  1. Mar 6, 2018 at 4:47 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The level feels like it goes in fine buuut i have had a time or two when it feels like somethings blocking it? I havent tried 4 low, but I can really quick.
    FLBAdrian likes this.
  2. Mar 6, 2018 at 4:48 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    I notived a big difference on the highway when i did mine not too long ago...stick shift was shaking like mad before, now...hardly at all.
  3. Mar 6, 2018 at 4:52 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    Mine is cracked as well. I used that Flex Seal tape...not OEM, but works. Besides, that tank isn’t cheap.
  4. Mar 6, 2018 at 5:59 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    I supply the parts mechanic said 300 to do the work I think I'm just going to let him do it I think.
    Timing Belt,Idler Roller,Tensioner Roller,Front Crankshaft Seal,Front Camshaft Seals,Water Pump,Water Pump Gasket,PCV Valve,Hydraulic Tensioner,Thermostat,Thermostat Gasket,Air Conditioning Belt,Alternator Belt,Power Steering Belt,Valve cover gaskets,1/2 moons,Cam plugs,Washers for bolts for valve cover,Carrier Bearing,U-joints
    Laundry list of parts being replaced. Anything else someone can think of that I should have done while this far in
  5. Mar 6, 2018 at 6:02 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Had the same issue with my non oem grille... Basically had to bend it to get it to fit.
  6. Mar 6, 2018 at 6:04 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Shit that's why. It's some cheap off brand grille but it's gonna take more than a bend to reach that port.
    Delta00[QUOTED] likes this.
  7. Mar 6, 2018 at 6:12 PM
    kmcmahon5
    kmcmahon5 Well-Known Member
    B.C.
    1996 Tacoma, 1989 pickup
    Just got back from an annual 10 day trip and the first gens outnumbered the others
  8. Mar 6, 2018 at 6:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah that's way off, I've had good luck with the TYC and Various Brands ones on RockAuto that are CAPA certified cause they at least verified fit rather than design off of pictures.
  9. Mar 6, 2018 at 6:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    thats not because you bent your core support?
  10. Mar 6, 2018 at 6:40 PM
    Speedytech7
    Looks really straight in relation to the rad
  11. Mar 6, 2018 at 6:41 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  12. Mar 6, 2018 at 6:43 PM
    Speedytech7
    That's an early 80s Toyota pickup
  13. Mar 6, 2018 at 6:46 PM
    1st4x4
    sam
    Torrance
    Haha it's a 80s toy pickup. If it was a jeep he would be with that one lonely guy that thought he was going to a jeep meet and found all the real trucks instead
  14. Mar 6, 2018 at 6:46 PM
    TashcomerTexas
    It's a new core support.
    Blackdawg[QUOTED] likes this.
  15. Mar 6, 2018 at 6:47 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    lmao ok, mistaken identity on my part i saw the grill and was really concerend
    1st4x4 likes this.
  16. Mar 6, 2018 at 6:50 PM
    JKO1998
    Utah
    Wer were you going somewhere with this?
  17. Mar 6, 2018 at 6:56 PM
    Speedytech7
    I was, but I thought you were gonna try 4low and get back to us whether it clicks still. Just trying to narrow down where it is coming from.
  18. Mar 6, 2018 at 7:01 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Came out NICE! Do you happen to know which size Rigid lights you used?
  19. Mar 6, 2018 at 7:04 PM
    JKO1998
    Utah
    Oh duh, forgot about that..
    jjsul likes this.
  20. Mar 6, 2018 at 7:06 PM
    1st4x4
    sam
    Torrance
    He's drunk haha
