  1. Feb 28, 2018 at 9:18 AM
    eon_blue
    Azusa, CA
    Fixed my drivers side door handle last night, was way easier than the passenger side was for some reason...but I snapped the plastic retaining clip on the inner door handle. So I can get into my truck again from the driver's side, but now I can't get out of it lol :bananadead:
    Ordered a new one from Toyota should be here tomorrow :spending:
  2. Feb 28, 2018 at 9:23 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    Does the spring come in several lengths at ace or it just one size? My pedal does the sag thing and pisses me off. For $2 seems like a good project
  3. Feb 28, 2018 at 9:33 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    yes. I figure about 10 sft
  4. Feb 28, 2018 at 9:35 AM
    tony2018
    tony2018 Well-Known Member
    Sounds about right, maybe less. I use to overlap but after watching a couple youtube videos a guy explained you only need to cover a small percentage to reduce noise. From then on I just covered a majority but not a complete coverage.
  5. Feb 28, 2018 at 9:35 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Just one size. There are several there just get the #70 one
  6. Feb 28, 2018 at 9:38 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Just rained and the noise is still there... Not sure where this popping is coming from...
  7. Feb 28, 2018 at 9:45 AM
    TacomTyler
    TacomTyler Well-Known Member
    Tyler
    Georgia
    2000 sr5 tacoma
    Yes, it’s actually 2 booths put together. Both are down draft but the farthest one heats, can open the middle doors and heat both booths though
    wilcam47[QUOTED] likes this.
  8. Feb 28, 2018 at 9:47 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Anyone here lose the key to their spare tire? I just discovered mine was missing since I bought the truck. I hope they still make em and aren't expensive.
    Or better yet anyone have their but doesn't need it anymore because they relocated their spare, wanna send me theirs? :)
  9. Feb 28, 2018 at 10:04 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That spare tire lock key thing is super cheesy and you can break it right off and use the normal tool.
  10. Feb 28, 2018 at 10:33 AM
    taco lifter
    taco lifter Well-Known Member
    James
    2002 Tacoma 3.4 crew TRD off road
    3" Trailgear lift, rack on camper shell, deck plate mod, led
    Does anyone know if spacers are worth it? Or are they just pieces of junk and a waste of weight?
  11. Feb 28, 2018 at 10:39 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Really? Break what off exactly?
  12. Feb 28, 2018 at 10:40 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    How do you go about breaking it off?
  13. Feb 28, 2018 at 10:40 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Wheel spacers? Spacer lift? Throttle body spacers? Space ships? What kind of spacers?
  14. Feb 28, 2018 at 10:40 AM
    taco lifter
    James
    Lol wheels spacer
  15. Feb 28, 2018 at 10:47 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So it only happens when its wet?
    No issues. But id not go over 1.5'' spacers and I HIGHLY suggest running extended thread lug nuts to hold the spacers on.
    Most use them to help clear different wheels.
    taco lifter[QUOTED] likes this.
  16. Feb 28, 2018 at 10:53 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    And to add to this, I'd only run em if you need to. Like clearing wheels, or getting the tires off the frame. But I have wheeled the piss out of my spidertrax 1.25" and have no issues. I also use blue loctite on the studs.
    And @Blackdawg I'd only go extended studs if you are going with something like a .25" spacer, no? Otherwise the wheel would hit the factory studs when you put the spacers on, right?
  17. Feb 28, 2018 at 10:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no, i ran ET lugs on all 4 corners for a long time. Still do on the rear. But im running 1.5'' spacers so..maybe on smaller spacers.
  18. Feb 28, 2018 at 10:56 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Et lugs and you'll be fine.
  19. Feb 28, 2018 at 10:57 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    NVM read your post wrong, I read it as running extended studs not lug nuts.
    Blackdawg[QUOTED] likes this.
  20. Feb 28, 2018 at 11:04 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Yep only after it rains or occasionally after a car wash... I hit the same driveway curb everyday at an angle with no noise. But the moment it rains or gets wet it makes that popping noise.
