  1. Apr 22, 2018 at 4:47 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Do tell..
    Lol that's some shitty welding too
  2. Apr 22, 2018 at 4:52 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Nearly done with my project
  3. Apr 22, 2018 at 4:53 PM
    kmac1701
    kmac1701 Well-Known Member
    Kevin
    Boston
    1998 Tan Tacoma PreRunner Ext Cab v6 3.4L
  4. Apr 22, 2018 at 4:55 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    sounds like you may have found your issue.
  5. Apr 22, 2018 at 4:56 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not much to tell, SpeedHut is a company that will pretty much make you any gauge you request. They even have templates for you to edit in PS or hand draw what you want. I custom mixed one of theirs that I liked the look of already and had them change the bezel, font, and add a TRD logo. Pretty simple, they're based out of and build the gauges in Orem, UT so you can talk to a real English speaking person about what you want.
    Blackdawg[QUOTED] and lukester78 like this.
  6. Apr 22, 2018 at 4:59 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    I bought the same ones. Had to trim the lip near the outer seat track, kept kicking it while getting in...became too annoying.
    Area51Runner[QUOTED] likes this.
  7. Apr 22, 2018 at 5:02 PM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Can I get some more info on your platform? I'm in the early stages of building mine, would love to compare designs
  8. Apr 22, 2018 at 5:05 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    +1 to this id like to build another
  9. Apr 22, 2018 at 5:12 PM
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    What wheels are you running? Can't tell if they're steelies or alloy
  10. Apr 22, 2018 at 5:13 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    I cut a square hole n folded it up like a door, it was big enough to disconnect the lines n n pull the pump n sending unit out. When I was done I just closed the door n put a few tack welds n silicone to seal it.
  11. Apr 22, 2018 at 5:13 PM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Is this boot being ripped on the bpv an issue ? Just noticed it after a few years
  12. Apr 22, 2018 at 5:14 PM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Because race truck
  13. Apr 22, 2018 at 5:24 PM
    buckmaster243
    Buck
    Washington
    Level 8 Trackers from Discount Tire. They are aluminium
    Here’s a better picture of them from when they were on my runner.
    SwampYota and Jebediah[QUOTED] like this.
  14. Apr 22, 2018 at 5:35 PM
    Speedytech7
    When your gauge pod game is on point...
    SwampYota, BartMaster1234 and tymeson like this.
  15. Apr 22, 2018 at 5:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah
  16. Apr 22, 2018 at 5:49 PM
    buckmaster243
    Buck
    Washington
    Your missing some zip ties! White ones of course wouldn’t want black ones that would blend into the gauge better. That things sweet!
  17. Apr 22, 2018 at 5:59 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Only 2 complaints I have about my speedhut gauges. 1-the backlighting at night whines faintly, can get annoying. 2-on cold starts the boost gauge usually reads .5psi. Only zeroes out on warm starts.
  18. Apr 22, 2018 at 6:02 PM
    Speedytech7
    Yeah I know the EL wire drivers can make some noise, basically mini high frequency flourescent ballasts. Strange about the cold start measures but I know mine opens the throttle plate enough for the SC to make a little boost on a cold start so it might be accurate.
  19. Apr 22, 2018 at 6:05 PM
    smmarine
    Melbourne FL
    Mine does it before the truck even starts. I turn the key and allow my gauges to zero before starting.
    Speedytech7[QUOTED] likes this.
  20. Apr 22, 2018 at 6:05 PM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Replaced front and rear Ujoints with Forged Moog ones. Problem solved:thumbsup:
