  1. Apr 12, 2018 at 12:14 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    :boom:
  2. Apr 12, 2018 at 12:17 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  3. Apr 12, 2018 at 12:19 PM
    eon_blue
    Azusa, CA
    haha I was going to say the same thing but then realized I'm at work, didn't want to search for the news article on his arrest given what I'd need to type in the search bar...
    Prayn4surf likes this.
  4. Apr 12, 2018 at 12:19 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Probably way more than I know about.
  5. Apr 12, 2018 at 12:27 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  6. Apr 12, 2018 at 12:31 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Bet he confirmed the reasons why you lube things.
    BYJOSHCOOK[QUOTED] likes this.
  7. Apr 12, 2018 at 12:44 PM
    Prayn4surf
    Socal
    :facepalm:
  8. Apr 12, 2018 at 1:31 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    This makes me more excited than it should...
    Also I think I may have found the solution to my pulley problem. Looks like a lower idler pulley from a 1GR-FE is exactly what I need. Gonna go to Orielly to check one out.
  9. Apr 12, 2018 at 2:16 PM
    Speedytech7
    It is a little smaller but a 2010 Tacoma V6 lower pulley will bolt in place of the 4cyl TRD supercharger pulley as a replacement.
  10. Apr 12, 2018 at 2:19 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Just an idler or a static tensioner?
  11. Apr 12, 2018 at 2:22 PM
    Speedytech7
    It's an idler pulley, no one makes a dynamic tensioner for this application. The tensioner pulley is the one for my power steering.
    drr likes this.
  12. Apr 12, 2018 at 2:26 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    So while I was walking to my truck I noticed the driver side rear end is leaning a little bit, what could be the cause?
    FLBAdrian likes this.
  13. Apr 12, 2018 at 2:27 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    All the heavy stuff's on that side, gas tank, battery, you.
  14. Apr 12, 2018 at 2:28 PM
    Speedytech7
    You calling me heavy?!
  15. Apr 12, 2018 at 2:29 PM
    JKO1998
    Utah
    You use to be in a colder climate, so I'm sure it kept you warm at one point.
    Speedytech7[QUOTED] likes this.
  16. Apr 12, 2018 at 2:29 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Get a fat girlfriend it will even out.
  17. Apr 12, 2018 at 2:30 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Any drawbacks of using bolt-on sliders vs. weld-on?
  18. Apr 12, 2018 at 2:41 PM
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    have to drill into frame
  19. Apr 12, 2018 at 2:42 PM
    SwampYota
    Jon
    Floor mats
    Sure, but is that a problem if you’re in a non-rust belt state?
  20. Apr 12, 2018 at 2:43 PM
    Speedytech7
    Not really but also why bother. Weld on is arguably easier unless you own a Magdrill
