  1. Apr 23, 2018 at 9:38 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Would running Toyota’s ATF make any negligible difference?
  2. Apr 23, 2018 at 9:39 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You'd notice your wallet getting lighter at an increased rate. ATF has standards if you match them properly there isn't much to go wrong
  3. Apr 23, 2018 at 9:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Hahaha yeah that would make the most sense. When I get the time I’ll put in some synthetic stuff.
    I put in a brand new OEM filter when I did the swap. Think I’m okay for now or should I replace the filter again?
  4. Apr 23, 2018 at 9:41 PM
    Speedytech7
    You won't need to change it unless you take it off. They're good for a very long time.
  5. Apr 23, 2018 at 9:45 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Thought so. Speaking of filters... I really should replace that fuel filter. Still the original one on the truck.
    One thing I wish we had was a cabin air filter. The a/c on this truck has such a distinct smell to it, it's not bad but it has a smell to it. If I had to describe it, it would be 1970's Cadillac interior. Weird - I know. Nice thing about my E320 is it has an activated charcoal filter. When you have the air set to exterior intake and you're driving behind a Diesel truck it stinks in the cabin. You hit the button and the air smells nice and fresh after a couple seconds.
  6. Apr 23, 2018 at 9:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is like buying a diamond ring before you have a girlfriend...
    Where is your battery tie down? You're not running it this way are you?
  7. Apr 23, 2018 at 9:50 PM
    Speedytech7
    Fuel filter isn't as bad as everyone makes it out to be. I changed mine twice without removing the intake. If you have wobble or ujoint extensions you can do it in about 45mins.
    BikerinBlak909 likes this.
  8. Apr 23, 2018 at 9:51 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    My friend has this early 80's Mustang GT and he had me replace the battery in it. It had this ingenious battery hold down that wasn't as obtrusive as ours. There was a small wedge that looked like a door stop than you put in between the battery and the bottom of the battery tray. All you did was clamp it down with a bolt and it held the battery in place really well. Wish we had something like that, I always find the clamp getting in the way when working in the general vicinity of the battery.
  9. Apr 23, 2018 at 9:51 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh it's under the intake? I'm thinking of the 5VZ one - isn't it under the cab on those trucks?
  10. Apr 23, 2018 at 9:54 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    I had to modify the TG crossmember where it wraps around the frame horns. The holes only lined up about 80% so had to notch them out. That plus a lot of bfh time got it on, ended up taking me all afternoon but it’s on there good now.
    I agree with making sure it’s as square as possible before putting the bumper on. Really sucks after fighting with it all afternoon only to realize you have to redo it.....ask me how I know
    49erfan[QUOTED] likes this.
  11. Apr 23, 2018 at 9:54 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
  12. Apr 23, 2018 at 9:56 PM
    Speedytech7
    5vz is on the frame rail under the truck. 2/3RZ is mounted to the engine block under the intake. I like that spot actually it's well protected and the lines are short and well thought out.
    My cruiser is the same way right under the massive 6tube intake manifold where I cannot get to it. This one I don't like as much hah
  13. Apr 23, 2018 at 9:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have seen the clamp style battery holders like you are referring to. And they work well with a battery that has a bottom lip like the yellow top pictured. But it doesn't look like it in this case. I can see the stock plastic tray below the battery.
  14. Apr 23, 2018 at 9:57 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  15. Apr 23, 2018 at 9:58 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah I saw the way the battery mounts in the Tacoma. The little plateau in the engine bay isn't completely flat so it wouldn't work.
  16. Apr 23, 2018 at 9:59 PM
    Speedytech7
    That's because it is from an Altezza... Otherwise known as an IS 300 in America. Lexus doesn't exist in Japan so they are just Toyotas there. This is the non airbag base model steering wheel that has been modified.
  17. Apr 23, 2018 at 10:03 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    How hard would it be to get those DOWN buttons to work on the steering wheel?
  18. Apr 23, 2018 at 10:04 PM
    Speedytech7
    The A340 is used in a supra. Can't be that hard, there's paddle shift kits made for them. Just be wiring to the paddle shift mod at that point.
  19. Apr 23, 2018 at 10:05 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That's all it takes - just the wiring and electronics associated with it? Huh.
  20. Apr 23, 2018 at 10:10 PM
    Speedytech7
    As far as I know. There are a couple companies that make paddle shift mods and stuff for the a340 too.
