  1. Mar 30, 2018 at 8:12 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I'm guessing the difference is AllData Pro includes proprietary Manufacturer info like how many hours it should take to do a repair and how much it pays. Stuff like that.
  2. Mar 30, 2018 at 8:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Bolt up? No, you'd have to make brackets to hold it in line over the A/C compressor or on the other side of the engine by the alt. But it only makes like 3-6lbs of boost so it wouldn't even need tuning, the ECU could account for it just fine on its own, plus you could turn it off with the flip of a switch because of the whole electric clutch deal.
  3. Mar 30, 2018 at 8:14 PM
    Speedytech7
    Yeah, you don't even want to know my opinion on all of that, I remember when Hybrids were the new thing and they got free passes. Only Cali vehicle legislature I really like has to do with lane splitting and filtering.
  4. Mar 30, 2018 at 8:16 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Cali's laws pertaining to cars is just a huge black hole...
    Prius drivers are some of the worst drivers in the world. Seriously. I'd say 1/4 of all cars in California is the Toyota Prius.
  5. Mar 30, 2018 at 8:25 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Yes sorry my turn signals thank you. Is that what it's called threw toyota
  6. Mar 30, 2018 at 8:26 PM
    Speedytech7
    Yeah it is a turn signal cancel cam, it sits in the column behind the clock spring. Almost guarantee it would be ultra cheap at a junkyard and the ones from 2wd models should fit fine.
  7. Mar 30, 2018 at 8:27 PM
    1st4x4
    sam
    Torrance
    No sorry my blinker won't shut off when I turn
  8. Mar 30, 2018 at 8:29 PM
    1st4x4
    sam
    Torrance
    Okay cool I'm going to look into it. Fairly easy to remove?
  9. Mar 30, 2018 at 8:30 PM
    Speedytech7
    Yeah just gotta pull the steering wheel, clockspring, and then you can get to it. Be careful not to turn turn the clockspring or the column after you separate them though.
  10. Mar 30, 2018 at 8:43 PM
    1st4x4
    sam
    Torrance
    I have a removable steering wheel on my truck so that comes off easy just have to figure out the rest
  11. Mar 30, 2018 at 8:47 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    You’re like my Green twin! :cheers:
  12. Mar 30, 2018 at 9:17 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I kinda want to get rid of the P0141 code the truck has been throwing for 6 years, which is well before I owned it. I'm guessing the cat is bad and its a California emissions truck. Any cheaper way of getting it to go away aside from pulling the bulb or putting tape over the light. Just don't feel like spending a bunch of money to basically get a light to go away.
  13. Mar 30, 2018 at 9:26 PM
    Speedytech7
    P0141 is an O2 heater circuit code, not a cat code (P0420), you need a new O2 sensor. You need an O2 for after the cat.
    Prayn4surf and Dalandser like this.
  14. Mar 30, 2018 at 9:34 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Tis the less expensive sensor too
    Dalandser likes this.
  15. Mar 30, 2018 at 9:54 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Well good thing I have one sitting on the shelf of parts that I need to put in. I just thought I read somewhere that the cat could also be bad causing the code. I dont know how I'm gonna get those rusty nuts off the studs lol
  16. Mar 30, 2018 at 9:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Do you have a oxy torch?
  17. Mar 30, 2018 at 9:56 PM
    Speedytech7
    Nope, it is a tossup between cat and sensor when the code is a P0420, but P0141 is simple either the wiring to the O2 sensor is faulty or the sensor is faulty and 99% of the time it is the sensor.
    Teke[QUOTED] and Dalandser like this.
  18. Mar 30, 2018 at 9:59 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Can't you pretty easily test those to see if they're bad?
  19. Mar 30, 2018 at 10:02 PM
    Speedytech7
    Yeah you can test the heater circuit with a headlight and some clip leads, you can halfway test it with just a normal test lamp (doesn't draw enough current to make sure the circuit can pass the amperage necessary though). You can test the sensor with a multimeter but there are some stipulations to that and I forget what they are.
  20. Mar 30, 2018 at 10:09 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Yeah I think I'm gonna heat them up them use a candle to try to get candle wax in the threads, ole pipe fitters trick.
    Dalandser[QUOTED] likes this.
