  1. Mar 4, 2018 at 1:10 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Nice, what’d you use?
  2. Mar 4, 2018 at 1:33 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    That’s where I put mine at.
    1997tacomav6[QUOTED] likes this.
  3. Mar 4, 2018 at 1:41 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Installed an airaid tube to complement my afe and snorkel. Was going for a drive and the truck wouldnt go. Forgot to reset the ecu..lol. .
    Also tightened the valve cover bolts. They were too loose and i have gunk all around. Hope this helps
  4. Mar 4, 2018 at 1:50 PM
    Crock112
    Crock112 Well-Known Member
    Crock
    New England
    '04 2.7l SR5 4x4 xtracab
    TacoYankee[QUOTED] likes this.
  5. Mar 4, 2018 at 1:51 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Thanks but I'm needing the plate that covers the lower part of the bell housing.
  6. Mar 4, 2018 at 2:32 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    20180304_142707.jpg Bent slider should I cut it at the red line and cap them. Thoughts? Think it will end up just being a place to get cought on a rock? Only reason I'm thinking is since the other one got welded to far forward and the tire rubs.
  7. Mar 4, 2018 at 2:39 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    If it were me, I'd cut them off and re-weld them back in the right place
  8. Mar 4, 2018 at 2:43 PM
    1st4x4
    sam
    Torrance
    Drivers side isn't bad since it's bent if I could easily bend the other I'd just do that. Im thinking of cutting them off but that's going to be alot of grinding wheels to get threw the welds.
  9. Mar 4, 2018 at 2:46 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Cutting wheels then grind left over after removed.
  10. Mar 4, 2018 at 2:48 PM
    1st4x4
    sam
    Torrance
    Probably going to go threw a dozen cutoff wheels
  11. Mar 4, 2018 at 2:55 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Autozone has the scanguage im looking for. Fuck. Yes.
  12. Mar 4, 2018 at 2:56 PM
    1st4x4
    sam
    Torrance
    How much is it at AutoZone? You going for the scangauge2? I got mine on eBay for 80 bucks
  13. Mar 4, 2018 at 3:00 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    you can check the heads and block for flatness with a good straight edge
    If the cylinders look good you can get away with honing and new rings. pistons dont have to be replaced if they look like they're in good shape.. but i would replace them. should be markings on the block to show which to get (if you go oem and the cylinders are still in spec)
  14. Mar 4, 2018 at 3:01 PM
    1st4x4
    sam
    Torrance
  15. Mar 4, 2018 at 3:08 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I'm basically restoring this thing which is why I asked. Anything else I should do in the engine?
  16. Mar 4, 2018 at 3:10 PM
    Empty_Lord
    Dan
    tried taking the stud out for the steering rack today so i could replace it (threads buggered up on the end for the nut)... and low and behold, the asshole who did my frame cross threaded the stud into the nut on the frame... the nut broke off the frame I'm not a happy individual right now..
  17. Mar 4, 2018 at 3:13 PM
    Empty_Lord
    Dan
    rods likely can be reused. cranks probably fine.. new bearings, new head bolts and main bolts.. have the block hot tanked if you want it nice and clean. maybe have some headwork done.. if the engines running fine right now you don't need much for it to be restored to like-new
    and of course paint the block and enjoy a shiny engine block
  18. Mar 4, 2018 at 3:36 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Aaaaaand DONE! Waterpump / Timing belt complete.
    Answer to your question... Waterpump / Timing belt probably took 8 hours actual wrenching time.
    It took me longer than that because I was cleaning every thing I could get to, while I had it taken apart, I was having to come up with solutions on the fly with the aluminum radiator... making the shroud fit and the lower radiator hose. I spent a good solid 2-3 hours just flushing the cooling system before I started, and had to make a few parts runs because I forgot you should replace the crank pulley bolt when you do this, my kit from Aircabinman came with the wrong thermostat, and I needed an upper radiator hose from a 1998 Dodge Neon to use for my lower on the new radiator.
    Adude[QUOTED], TacoYankee and 1st4x4 like this.
  19. Mar 4, 2018 at 3:45 PM
    1st4x4
    sam
    Torrance
    I'm doing mine soon hopefully he didn't send me the wrong thermostat
  20. Mar 4, 2018 at 3:49 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    If yours is the same as mine, 6 cyl auto, you need a 90916-03075 Thermostat.
    He sent me a 90916-03093 Thermostat.
    The damn thermostat at the Stealer-ship was 52 bucks!
