  1. Apr 10, 2018 at 8:36 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Not bad. Just make sure you mark, drill and tap it correctly. I made a few mistakes not making sure I drilled it at the right angle and ended up drilling out one of the taps and putting a nut and washer on the inside of the frame.
  2. Apr 10, 2018 at 8:41 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah this too :D but I just hung it from the cam bolts. My truck was already torn apart when I did mine.
  3. Apr 10, 2018 at 8:51 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Ha I figured that much
    Gotcha, well I'll take my time for sure whenever this happens, hopefully sooner than later ha
    SilverGhost[QUOTED] likes this.
  4. Apr 10, 2018 at 9:14 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am beginning to wonder whether 600# king coils are adequate for a 1st gen hanging any weight over a stock configuration off the front. Both you and @eon_blue are running them with some added weight and having some issues.
    Are you still on King's default valving configuration? I think he is if I am not mistaken.
  5. Apr 10, 2018 at 9:34 AM
    eon_blue
    Azusa, CA
    I think he just means that it's not sufficient enough, he may be right but the only extra weight I have up front is a 3/16" steel skid...no bumper, yet. The stock spring configuration was what...500#? I would imagine 600 should be enough but maybe I'm wrong, or maybe they do just need to be valved a little differently.
    Digiratus likes this.
  6. Apr 10, 2018 at 9:38 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    nWCB4u4lIMfKyA0-Qliql0aVqQwJi0na2V6LSzZD_b8a7231d249d994dab99141cfeab7c562d98e210.jpg
    Filled the air box with a bit of muddy water...:anonymous::D
    Snorkel ordered on the group buy :bananadance:
  7. Apr 10, 2018 at 9:43 AM
    Digiratus
    Roaming the PNW
    The RedHead
    o_O I am saying exactly what I wrote. I am wondering if 600# king coils are adequate for a 1st gens running extra weight. Are you suggesting that I need to measure whether the King's rating is accurate?
    This.
  8. Apr 10, 2018 at 10:05 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    mm i doubt it.
    OME coils are only 550 for 882s and 590 for 883s. Granted, I do NOT know how much or in any they get precompressed to load them up more. Which I know they are precompressed a bit i just don't know how much exactly.
    And i'll find out as im about to put a plate bumper on 600s. Though i can't imagine that is the problem. It just sounds like more valving in needed as extra weight changes the valving requirements. If you have too much weight it will over power the shim stack if you don't have a stiff enough one in.
    Id still wager stiffening up the compression a bit and slowing the rebound would help.
    Digiratus[QUOTED] likes this.
  9. Apr 10, 2018 at 10:37 AM
    tony2018
    tony2018 Well-Known Member
    harness ordered...money drained.
  10. Apr 10, 2018 at 10:39 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I would agree with this assessment that extra weight shows how inadequate the default valving is that King is using.
    I do not think the fix for this will be found with bump stops. And certainly not with hydros as some have suggested.
  11. Apr 10, 2018 at 10:43 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Who was it that did their rear shock relocation recently? I want to see their set up as my Bilstein 10" 5125 (stock location) are spewing oil. Thanks.
    snowboard704 likes this.
  12. Apr 10, 2018 at 10:45 AM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    I’m not sure what spring rate to step up to. I need to figure out a better shim stack/valving also because as is this setup is clearly not working.
  13. Apr 10, 2018 at 11:02 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That'd be me, hope this helps
    [HOW-TO] - 1st Gen Tacoma Rear Shock Relocate
    jubei, Prayn4surf and quetzal[QUOTED] like this.
  14. Apr 10, 2018 at 11:07 AM
    quetzal
    Mario
    Long Beach, CA
    If you don't mind, I am going to pick your brain either thru the link and/or PM. I'm a total noob when it comes to suspension/shocks etc. :cool:
  15. Apr 10, 2018 at 11:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah its also why nitrochargers work because they are valved very stiff and ride like hell with no extra weight.
    Bumps would not be the solution here.
    Talk to DSM. If you bought them from them I think they do a revalving for free first time..not sure on that though. But just talk to them about it and they will tweak it. Or DIY.
    @TMFF also is a good option.
    jubei likes this.
  16. Apr 10, 2018 at 11:08 AM
    Speedytech7
    No prob, happy to help as much as I can
  17. Apr 10, 2018 at 11:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    You might consider monte's suggestion VVV to rebuild the shocks rework the shim stack when you do.
    I am running 700# coils on my Kings and don't normally get into the stock bumps, even when getting aggressive. However, I don't think those are the way to go for most, especially with less weight and e-rated tires with their stiffer sidewalls.
    The 700s work well for me and the off road performance is awesome (stock valving) but it is likely due to all of the weight I am carrying. Plate bumper with winch, and full budbuilt skids and sliders on an extracab with a v6.
    jubei likes this.
  18. Apr 10, 2018 at 11:15 AM
    Speedytech7
    The perfect storm of conditions haha. I too believe that a revalve will help him, I didn't change my spring rate at all but my Icons are completely different beasts after a rebuild and revalve for my uses. 650s work nicely in my case.
  19. Apr 10, 2018 at 11:19 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I am a little leery of comparing what you have to his King issues, The Icon 13" coils are a different beast compared to King 14"ers. Then there is that whole progressive/digressive thing. Just sayin...
  20. Apr 10, 2018 at 11:19 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I wonder if this is the same for icon coil overs
