  1. Apr 23, 2018 at 2:59 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I had someone try to buy my old A340E because the one on his Tundra overheated when he crimped a line going to the aftermarket transmission cooler he installed. Said the planetary gears were cooked after a couple miles.
    Output shaft wasn’t long enough on the Tacoma A340E, so he didn’t pick it up.
  2. Apr 23, 2018 at 3:06 PM
    shmabs
    shmabs Well-Known Member
    I'm currently running Dakar's and stock shackles on the rear of my 2003 double cab, I think I ended up with about 2.5 inches of lift. I laid under my truck for a while the other night measuring for shocks. I've been doing some research on which shocks would fit under there, it looks like a bilstein 7100 short body in a 10 inch travel variety would work well for me. They're 14.29 inches collapsed, and with my extended bump stops, that 'should' work. Just some food for thought.
    Edit: The 7100's come with heims, in past applications i have removed the heim and replaced it with an hour glass poly bushing. That was a while back, I'm not sure if they have changed lately. PN: AK7110SB05 is what I was looking at
    Speedytech7[QUOTED] likes this.
  3. Apr 23, 2018 at 3:15 PM
    Oldred92
    Oldred92 Well-Known Member
    Austin
    Boston, MA
    2003 White SR5 Double Cab Tacoma TRD 4x4
    Front Suspension: 882 w/ Nitrocharger Sport Rear Suspension: Dakar HD w/ Nitrocharger Sport ARB Front Bumper w/ winch Extruded aluminum roof rack Tires: Discoverer ST Maxx LT255/85/R16 on Tacoma Steelies Additional Fuse Box and Upgraded Wiring
    Finally pulled the trigger on an ARB front bumper!
    Install was simple once I tossed the ARB supplied instructions.
    I could not be happier with the results. I still need to do some final adjustments to get the gaps just right.
    01x4, TacoYankee, BYJOSHCOOK and 7 others like this.
  4. Apr 23, 2018 at 3:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    a 15'' compressed shock is about a long as you can go with stock locations. Though i believe the 7100 that is a short body and is around 15'' compressed is actually a 12'' shock. That said you'll bottom the sock out with a taller bump which it sounds like you have so should be good.
    If you want to use the stock mounts you'll still have to swap the heims for the bushings on the 7100s.
    Prayn4surf and shmabs[QUOTED] like this.
  5. Apr 23, 2018 at 3:37 PM
    shmabs
    You are correct, I had my PN's crossed. 14.29 collapsed for the 10 inch travel short body, 16.1 collapsed for the 12 inch travel short body.
    Blackdawg[QUOTED] likes this.
  6. Apr 23, 2018 at 3:38 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Thanks guys I was just curious. I plan on getting a little cargo trailer to pull to hunting camp and stuff so figured a little extra monitoring could help.
  7. Apr 23, 2018 at 3:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    the 10'' will work a treat. The 12s fit. I know of several that have run them just need to get your bumps right. So kind of stinks as you loose up travel unless you have a lot of rear lift. Like 4''+
  8. Apr 23, 2018 at 3:40 PM
    shmabs
    Yea, that sounds right. Given the uses of my truck I'm looking for a near 50/50 split in up/down travel.
  9. Apr 23, 2018 at 3:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well you might be a tad low on lift for 10s still. I ran 10s with 4.5" of lift. I have 8s now for around 1.5-2''.
    If you can flex it out to really measure before blowing the money that would be the best idea.
    shmabs[QUOTED] likes this.
  10. Apr 23, 2018 at 5:00 PM
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
    Finally got around to installing the winch into the ARB winch bumper. After all, why have a winch bumper without a winch? I bought the truck with the bumper on it and now it has a winch to fill the hole!
    I had to relocate the solenoid box and chose a spot on the passenger side engine compartment. I like the way this turned out. Now to go pull something!
    edit update: I just ordered a wireless remote for the winch. It was a whopping $16.00! I guess I will find out how long it lasts. The name brand ones are in the hundreds.
  11. Apr 23, 2018 at 5:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you might think about adding in cab controls or extending the plug for the remote so you can operate the winch with the hood down.
  12. Apr 23, 2018 at 5:05 PM
    toyrunner
    Danny
    Pasadena, Ca.
    I have a remote that will reach to the drivers seat for self extraction efforts, if needed! Thinking of getting the wireless remote at a later date.
  13. Apr 23, 2018 at 6:44 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Got an oil change today from a local Amsoil dealer. My engine sounds brand new! Total game changer!!!
    SwampYota likes this.
  14. Apr 23, 2018 at 6:47 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Whatever...
    4drtaco03, devinzz1 and FLBAdrian like this.
  15. Apr 23, 2018 at 6:48 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I'm itching to get parts coated and parts ordered but I plan on proposing so everything seems to be on hold. She puts up with me constantly wrenching and buying parts so she's a keeper for sure.
    TacoVio, m3bassman and buckmaster243 like this.
  16. Apr 23, 2018 at 7:06 PM
    buckmaster243
    Buck
    Washington
    Congrats man. Say goodbye to spending money on the truck until after the honeymoon! Ask me how I know
    koditten and eon_blue like this.
  17. Apr 23, 2018 at 7:10 PM
    eon_blue
    Azusa, CA
    Yeah my girl and I got engaged in January...still trying to lock down a location but once we do we want to get married pretty quick, before the end of the year. I'm buying truck parts like crazy now even though it hurts because I know I won't be able to as easily real quick. We want to try for a kid not too long after the wedding too so I'll definitely be tight on truck spending lol.
    She loves to wheel with me and is interested in the things I do to my truck so that helps.
    mechanicjon and Prayn4surf like this.
  18. Apr 23, 2018 at 7:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Where do I find one of these?
  19. Apr 23, 2018 at 7:16 PM
    koditten
    Kirk
    Central Michigan
    Think about eloping. Best 1st decision we we ever made.
    100 percent of the couple's that eloped, never felt sorry about having eloped.
    50 percent of the couple's that had big weddings wished they had just eloped.
    Just go on vacation and come back married.
  20. Apr 23, 2018 at 7:18 PM
    eon_blue
    Azusa, CA
    Believe me, if it were up to me that's how we would do it. Unfortunately that's her call though lol, and she wants a wedding.
    Fortunately, we are making it a small wedding at a state park (Redwood forest, cheap permits) because we have to finance it ourselves.
