  1. Apr 6, 2018 at 9:28 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    probably going to watch a timmy the toolman vid about timing belt swap. see if i feel comfortable on doing it. mechanic hasnt called me back on a price for the job
  2. Apr 6, 2018 at 9:34 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I don't care. I'd want to see it.
    Doesn't show the gasket, the TB gasket, the check valve, the Dynamic tensioner, the bracket for the tensioner, not even the pulley for the blower is on it.
    Digiratus and SnowroxKT like this.
  3. Apr 6, 2018 at 9:44 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    i was thinking the same thing. as tempting as it is i want to see everything it comes with
  4. Apr 6, 2018 at 10:52 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    No, upper is longer.
  5. Apr 6, 2018 at 12:09 PM
    flenniken7
    flenniken7 Wishin' I was Fishin'
    OKC
    2000 4x4 tacoma 1996 Z71 DD 248K, 2012 tahoe
    5100's 285' to come 4" lift 33's on hoe
    these came in today.. Next stop the tire shop to get my 285s mounted
  6. Apr 6, 2018 at 12:15 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    1 inch spacers?
  7. Apr 6, 2018 at 12:21 PM
    flenniken7
    OKC
    1.25
  8. Apr 6, 2018 at 12:48 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You might not want to use red loctite on the wheel studs for the spacers, if that’s what that’s for. It would make it a real pain to remove them if you need to change a CV on the trail or something like that. Blue loctite is more than enough for those.
    jubei and Speedytech7 like this.
  9. Apr 6, 2018 at 1:28 PM
    flenniken7
    OKC
    Thanks for the heads up bud
    drr[QUOTED] likes this.
  10. Apr 6, 2018 at 1:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have to agree, this was the best I could get 6013 to look and is what I submitted to pass my class in stick welding haha...
    I have no doubt with metal this clean anybody could have done better with 7018 myself included.
    m3bassman[QUOTED] likes this.
  11. Apr 6, 2018 at 1:41 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I think the welding gun is missing the threads for the gas nozzle? Looks complete different from my Lincoln gun.
  12. Apr 6, 2018 at 1:42 PM
    Speedytech7
    That's a dirty gun... but millers have slip fit nozzles so no threads is normal.
    SnowroxKT likes this.
  13. Apr 6, 2018 at 1:45 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Don't think I have to replacing the lining or anything?
  14. Apr 6, 2018 at 1:46 PM
    Speedytech7
    Won't know till you weld with it a bit, a dirty or kinked lining will cause your wire to spool out inconsistently and occasionally jam.
  15. Apr 6, 2018 at 1:51 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That happened a lot when I was testing it. It jammed a lot.
  16. Apr 6, 2018 at 1:56 PM
    Speedytech7
    Liner is probably kinked or has some buildup. I'd check your roller tension, spool tension, and consumable size before you go buying a new liner though
  17. Apr 6, 2018 at 1:56 PM
    Phessor
    Phessor Well-Known Member
    I got the compressor mounted, front air fitting installed and all of the plumbing done.
    I mounted the air filter behind the driver side rear tail light.
    All I have left is the wiring, still waiting on the switch.
    Dirty Harry, Poncate, Cid and 7 others like this.
  18. Apr 6, 2018 at 2:37 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Maiden Voyage :rofl::anonymous:F52ED649-6336-482D-A579-C0E1105A3726.jpg
  19. Apr 6, 2018 at 2:38 PM
    Speedytech7
    Any luck with adjusting it, if the drive roller isn't the right size for the wire it'll stop a lot cause it is slipping. Make sure you have roughly 3/8" wire sticking out the tip too.
  20. Apr 6, 2018 at 2:39 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That leader hose gets pretty hot on my viair. I'd be cautious about those wires ziptied to it.
    Speedytech7 likes this.
