  1. Mar 7, 2018 at 7:02 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
  2. Mar 7, 2018 at 7:03 PM
    1st4x4
    sam
    Torrance
    Hammer trick to cut it out?
  3. Mar 7, 2018 at 7:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  4. Mar 7, 2018 at 7:11 PM
    Patmaui
    Patmaui Well-Known Member
    Pat
    Maui
    02 2.7L 4x4
    K&N intake magnaflow exhaust fabtech 6" king coils front procomp rear total chaos uca's 33x12.5x15 bfg km3's 15x10 procomp alloys 4.88 gears
    This type is motorized so you can tilt the screen to 5 different positions. I have it set to the most angled in the picture due to the location on our trucks. The sound on the stock speakers is way better too.Thing is so sick! $300 Amazon and dont forget your wire adapters
  5. Mar 7, 2018 at 7:12 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Now that is nice!
  6. Mar 7, 2018 at 7:28 PM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    Does anybody have the part number for the bearing for AC tensioner pulley?
    Or the pulley assembly itself.
  7. Mar 7, 2018 at 7:29 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Started the tear down for the valve cover gasket replacement. Went pretty smoothly. Looks like it’s been done before. So many old hoses and stuff that should probably be replaced at some point. Here is before I started and where I got to: 2EF1F757-4996-4EBA-A170-6DBD8E3BD060.jpg 562BF492-7B50-4E55-8DF4-89B888E35381.jpg
    BYJOSHCOOK, FLBAdrian and SwampYota like this.
  8. Mar 7, 2018 at 7:31 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I know it’s not very helpful, but that pulleys only like 30$ at autozone.
    fiziks[QUOTED] likes this.
  9. Mar 7, 2018 at 8:00 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    No problem man glad to help. I have a note book for every project on compatible parts sources ect.
    I belive this is it, the disscussion was had a few days ago.
  10. Mar 7, 2018 at 8:06 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Make sure you remember where they all go lol. I fucked it up on my supercharger install lol
  11. Mar 7, 2018 at 8:06 PM
    Adude
    Pnw
    04 Double cab
    This looks like a gear drive case vs the tacoma chain drive, but it might help.
  12. Mar 7, 2018 at 8:18 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Pulley assembly (v6): 88440-04040 (or you can get a non-OEM at your local parts store for $30)
    Replacement bearing: 6301-2NSE
  13. Mar 7, 2018 at 8:33 PM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Got my tablet all mounted up for nav
  14. Mar 7, 2018 at 8:55 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    I took some before photos to help with that. A a lot of it will be from memory though, which I’m glad I have a good one
  15. Mar 7, 2018 at 9:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    lol man oh man. It is so easy to just put piece of tape on the hose and the end you pulled it off of and label 1...then 2...then 3.
    Just connect the numbers when you put it back together.
    This also ensures you never miss a small line that falls down somewhere or something as it'll have a piece of tape on it and the part you need to connect does too. Blue painters tape is a big flag as well.
    ireymon, Teke and Adude like this.
  16. Mar 7, 2018 at 9:03 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    that tip probably helped you out more then you can mention it when working on frank
  17. Mar 7, 2018 at 9:22 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Another small part of the problem is that some of the lines go somewhere slightly different. One of mine wasnt used which threw me off as well. More than a little help was needed but I got it hooked up right finally. Sidenote, it still isnt running quite right.
    Speedytech7 likes this.
  18. Mar 7, 2018 at 9:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  19. Mar 7, 2018 at 10:24 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    This is driving straight. Living on the edge.
  20. Mar 7, 2018 at 10:27 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    how'd ya manage that? new rack?
