  1. Feb 18, 2018 at 1:32 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Depending on the drive train you have. Im a 6 cyl. The 4cyl had different pumps.
    Use the vin check.
    6cyl shaft 4431206010 its $16.35 from toyotapartsestore.com
    Take a picture of the front face of your pump. I dissasembled mine v6 2004 and it uses the p.s o ring kit for the 95-04 2/4 wd 4 cyl. Not the V6, the v6 kit didnt have the proper O rings.
    When you dissasemble it remove the fluid drive blades and flip them so the fresh edge is out.
    @Lux threw this up 1400 posts ago managed to find this part.
    Lux likes this.
  2. Feb 18, 2018 at 2:10 PM
    Krazyoakes
    Krazyoakes Well-Known Member
    Isaac
    Eugene, OR
    01 Tacoma 4x4
    Check out what I just picked up for $20 :D @Blackdawg
    mechanicjon, SwampYota and Blackdawg like this.
  3. Feb 18, 2018 at 2:10 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Found a great deal on a set of Gen3 rims and tires. Think it looks pretty good. 268K and still rolling...
  4. Feb 18, 2018 at 2:12 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Picked it up now to buy the rubber tabs. And try to find a tan paint close to the same as my interior.
  5. Feb 18, 2018 at 2:17 PM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Hate welding exhaust tubing..
    SwampYota, 1st4x4 and Krazyoakes like this.
  6. Feb 18, 2018 at 3:00 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    now THAT is the best 20 bucks ever spent.
    Keep on Truckin' and Speedytech7 like this.
  7. Feb 18, 2018 at 4:25 PM
    Madjik_Man
    Colorado Front Range
    Congrats.
    I just painted/dyed mine black for simplicity.
  8. Feb 18, 2018 at 4:58 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Well I’m done. Changed the radiator, radiator cap, thermostat, all hoses, removed and cleaned out the overflow reservoir and put new Toyota Long Life Fluid in at a 50/50 mixture with distilled water.
    What prompted this was my truck consistently running at >200F.
    After I broke loose 2 of the 3 studs trying to remove the thermostat housing I confirmed my suspicions that Toyota put the thermostat in at 12:00 rather than 6:00 last year when they did my water pump and timing belt. I replaced and threaded the studs back in. Ripped out and replaced everything else, put it back together and fired it up.
    Ran it hard for 20 minutes down the highway after warmed up. Topped out at 190F! Stayed relatively steady at 186F. Made my day.
    Also, I bought a sticker on eBay for my new radiator cap. They don’t allow you to live that TRD radiator cap lifestyle with the 0.9 cap so I improvised. Yep I’m a dork.
    This took way longer than it should’ve and in all likelihood replacing the thermostat was all that was truly needed but hey, I now have no concerns at all with my cooling system as all components are <13 months old at this point. Now it’s time for a beer.
  9. Feb 18, 2018 at 5:00 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Funny brakes have popped up as I have been curious about that as well with the raised bpv bracket etc. Dirt testing makes sense n I proved that yesterday...the rears work fine... wich led me to look my next concern is my ebrake...what have you guys done with that line. It is not long enough to allow me full articulation. It needs to be addressed. Use the same bpv overload sensor bracket for that? Or remove the driver side harness on the axle?
    I found this
    http://www.parksoffroad.com/tacomamods/rearbrakelinerelocation/rblrelocation.htm
    Just wanted to see what you guys did/recommend with your ebrake line.
    Speedytech7 likes this.
  10. Feb 18, 2018 at 5:27 PM
    1st4x4
    sam
    Torrance
    What does it matter for the thermostat which way it goes?
  11. Feb 18, 2018 at 5:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The parks off-road way should tide you over well, plenty long enough for what springs in the stock position can flex to.
  12. Feb 18, 2018 at 5:55 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What a difference. That old carpet was not only a biohazard, it was a absolute threat to human health.
    At least the radio works...
  13. Feb 18, 2018 at 6:13 PM
    SwampYota
    Jon
    Floor mats
    1st4x4[QUOTED] likes this.
  14. Feb 18, 2018 at 6:27 PM
    tony2018
    tony2018 Well-Known Member
    Didn't know continental had silicon hoses for our trucks. Good to know.
  15. Feb 18, 2018 at 6:39 PM
    Adude
    Pnw
    04 Double cab
    The blue hose kit nice, how did it all fit up? Its on my right now list of to do.
  16. Feb 18, 2018 at 6:40 PM
    Madjik_Man
    It's not the thermostat, it's the jiggle valve that has to be installed in the proper orientation.
    I'm not 100% sure but I believe the jiggle valve allows air bubbles/pockets to either burp or somehow not disrupt the flow of coolant to the thermostat. If the jiggle valve is installed in the wrong direction air can get trapped on the engine side and make your engine temps higher or overheat.
    Someone else who knows what they're talking about please chime in :oops:
  17. Feb 18, 2018 at 6:42 PM
    SwampYota
    Jon
    Floor mats
    I don’t think they’re silicone, box doesn’t mention it. Just something about aramid reinforcement. Less expensive than OEM for all these hoses though:
    tony2018[QUOTED] likes this.
  18. Feb 18, 2018 at 6:42 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Service manual states to install the thermostat with the jiggle valve downward. As for what happens when you don't, I'm not sure.
  19. Feb 18, 2018 at 6:44 PM
    JasonLee
    15 TRD OffRoad
    They are EPDM (rubber) coated.
    Super Hi Temp, Blue EPDM Cover
      • Blue color identifies premium hose for ease of maintenance
      • Withstands high engine and ambient temperatures
      • Resists cuts and abrasions from road debris
      • Doesn’t require special clamps
      • Resists cracking from ozone
    SwampYota[QUOTED] likes this.
  20. Feb 18, 2018 at 6:45 PM
    SwampYota
    Jon
    Floor mats
    I had to cut about an inch off of two of the three hoses to the heater core. The rest fit perfect.
    tony2018 and Adude[QUOTED] like this.
