  1. Feb 28, 2018 at 8:18 PM
    Madjik_Man
    Colorado Front Range
    I did it. So 0.
    Squeaky Penguin likes this.
  2. Feb 28, 2018 at 8:18 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You got the right one. Loosen the bolt behind it to take the tension off the belt. Remove the bolt in the center to take the pulley off.
  3. Feb 28, 2018 at 8:21 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Alrighty, I'll mess with it tomorrow, can't do anything with it tonight anyway.
    Thanks for the help again everyone, hopefully this is the problem. Sorry for the lack of confidence and amount of questions.
  4. Feb 28, 2018 at 8:22 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Ok... quick question.
    Popped my radiator today, so I guess I'm doing the Timing belt, Water pump, etc and replacing the radiator (already had a radiator cause I was planning on doing this in the next few weeks anyway)
    I want to replace the fan clutch while I'm doing this (yes... I'm getting an OEM... lol)
    Question is... I see one for WITH tow package and one for WITHOUT tow package. I'm leaning towards the WITH tow package because I assume it's better. Any reason that one won't work?
    I have a 2002 6 cyl, auto, Prerunner, TRD.
  5. Feb 28, 2018 at 8:23 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    If you need the two rear most crossmembers I have a set at my parents in PA.
  6. Feb 28, 2018 at 8:29 PM
    koditten
    Kirk
    Central Michigan
    On the 4 wheel drive V6 trucks, the clutch was the same as the tow package clutch. Not sure about Prerunners, though.
    Why do you think your fan clutch is bad?
  7. Feb 28, 2018 at 8:37 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The truck has always run warm the whole 14 years I've had it.
    I don't neccesarily think the clutch is bad... but since I cracked the radiator and overheated today, I am moving up my plans to replace the Waterpump, timing belt, tensioners, accesory belts, cam seals, crank seal, radiator etc to like, tomorrow... I figure while I have it all torn apart, I might as well replace the fan clutch while I'm at it.
  8. Feb 28, 2018 at 8:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Here VV
    @JKO1998
    You have to loosen the front bolt FIRST before undoing the side one. The side one is for tension and the pulley won't move if the mount bolt is sucked down.
    One you have relieve the tension, remove the bolt holding the pulley on. There will be a washer and the nut. Then the whole pulley will come right off. Reverse process to go back on. Again, you can't adjust the tension with the mount bolt under torque.
    Madjik_Man likes this.
  9. Feb 28, 2018 at 9:01 PM
    koditten
    Kirk
    Central Michigan
    Please tell me you are reading the true water temp with a scan gauge or similar tool.
    The dash gauge is not accurate in any of our trucks.
  10. Feb 28, 2018 at 9:02 PM
    JKO1998
    Utah
    When I’m putting tension back on the belt, so tightening the side bolt, how do I know when it’s tight enough?
    The belt systems intimidating me for some reason.
  11. Feb 28, 2018 at 9:04 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I replaced this pulley a month or so ago but I’m still getting a humming noise. The new pulley definetly quieted the engine noise down but it still has a hum. Any idea what it could be guys? Doesn’t change when I turn the wheel, it’s all the time not just when the ac or def is on. Seems to only do it at idle and then goes away at higher rpms (or I can’t hear it anymore). Belts are def shot and need to be replaced soon.
    Edit: 04 3.4l 5 speed @140k
  12. Feb 28, 2018 at 9:05 PM
    Reh5108
    Idaho
    Toyotas first attempt at a hybrid vehicle. There marketing department failed and it is only good for very shosh distances.
    On a more serious note it's convenient to not have to hop in the truck to start it on cold days. If your clutch fails you can start in gear then rev match from there. And then there's this...
  13. Feb 28, 2018 at 9:05 PM
    koditten
    Kirk
    Central Michigan
    If you don't have it tight enough, it will squeel when ac runs.
    Feel how tight the altinator belt feels by trying to twist it. Make the ac belt the same tightness.
  14. Feb 28, 2018 at 9:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I usually go for 1/8'' of deflection(belt moves about 1/8'' when you press on it.)
    From there, start it up, if it squeals, at some more tension, just a turn or so and try again.
  15. Feb 28, 2018 at 9:06 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Yes... I'm aware of the fan support bracket. I'm ordering that too, lol. Although I have never had any squealing or any signs of that bearing being bad... at 265,000 miles, I'm gunna say fook it. The old one has to come off to replace the water pump, I'm not putting the old one back on.
    Buuuut... back to the original question. Is there anything I'm not aware of, that would cause a tow package fan clutch to not work on a 2002 Prerunner, 6 cyl, auto, TRD?
  16. Feb 28, 2018 at 9:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. As stated in that post most came with the green on and thats the one they sell for use now anyways. It'll work just fine. Though i doubt that'll drop you engine temps. What will is your new radiator.
  17. Feb 28, 2018 at 9:10 PM
    JKO1998
    Utah
    Your problem sounds like my problem.
  18. Feb 28, 2018 at 9:13 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I understand... the clutch is more preventative maint. I figure I have a lot of miles on the truck and hopefully I wont have to get at the fan pully, clutch, etc anytime again soon... so I might as well replace it while I'm in there.
    At least that's my thinking on it... could be wasting 90 bucks too... lol
  19. Feb 28, 2018 at 9:23 PM
    1997tacomav6
    Denver
    Yu
    yup the green one I believe was with the tow package maybe, I replaced mine green one from O'Reillys But returned it for an OEM from Toyota as it was acting funny when it engaged.
    Stay with OEM
  20. Feb 28, 2018 at 9:27 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya... I'll be going with Aisian on this one.
    Unless I can find a Moog fan clutch. lmfao (jooooking) :thumbsup:
    1997tacomav6[QUOTED] likes this.
