  1. Mar 12, 2018 at 6:43 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    Those look just like my GE Nighthawks without the branding.
    The nighthawks are awesome, but one now has some moisture in it :(
  2. Mar 12, 2018 at 7:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I was considering those, they look nice and GE has a good warranty. I thought they covered them for like 5 years?
  3. Mar 12, 2018 at 7:26 PM
    jjsul
    James
    New Hampshire
    95.5 OME
    I should look into that. PO installed them but they’re def less than 5 years old
  4. Mar 12, 2018 at 7:26 PM
    17tacostormtrooper
    17tacostormtrooper They call me bacon!!
    Zach
    Pike county Ga
    2017 TRD DCLB/2000 ext cab trd
    Stage 2 icon lift 285/55r20 toyo rt tires Fuel maverick 20x9 wheels Window tint Vent shades LED interior lights Led reverse light Night light rear led standalone reverse lights Smitty built drivers side mole gear seat cover Husky floor mats Truxedo bed cover Factory roof rack Custom grill
    2000 Taco 2.7
    Any of you guys have a clue what is going on with my truck I have replace the
    coils
    Plugs
    Wires
    Egr valve
    Egr modulator
    All vaccumn lines
    Maf sensor
    Fuel filter
    Only run 93 octane with octane booster
    I have also cleaned the throttle body and checked for vaccumn leaks.
    I am getting a slight skip seems to be more under 2500 rpms like from idle to 2500. But sometimes skips above that, I have checked all coils and replace them again all plugs and wires are ngk. It is not throwing any codes I do not know what the hell is going on!!!it was doing this before I did all this. Any help will be appreciated!
  5. Mar 12, 2018 at 7:44 PM
    jjsul
    James
    New Hampshire
    95.5 OME
    @Speedytech7
    3 year warranty :( I missed it by a couple months
  6. Mar 12, 2018 at 7:47 PM
    Speedytech7
    Damn! I'd still give them a call and see if they're willing to give you a deal on one or something. Usually because these are 100% sealed because of the non changeable LED there is zero reason for them to fog.
    jjsul[QUOTED] and flenniken7 like this.
  7. Mar 12, 2018 at 8:11 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ordered Tire and washed the 1 1/2" of mud off of it. Tomorrow Ill get my tire fixed and buy some paint supplies for my wheels. Aughta be a good time.
    Clarification: I ordered 4 tires, happened to miss the "s"
  8. Mar 12, 2018 at 8:22 PM
    Speedytech7
    tire? Like a single tire? Why
  9. Mar 12, 2018 at 8:27 PM
    JKO1998
    Utah
    Cause I missed the S....
  10. Mar 12, 2018 at 8:28 PM
    Speedytech7
    Oh okay, cause a single tire after you've worn the other three down is a pretty massive waste of money haha
    Adude likes this.
  11. Mar 12, 2018 at 8:29 PM
    JKO1998
    Utah
    I may be dumb, but I don't believe I'm that dumb.
    Adude likes this.
  12. Mar 12, 2018 at 8:31 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Nice.
    Getting the settings can be a pain, but we'll worth it.
    ToxicTwin, ToyRyd04, JKU3000 and 6 others like this.
  13. Mar 12, 2018 at 8:31 PM
    JKO1998
    Utah
    Speedytech7 and SwampYota like this.
  14. Mar 12, 2018 at 8:32 PM
    Speedytech7
    I didn't believe you were either. Hell if you come down to AZ you can run a set of tires all the way from mud terrain to track slick and keep on going till you're on the cords haha. People down here run around on bald ass tires cause it doesn't rain often then act all surprised when theres a 90 car pileup after it sprinkles. And then have the nerve to change one tire.
  15. Mar 12, 2018 at 8:44 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    What plugs did you use....
  16. Mar 12, 2018 at 8:45 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Can confirm, have driven on BFG AT drag editions when I lived in AZ
  17. Mar 12, 2018 at 8:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I went the dual battery route. 2-group 24F AGMs. One in the stock location and one in the bed.
    There isn't enough room in the stock location. And in many of our trucks there isn't enough room anywhere under the hood for a 2nd one.
    Silver02Taco likes this.
  18. Mar 12, 2018 at 8:53 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Speedytech7 likes this.
  19. Mar 12, 2018 at 8:57 PM
    JKO1998
    Utah
    Dick Cepek also has a rebate that goes till May, I dont know if theyre stackable, but I'm going to try, making it 499$.
    Most the reviews Ive read have been positive also, so thats a plus.
  20. Mar 12, 2018 at 8:59 PM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I have dual batteries in the stock location. Columbia Overland makes the kit, although I believe they shut down their business.
