  1. Apr 25, 2018 at 6:32 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    You are wasting your time if you think a timing calibrator will help. The timing calibrator can only pull timing and is only good if you have pinging. I believe I’ve read about this on CT and knock sensors seem to be the issue.
    I might be having the same issue. Although I haven’t seen my timing numbers in the single digits. The peak and hold function on my tool reported that it dips that low....
    This shit is about to wear me out. I still have some issues to iron out.
    Long cold starts. Which is Fuel pressure related.
    Sometimes when I’m just driving normally I get very slight surging. I can see my AFRs getting richer then leaner and I can hear the SC get louder and quieter. But it’s not enough to bounce my tachometer. It’s totally random and will go away as soon as I add gas or brake a bit.
    I get pinging in OD most of the time unless ECT power is on. But ECT sucks to drive around on through town.
  2. Apr 25, 2018 at 6:57 AM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
  3. Apr 25, 2018 at 7:02 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    at least your knock sensors aren't buried under the intake manifold.
    Im going to swap mine out to the GM one. Supposed to help a lot.
  4. Apr 25, 2018 at 7:05 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  5. Apr 25, 2018 at 8:36 AM
    Goran
    Goran Well-Known Member
    Jacob
    WA
    2011 Tundra Rock warrior 3" Icon Lift 35s
    How much did you tighten the bushing down? Or does it end up bottoming out with no more movement.
    Thanks!
  6. Apr 25, 2018 at 8:43 AM
    jules04taco
    jules04taco Well-Known Member
    Trish
    PNW
    04 xtra cab 4x4 TRD
    Camburg UCA, Kings, URD short shifter, K & N performance air intake
    No rubbing at all. Not even in reverse.
    tony2018[QUOTED] likes this.
  7. Apr 25, 2018 at 8:49 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It doesn't take much at all to tighten it. I think I moved it less than an eighth or a turn. I basically just went off feel of turning the steering wheel, then check to make sure there still isn't any play at the tire. I drove it today and its a little bit tighter but not anything I'm concerned about.
    It does appear that there is a torque spec of 51 ftlbs for it. I don't think mine is that tight though.
    Screenshot_20180425-094642 by Ryan Heintzelman - Flickr2BBcode
  8. Apr 25, 2018 at 8:52 AM
    jules04taco
    Trish
    PNW
    04 xtra cab 4x4 TRD
    Are you referring to OEM vs. Extended Travel (ET) lengths? If so, OEM is stock spec travel lengths and ET is designed for use with aftermarket UCA. Aftermarket UCA allows for more down travel or droop, and you will need to compensate for this with an ET length shock. How you get you lift depends on several factors, most starting with coil spring weight and setting.
  9. Apr 25, 2018 at 9:01 AM
    Oldred92
    Oldred92 Well-Known Member
    Austin
    Boston, MA
    2003 White SR5 Double Cab Tacoma TRD 4x4
    Front Suspension: 882 w/ Nitrocharger Sport Rear Suspension: Dakar HD w/ Nitrocharger Sport ARB Front Bumper w/ winch Extruded aluminum roof rack Tires: Discoverer ST Maxx LT255/85/R16 on Tacoma Steelies Additional Fuse Box and Upgraded Wiring
    ...Uh oh
  10. Apr 25, 2018 at 9:19 AM
    Goran
    Jacob
    WA
    Alright! Yeah the only reason i ask is i wander all the time on the road and i'm thinking its either my tie rod ends or rack and pinion..
    Already did the Roll pin Mod and it didn't do much but tighten up the steering column.
    All try this next!
    Thanks.
    Reh5108[QUOTED] likes this.
  11. Apr 25, 2018 at 9:22 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    It doesn’t mention anything about LT, all it states is “lifted application “. Thought it was a little odd but guess I can ask DSM and see what they mean.
  12. Apr 25, 2018 at 9:35 AM
    eon_blue
    Azusa, CA
    Yeah that happened to me too, that's a common problem with 1st gens and suspension lifts (inner boots start to pull off the CV). Mine was like that for about a month, kept telling myself I'd get around to fixing it and one day the boot came off completely and slung the grease everywhere. Ended up having to swap out the CV axle for a new one, and lowering my lift down about a half an inch to keep it from happening again. So far so good.
    The angle is a bit too high so even if you fix it, it will likely happen again. Are you running a diff drop? Might be enough to help...it wasn't for me though.
    Or you could try those high angle CV axle boots that someone sells, I think it's RCV or something like that.
  13. Apr 25, 2018 at 9:39 AM
    Skeletoy
    Skeletoy Well-Known Member
    RDM, OR
    Stock 3rd gen, Samurai
    Gave mine an alignment today...$80, along with the tech trying to sell me new control arm bushings, steering rack bushings, etc. Just put it on the rack and get it close pal.
    :goingcrazy:
    Getting some 33x10.50's "on loan" tomorrow, and moving to central Oregon in less than a week.
    Dalandser, TacoYankee and Jebediah like this.
  14. Apr 25, 2018 at 9:39 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I have a 2 day subcription to Toyota TIS website. Need anything?
    Dalandser likes this.
  15. Apr 25, 2018 at 9:40 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not LT. LT is long travel. Thats totally different.
    Extended travel coilover as still "stock spec". The only difference is that most manufactors remove a small spacer that is inside the shock. The spacer limits the travel the shaft does. They do this because the OEM upper ball joint binds at a certain point before the shock could full extend. If you get Uniball UCAs you eliminate this problem and can remove the spacer from the coilover thus giving you a more down travel.
    That is the only difference between an extended travel vs standard travel. Small piece of plastic.
    Long travel so far from stock. 3.5'' wider upper and lower control arms per side and an 8'' long shock.
  16. Apr 25, 2018 at 9:41 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dalandser and Prayn4surf like this.
  17. Apr 25, 2018 at 9:43 AM
    Skeletoy
    RDM, OR
    Can you look up your own VIN to see if any recall work had been done or something?
  18. Apr 25, 2018 at 9:44 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    been doing alot of that already
  19. Apr 25, 2018 at 10:16 AM
    hammertime40
    hammertime40 Member
    Jeff
    1995 Tacoma
    Will you post a pic of that set-up. I just finished my OME lift and want to do the same tire set-up.
  20. Apr 25, 2018 at 10:25 AM
    Skeletoy
    RDM, OR
    yah, i'll update my build when I get em on. They're coming from a family member who's tired of storing a set of brand new tires that he has no vehicle for. so i get to "borrow" them when I move to OR. So excited to move to a new state and explore new stuff.
