  1. Apr 12, 2018 at 4:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Looks good, saw it on Facebook and made a bet with myself it was on here too haha, I won that bet.
    Teke[QUOTED] likes this.
  2. Apr 12, 2018 at 4:39 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Ahhh the taco lean. I'm getting some OME trim packers to fix that when I do my 4x4 swap.
    tymeson[QUOTED] likes this.
  3. Apr 12, 2018 at 4:44 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Haha yeah the guy who sold me the door wanted to see the end result so I posted it and tagged him.
    Now I just need to get my bumper and bed rack powdercoated so I can throw them on
    JKO1998[QUOTED] likes this.
  4. Apr 12, 2018 at 4:45 PM
    JKO1998
    Utah
    Trucks are never ending projects, as everyone knows.
    tymeson and Teke[QUOTED] like this.
  5. Apr 12, 2018 at 4:47 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    This spacer right here? I've only had the lift on about 2 months
    2002Tacoma4x4 likes this.
  6. Apr 12, 2018 at 4:48 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    For sure. It’s either fixing something or breaking something it seems like over here. My buddy just replaced every pulley, the alternator and water pump trying to track down a squealing bearing and then today his caliper seized up o_O
  7. Apr 12, 2018 at 4:50 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    I thinks sometimes it's more of what can I do to it this weekend :D
  8. Apr 12, 2018 at 5:02 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    No you don't, if you build them yourself. Just space the brake line off the frame a bit with some washers.I had to get a little creative with some of the mounts on the drivers side with the ebrake cable in the way, but its doable. 100% no drill, no weld rock sliders.0113181519a.jpg 0116180933a.jpg
  9. Apr 12, 2018 at 5:08 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    My driver side just broke today. Warmer temps so I opened the side window and the dang thing broke. Thankfully I have a replacement from when I did the passenger side.
    m3bassman likes this.
  10. Apr 12, 2018 at 5:22 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    How are they attached?
  11. Apr 12, 2018 at 5:31 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Those mounts slip over the frame, then bolts go across the top. "Clamp on" if you will. I didnt notice the frame being squeezed too hard or crushed, as the bolts dont need to be tightened with an impact wrench or anything. I just used my normal sized 9/16" wrench and tightened them down as tight as I could manage with some blue loctite. It was a little frustrating to figure out spots for the drivers side mounts but it's doable.
    SwampYota[QUOTED] likes this.
  12. Apr 12, 2018 at 5:32 PM
    1997tacomav6
    Denver
  13. Apr 12, 2018 at 5:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    1997tacomav6[QUOTED] likes this.
  14. Apr 12, 2018 at 5:37 PM
    1997tacomav6
    Denver
    Look at the swap thread I posted, mine is for a 5speed, if it’s auto the shroud will hang lower. You probably could use the shroud type I have with more trimming for the trans lines and it would not
    hang so low
  15. Apr 12, 2018 at 5:38 PM
    1997tacomav6
    Denver
    SwampYota likes this.
  16. Apr 12, 2018 at 5:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn. I ordered the wrong one then if you still have to trim. Oh well. Filament isn't that far off so should be easy to make work.
    Kinda seems like if you got the shortest shroud it wouldn't fit the v6 fan at all.
  17. Apr 12, 2018 at 5:41 PM
    1997tacomav6
    Denver
    My shroud is 1997,5 speed, fits almost perfectly with a few cuts
    Blackdawg[QUOTED] likes this.
  18. Apr 12, 2018 at 5:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah I ordered that size of shroud vs cutting up my auto one.
    Looks like it'll fit good and just needs a few holes drilled to clear things.
  19. Apr 12, 2018 at 5:46 PM
    1997tacomav6
    Denver
    I swear after you get the Champion radiator and see how it’s built compared to the stock radiator, the stock radiator will look and feel like a piece of junk.
  20. Apr 12, 2018 at 5:51 PM
    Rockymtntacoma
    Rockymtntacoma Well-Known Member
    Jake
    SLc,UT
    03 ext cab 4x4 v6 5 speed sr5
    Dual cases, triple sticks, 4.88’s, Harrop e-locked f/r, 35’s, boosted
    61DC6A77-10C7-45E7-94EA-949DBCCFD0F0.jpg D1501C8C-1AF4-40C3-ADA6-990D5F57F423.jpg 2217B4D5-DB57-472E-B438-07DB4D62B82F.jpg Finished my bumper, I still haven’t decided if I’m going to add a light hoop
    turbodb, tymeson, nw_chris and 15 others like this.
