  1. Mar 16, 2018 at 6:35 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Anyone have a part number... or even a proper name for that stupid rubber guard?
  2. Mar 16, 2018 at 6:43 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It is as easy as the Low Range video makes it out to be. If you are changing the inner tie rods, I would change the outers too.
  3. Mar 16, 2018 at 6:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How much does one of them steelies weigh?
  4. Mar 16, 2018 at 6:51 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    I took my top off
  5. Mar 16, 2018 at 6:52 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    27# ish
  6. Mar 16, 2018 at 6:54 PM
    AZn8v
    AZn8v Well-Known Member
    2019 TRD OFF-ROAD
    Added a Yakima Megawarrior basket on 60" tracks.
  7. Mar 16, 2018 at 7:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So ~75# total. How does that compare to what you are rolling on now? Since these will no doubt be taller than those, you will already be loosing some performance. More unsprung weight will impact that too.
  8. Mar 16, 2018 at 7:12 PM
    JKO1998
    Utah
    Honestly have no idea, I can weigh them I take them off next week.
    Worn out Studded St Maxx’s 31/10.5/15
    Digiratus[QUOTED] likes this.
  9. Mar 16, 2018 at 7:12 PM
    tony2018
    tony2018 Well-Known Member
    SO, yotamasters and low range off road has a kit. But I need to verify something before I order plus I might need more of that FIPG for the pumpkin instead of using the gasket they sell.
  10. Mar 16, 2018 at 7:35 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Question for those more familiar with the 3.4 history than I... What would be the up and down sides of putting an ECU from a 98 in a 01? Any? Would it even worth right? I know there are a few differences over the years but I'm not sure what they all are...
  11. Mar 16, 2018 at 7:36 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    Can you say a little more on this?
    My cousin and I busted out my rear shock relocation pretty quick, couple hours. I will say I didn’t break down my leaf pack. We just made it so the OME nitrocharhers could make full droop, plus some.
    My only concern was that my bump stops wouldn’t be tall enough to stop compression from smushing the shocks. I don’t wheel super hard, and my Dakar’s are stiff and barely flex, so I wasn’t too worried at the time.
  12. Mar 16, 2018 at 7:37 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Honestly, I’m not sure what they’re going to charge. But it’s people I know, that have worked on this truck for years so I feel like they’ll do right by me. My problem is I don’t have a garage or shop, I’m doing it under my 24x31 shelter with plywood laid down do I don’t have to lay in the dirt. It’s another added cost to the conversion, but it’s worth it for me without having to buy a tranny jack or the headache having to swap the tranny without really knowing what I’m doing.
    I’ll keep that in mind about the runout specs on the torque converter. But I think I have an extra flex plate laying around from a recent motor swap, so that’s a plus in the event something happened :thumbsup:
    It will be all manual. Not only for convience sake, but I’ve always wanted a Toyota with manual hubs even since before I could drive.
  13. Mar 16, 2018 at 7:47 PM
    tony2018
    I don't know if it'll work. I think the ecu plugs are different.
    ClevSix[QUOTED] likes this.
  14. Mar 16, 2018 at 8:00 PM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    I think Bearing but I'm not so sure now
  15. Mar 16, 2018 at 8:14 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I would stick with the 01-02 ECU. It should be the same model too. Dont get a cali one either then you will get stuck with having to buy new cats that meet cali smog requirements. Do not get an 03-04 Ecu either because the throttle body and tranny are different.
  16. Mar 16, 2018 at 8:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    no it was a dealer install option only. All TRD performance accessories are.
    well sounds like you are using your shocks as limit straps now..also not a good thing
  17. Mar 16, 2018 at 8:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    none and you also can't.
    Pin out changed and the connectors changed
  18. Mar 16, 2018 at 8:18 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I guess where I'm coming from is trying to dial a "midtravel" setup, versus just tossing the shocks in another location. Breaking down the leaf pack and cycling alone would take more than a couple hours. Bumped, soon to be strapped, getting as much usable travel out of my leafs as possible, etc. All takes lots of trial and error to get dialed. The shorter the shock the easier too, getting 2.5x10" to fit under the bed was a bit of a struggle.
    malburg114 and Yetimetchkangmi like this.
  19. Mar 16, 2018 at 8:22 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Thank you
  20. Mar 16, 2018 at 8:52 PM
    JKO1998
    Utah
    What’re the down sides of a shackle lift?
    When I ordered my Alcans I asked for 3” of lift, I don’t know if that’s where they currently stand.
    This pictures making me nervous.
    Like I might need a little more lift.
    Also might end up ordering a axle relocation plate.
    FLBAdrian and 2002Tacoma4x4 like this.
