  1. Apr 22, 2018 at 10:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It has a programming feature like the ScanGauge but I don't think anyone has figured out how to make it read trans temps on a Taco. I don't have an auto anyway. I got it because it has the superior form factor and screen, it also has all standard OBDII pids and some Mode 6 pids built in. The ScanGauge requires you to apparently program most of that yourself but it is capable of reading Taco trans temps (on later models 98-04).
    MedicMutt and jubei like this.
  2. Apr 22, 2018 at 11:28 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Been noticing a 'clunkiness' and more bumps than normal since yesterday and started to worry maybe I botched something with the rack bushings / tie rod change I completed last week.
    On a whim, just now decided to check tire pressure since its been sitting all evening and tires are cold (I had just taken in to the local Costco Tire Center for a balance/rotation a couple of days ago). Damn azzhat tech - front was at 38psi and the rear was at 37! For those curious, I'm riding on 265/70/16 Bridgestone Revo II Duelers. Decent tire and happy with it - just not with 38psi.
    I had specifically asked what they usually inflate to on this tire/application and the counter guy said 35. I requested 33psi since that usually produces the best results for me. No wonder I was feeling every bump and hairline crack in the road. That really pisses me off. Now I have to call into question if the tech bothered to balance the tires at all or properly. :mad::mad::mad::mad::mad::mad::mad::mad::mad: Guess I'll be going to another Costco to have them re-balance. Thx Costco Tech
    TacoYankee likes this.
  3. Apr 22, 2018 at 11:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Anyone know the rear hose that comes from the driver side rear head(valve cover) that comes over to right in front of the Throttle body for an 01-04?
  4. Apr 22, 2018 at 11:46 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    just the vent isn't it.
  5. Apr 22, 2018 at 11:46 PM
    Speedytech7
    You talking about the engine breather hose? Not the PCV one but the other one
  6. Apr 22, 2018 at 11:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    correct. The source of air for the PCV system.
    I think I found it. 12262-62060 just can't quite confirm it..Mine spit at the end.
  7. Apr 22, 2018 at 11:49 PM
    Speedytech7
    Oh yeah that happened to the one on my 4cyl too, but luckily there was extra so I cut it and slipped on further.
  8. Apr 22, 2018 at 11:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    mine is very different from the earlier versions. Its shaped a lot. Not just a straight tube.
    and of course no one has it in stock..
  9. Apr 23, 2018 at 12:00 AM
    Speedytech7
    Huh, maybe make sure it's the right number in this guide... The naming for these parts is criptic at best.
  10. Apr 23, 2018 at 12:15 AM
    ZrowGz
    ZrowGz I'm a n00b.
    SLC, UT
    97 4x4 LT/Cantilever
    Just bought one of these today for $200: https://www.rigidindustries.com/led-lighting/240043
    And ordered the rear shocks from ADS with external resi and clicker adjusts. Now do I get custom deaver springs so I can carry my weight or go with Dakar... Kinda thinking Dakar would do just fine eh?
  11. Apr 23, 2018 at 12:16 AM
    Speedytech7
    You ordered shocks before leafs, how do you know how much length and valving you'll need?
    malburg114 likes this.
  12. Apr 23, 2018 at 12:41 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Blackdawg[QUOTED] likes this.
  13. Apr 23, 2018 at 4:21 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    Saw that website, what’s the difference between the “stock” versus “lifted” shocks? $200 difference is for what’s? Thanks
  14. Apr 23, 2018 at 7:42 AM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    So do you think the Previa SC would have added even more power? I thought you were saying it makes a couple more psi or something over the standard 2.7 sc.
  15. Apr 23, 2018 at 7:54 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Went up to AOP in TN this past weekend. Hit some gnarly stuff and got a nice little dent that can be popped out. My muffler bracket came unbolted too so I'm straight piping it for right now. Full send engaged
    UssMoGn, Prayn4surf, jubei and 6 others like this.
  16. Apr 23, 2018 at 7:55 AM
    tony2018
    tony2018 Well-Known Member
    GAH! Bringing back horrible memories.
  17. Apr 23, 2018 at 7:57 AM
    tony2018
    When turning full lock, left to right, do your tires hit it?
  18. Apr 23, 2018 at 8:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    eh wasn't too bad once I had a couple more tools and time. Got it all buttoned up last night. Just have to do the new radiator and tranny cooler, flush the tranny. Then bolt on the new fender, fix the head lights and flare. Add new bumper and get new tires mounted an alignment and Im back in business.
  19. Apr 23, 2018 at 9:35 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Shipped?
  20. Apr 23, 2018 at 10:28 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Been trying to install some used bully bar brand running boards on my truck today. I know they're.not popular here, but I need for my mom to be able to get in and out of the truck. I can't find instructions online andybody got any ideas? :help:
