  1. Apr 5, 2018 at 6:16 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Better to have a little too much tool than not quite enough!
    malburg114[QUOTED] and Dalandser like this.
  2. Apr 5, 2018 at 6:17 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Installed my bedside decals finally. Thanks @CBoy808
  3. Apr 5, 2018 at 6:19 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Now where have I heard that before? :oops:
    mechanicjon and Keep on Truckin' like this.
  4. Apr 5, 2018 at 6:23 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Right on. they still had issues with boost?
  5. Apr 5, 2018 at 6:23 AM
    flenniken7
    flenniken7 Wishin' I was Fishin'
    OKC
    2000 4x4 tacoma 1996 Z71 DD 248K, 2012 tahoe
    5100's 285' to come 4" lift 33's on hoe
    top one $1500 - $2000 bottom $400 - $700.... IMO
  6. Apr 5, 2018 at 6:29 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    OEM
  7. Apr 5, 2018 at 6:30 AM
    Dan8906
    Daniel
    Concord, California
    No I never fully bedded them.
  8. Apr 5, 2018 at 6:42 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Not likely to be many 1st gens, almost to the end now.
  9. Apr 5, 2018 at 6:46 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Happy wife, happy life!!*
    *also applies to girlfriends, fiances, etc
  10. Apr 5, 2018 at 6:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Id take it. Even if something is wrong with it parts will be readily available.
    This^^
    Same problems as usual. Pinging in high gears under load at lower rpm. there is no doubt the later years were better prepared for it.
  11. Apr 5, 2018 at 7:01 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    whats the point in having two? You can always size down with an adapter to a 3/8th. and to have twice the torque...really helpful when you have stubborn axle nuts. If its on a smaller bolt...just be a bit more gentle because obviously you can give it too much brunt and destroy the bolt. if you were going to buy two, id buy the high torque impact and a right angle impact. But for just a regular carry with you impact gun, better to have more torque and not use it than less torque and wish you had more
  12. Apr 5, 2018 at 7:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    smaller gun fits more places..
  13. Apr 5, 2018 at 7:10 AM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    I want something like the top one but everyone is quoting me 2500 to 3k. Figure the bottom one is a good starting point the guy wants 250 for it
  14. Apr 5, 2018 at 7:15 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    So with a manual transmission is pinging still an issue since you can just downshift to a lower gear raising the RPM?
  15. Apr 5, 2018 at 7:18 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The top one looks really nice and to me, nothing about it looks expense until you get to all the tubing. But I don’t know a lot about fabrication. Is it made out of aluminum?
  16. Apr 5, 2018 at 7:18 AM
    flenniken7
    OKC
    for sure, its a good place to start and you could always use it like it is and have it modified down the road. $250 sounds like a fair deal to me
  17. Apr 5, 2018 at 7:21 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    But for how marginally smaller it is does it fit that many more places? And if you’re in a cramped enough space, and can’t get an extension to your bolt, how often do you need an impact gun? Like any place I can’t fit the impact gun, a socket is plenty anyway.
    Hence why I said right angle impact if you’re getting both
  18. Apr 5, 2018 at 7:43 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Have you tried any brake cleaner?
  19. Apr 5, 2018 at 7:46 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I thought it is too late to get the frame replacement. Didn't it end last summer?
    what road likes this.
  20. Apr 5, 2018 at 8:07 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Your girlfriend/wife looks like Tomb Raider in this photo lol
    eon_blue[QUOTED] and what road like this.
