  1. Mar 12, 2018 at 9:52 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    IIRC, the resting height of SuperBumps is ~5" and they compress ~2" bringing them to 3", which just about matches the factory bumps. It's deceiving, but SBs don't really add any height. They are just a less jarring approach to bumpstops than the triangular hockey pucks that come stock.
    austinmtb[QUOTED] likes this.
  2. Mar 12, 2018 at 9:58 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Today I wished the truck a happy birthday. It turns 19 today around noon.
    When I brought it home there was a Bed Rug, seat covers, Husky mats and the full FSM waiting. The cap had been ordered. 2 weeks later I was drilling holes in the dash and sealing the locker actuator.
    Prayn4surf, Jiveydude, jubei and 7 others like this.
  3. Mar 12, 2018 at 10:02 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Are you measuring the whole mount that wheelers sells, or just the bump itself?
  4. Mar 12, 2018 at 10:09 AM
    sente3
    sente3 -
    North Jersey
    That's the entire mount. From base to the tip of the bump. But I just checked my measurement, since I wasn't sure. Seems to be more like a little under 4.5" static height. And the bumps themselves are just over 2.5".
    Disclaimer: I have not measured the compression myself. I have read it from other users. But seems to be consistent agreement that they compress to factory height.
  5. Mar 12, 2018 at 10:54 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I wish the metallic part was black, then I'd be all over them.
    That's probably why the winch still isn't done :anonymous:
    Prayn4surf and BYJOSHCOOK like this.
  6. Mar 12, 2018 at 10:57 AM
    tony2018
    tony2018 Well-Known Member
    :smokertransformer::drunk::cheers::dancingbacon::broccoli::bananadead::spy::spy:
  7. Mar 12, 2018 at 11:14 AM
    tony2018
    Gonna continue finishing up on the rear axle swap, connect shaft add diff fluid, swap brakes, bleed brakes.
  8. Mar 12, 2018 at 11:23 AM
    dorkknight
    dorkknight Well-Known Member
    Fort Worth, TX
    2001 Tacoma Double Cab TRD 4x4
    So I live in an apartment and realized that I need a work bench that is easily portable. I saw a video about this workbench that was integrated into the tailgate of a pickup. After searching and searching for this product with no success, I said frig it and decided to make my own. This also gave me a chance to test out my new DeWalt router. It took about a week or so to build due to staining and sealing the wood but I am very happy with it. It is maid from wood instead of metal or plastic, but I think it will hold up nicely with the stain, sealer, and tung oil. I also now have a bed cover that only cost me $10. :D
    I designed it to bolt down to my tailgate for a "permanent" solution. However, it can be easily removed. I also made some tie-downs that secure the bottom of the bench since there are no holed at the bottom of the tailgate. These tie-downs slide into the drain holes of the tailgate and are screwed down into the wood. I also drilled holes and inserted threaded inserts to bolt down my equipment. On the right side sits my miter saw. In the middle I have holes for my table vice in case I need it. On the left are two holes for my hold-down clamps that I made from all-thread, handles, a piece of aluminum, stop-nuts, cap-nuts, and some good ol' plasti dip. The clamps aren't perfect, but they are fairly nice and will most definitely do the job. Anyway, the pictures are below. Please feel free to comment, give advice, ask questions or whatever else.
  9. Mar 12, 2018 at 11:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Mad respect to anyone who can work the dead tree carcasses. Looks really nice, what kind of stain is that?
  10. Mar 12, 2018 at 11:31 AM
    dorkknight
    Fort Worth, TX
    Thank you! I am just now getting in to the whole woodworking thing. I needed a new hobby. The stain is olympic elite stain and sealer. It was a sample can and it said "tan". After the stain I applied two coats of Tung Oil.
    Speedytech7[QUOTED] likes this.
  11. Mar 12, 2018 at 12:03 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Not to bash on Trail Gear, but holy shit check out the differences in these shackles.
    Trail Gear 3/4" Shackle WLL = 4.75T____5:1 Design Factor
    CM 3/4" Super Carbon Shackle WLL = 6T_____6:1 Design Factor
    That is over a 15 Ton difference in breaking strength.
    https://youtu.be/qiZmsRuSEjA
    Adude, Speedytech7 and dorkknight like this.
  12. Mar 12, 2018 at 12:20 PM
    Speedytech7
    I know isn't it crazy? I get the $20 ones from Tractor Supply because they're rated 6.5T and they actually come with a gold zinc coating on the pin so it fits right, instead of powdercoat where it is too big
    Adude and SnowroxKT[QUOTED] like this.
  13. Mar 12, 2018 at 12:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Long as it isn't made in China. I wouldn't worry about that.
  14. Mar 12, 2018 at 12:45 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Put a double din dvd in the other day (a must have when you have kids)
    Took the first leaf out and replaced it with an aal from a Chevy 1500. Gave me about 2.5-3” lift overall.
  15. Mar 12, 2018 at 1:48 PM
    RVA_TRD
    RVA_TRD Well-Known Member
    Richmond Virginia
    2000 TRD Offroad, Bilstien 5100s front and rear with 881s and OME Dakars
    Bilstien 5100s on 881s front Bilstien 5100s rear with OME Dakars, together total about 3" of lift 31' Toyo Open Country All terrain Grey Wire mod
    What are the name of those wheels you usually run? I have the same wheels and have no idea what they are lol.
  16. Mar 12, 2018 at 1:49 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Also have no idea, they say eagle on the caps if I remember right.
  17. Mar 12, 2018 at 1:50 PM
    Speedytech7
    That would mean they're American Racing Eagle Alloys
  18. Mar 12, 2018 at 1:51 PM
    JKO1998
    Utah
    I figured, just don’t know what model I guess.
  19. Mar 12, 2018 at 2:20 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    My double cab decided it wanted to add an appendage...
  20. Mar 12, 2018 at 2:24 PM
    eon_blue
    Azusa, CA
    Awesome! The only thing keeping 1st gen Tacomas from having been god's greatest gift to man was the fact that the double cabs were never offered with a manual trans.
    Now you just need floor mats lol
