  1. Mar 15, 2018 at 8:28 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The bumper on the 5-Lug is beyond repair, so I went ahead and bought a fiberglass rollpan for it that would be flush with the bed. Looks a lot better on 5-Lugs since they ride so close to the ground than the stock bumper IMO.
  2. Mar 15, 2018 at 8:37 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Are you gonna put that on your trailer?
  3. Mar 15, 2018 at 8:58 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If I turn it into a trailer. The plan is still to restore the truck.
    That's if the Bonded Title doesn't cost me too much.
  4. Mar 15, 2018 at 9:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Looks great Dan. I'm looking forward to the write-up/report.
    turbodb[QUOTED] likes this.
  5. Mar 15, 2018 at 10:36 PM
    zhillian
    zhillian Member
    Ray
    '98 Tacoma
    The only thing I have done is take it back! I had given it to my son but he just bought a Jeep. I'm happy to have it back!
    flenniken7 likes this.
  6. Mar 15, 2018 at 11:27 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I switched to the '01-'04 under radio trim with the switch blanks instead of the pocket.
    I never realized how good of a mounting location this is for a ScanGuage. The wire feeds from the back through a switch blank and it gives you a very clean look.
  7. Mar 15, 2018 at 11:44 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    So if I've I programmed this right TFT should be reading out the transmission temperature.
    I guess my transmission is currently -39.9 Degrees Fahrenheit.
    I have a feeling scangauge only correctly reports transmission temperatures on newer cars. Something about switching from the ISO to CANSF protocol or something in 2003.
    2002Tacoma4x4 likes this.
  8. Mar 16, 2018 at 12:31 AM
    tony2018
    tony2018 Well-Known Member
    ok fuck this, running new wiring to the elocker. But 1st, gotta reseal the pumpkin. Which means if I have to pull the axles I might as well do the seals and bearings and never have to look at it again.
  9. Mar 16, 2018 at 2:18 AM
    Jet3Bamafan
    Jet3Bamafan Active Member
    Trey
    Livingston, Montana
    1998 Toyota Tacoma sr5 4wd Ext Cab
    Leer camper shell, Cabelas Cargo Rack,LED interior Map Lights
    What`s the biggest tire size you guys are running on 2.5" lifts? With and without spacers? 15 or 16" wheels? I`m running the ome 883 coil springs with billy 5100`s and the Dakar 2.5" leafs in the rear.
  10. Mar 16, 2018 at 3:47 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    Yes. You won't be able to mount your front wheels without them. Got a lot of frame rub with 1.25". Had to use 1.5". Still rub a tiny bit on one side.
    flenniken7[QUOTED] likes this.
  11. Mar 16, 2018 at 6:12 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    The tech did the same to me. I told him I know I'm replacing the entire rack soon hahaha
  12. Mar 16, 2018 at 6:19 AM
    flenniken7
    flenniken7 Wishin' I was Fishin'
    OKC
    2000 4x4 tacoma 1996 Z71 DD 248K, 2012 tahoe
    5100's 285' to come 4" lift 33's on hoe
    Thanks for the info
    2BeersPlease[QUOTED] likes this.
  13. Mar 16, 2018 at 7:03 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    35s on 15x10s. 1/4 inch spacer up front
    Silver02Taco likes this.
  14. Mar 16, 2018 at 7:07 AM
    mxjagracer
    mxjagracer Well-Known Member
    Asheville NC
    2000 Tacoma 4x4
    Replaced the busted harmonic balancer
    2002Tacoma4x4 and Dalandser like this.
  15. Mar 16, 2018 at 7:20 AM
    2BeersPlease
    With 5100s all around and no trimming, right?
    Silver02Taco and jubei like this.
  16. Mar 16, 2018 at 7:29 AM
    2BeersPlease
    Area51Runner likes this.
  17. Mar 16, 2018 at 7:48 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    With or without trimming/cutting is the question you need to ask here. Lift doesn't matter. Wheel spacers makes it worse.
    31s - no trimming
    32s - very minor trimming to the wheel liner and pinch weld
    33s - cut/hammer all of the pinch weld, and you'll start running into other issues here and there like the windshield washer reservoir.
    34s - you'll get to know your favorite BFH well as you smash the firewall back as far as possible
    35s - tubbing
    Silver02Taco, Adude, jubei and 7 others like this.
  18. Mar 16, 2018 at 8:02 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I took a look at my belts this morning since one squeals like a banshee sometimes and realized I'm missing the alternator tensioner bolt.
  19. Mar 16, 2018 at 8:35 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    I think ilI' be getting a cbi bumper as well but which one
  20. Mar 16, 2018 at 8:41 AM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    that's not great... I just tightened all mine, had an awful squeal going for the last couple weeks, but moving took priority.
