  1. Apr 11, 2018 at 10:44 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Truck seems to be driving and idling fine, and a cursory inspection of hoses under the hood - I don't see anything cracked or loose.
  2. Apr 11, 2018 at 10:49 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sorry dude that's not always an easy one. All it means is you're running lean to the point where your computer cannot reasonably compensate for it. You need to check for vacuum leaks after the MAF, buy a can of something flammable (starting fluid or the like) and be very careful not to catch yourself on fire while spraying around vacuum lines and joints for the intake, when the engine idles up you know you've hit the leak with your can of fluid. Listen for hissing too
    This can also be caused by the MAF if it happens to be reading erroneously, the extra air it isn't metering (but is passing over it, IE not pirate air) will basically be a mystery to the comp and all it can do is add more fuel if it doesn't have sufficient evidence like improper impedance to throw a MAF code directly
  3. Apr 11, 2018 at 11:00 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    How serious? Should I abort trip? (and thanks guys, for all the responses)
  4. Apr 11, 2018 at 11:02 AM
    Speedytech7
    It can range, could be something simple like pirate air from a broken hose, maybe an injector not keeping up with the others, leaking seal in the intake tract, bad or dirty MAF. I cannot tell you with any certainty without seeing it myself. Do you have a scan gauge or ultragauge? If so what are your Fuel Trims?
  5. Apr 11, 2018 at 11:10 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    fuck no.
    You'll be fine to wait.
  6. Apr 11, 2018 at 11:11 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Long-term fuel trim Bank 1 - 32%
    Short-term fuel trim Bank 1 - 0 to -1%
    Long-term fuel trim Bank 3 - 41.4%
    Short-term fuel trim Bank 3 - 7%
    Those what you asking for?
  7. Apr 11, 2018 at 11:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn you're dumping fuel. You mpg will suck this trip haha
  8. Apr 11, 2018 at 11:14 AM
    Speedytech7
    So just a rapid heads up that code is 100% coming back with trims that high. But it is affecting both banks so odds are high it is MAF or vacuum leak related.
  9. Apr 11, 2018 at 11:14 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Where should I be?
  10. Apr 11, 2018 at 11:14 AM
    Speedytech7
    0 to 5%
  11. Apr 11, 2018 at 11:16 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    LT trims should be around +/- 5-10% ideally.
    Your dumping in 41% more fuel than normal over a long period of time.(can't remember the time used for measurement).
    Definitely a vacuum leak. I wouldn't think your MAF would be bad with your mileage.
  12. Apr 11, 2018 at 11:19 AM
    Speedytech7
    @turbodb
    This is a wild guess and probably wrong but worth a look, you have one of those early ADD systems with the vacuum tank that basically resides in the front of the drivers front wheel well, you should make sure that is all intact.
  13. Apr 11, 2018 at 11:23 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Okay I will check that as soon as I stop for gas, which won't be long. Hahahaha. If it is a vacuum leak, on a 2500 mile trip is the only damage I'm doing to my wallet? If it is I'm going to keep going, if it isn't I can turn around now.
  14. Apr 11, 2018 at 11:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    pretty much just a wallet kicker.
    You should be fine if its not a big obvious leak.
    other place to check is the back side of the intake on the driver side. Can be some connections buried back there depending on the year of truck.
  15. Apr 11, 2018 at 11:25 AM
    Speedytech7
    For the most part it'll just run uber rich and that may be less than kind to your CAT and O2 sensors. But it shouldn't hurt anything in the engine unless the leak is bad enough that it cannot throw enough fuel in to keep it rich. Sounds like a pretty gross leak by those trims though
  16. Apr 11, 2018 at 11:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    considering the amount of fuel its pouring in, you'd think it would be an obvious find..
  17. Apr 11, 2018 at 11:27 AM
    Speedytech7
    Yeah, I was thinking brake booster diaphragm or that weird box looking thing you V6 guys have on the backside of your intake tract.
  18. Apr 11, 2018 at 11:29 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    booster could be it. That would suck. I have a spare though if you need that Dan.
    Box thing..if your talking about what I think you are, thats on later models and is a vent from the cam cover.
    It could be something with the EVAP box too as that thing has plenty of vac connections
  19. Apr 11, 2018 at 11:34 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Can I spray MAF cleaner or throttle body cleaner around in there? those are the things I have on hand. And I guess some WD-40.
  20. Apr 11, 2018 at 11:35 AM
    Speedytech7
    As long as they're decently flammable, I know WD-40 is kinda flammable but I don't know if either of the cleaners are. Any gas station that sells diesel should have starting fluid.
