  1. Apr 27, 2018 at 11:51 AM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    I like it except for the stupid snorkel and think it'll look better if they actually lower it like they are talking about. Not a fan of that crossmember though.. Would suck to have to undo everything just to drop the tcase or tranny.
  2. Apr 27, 2018 at 11:53 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have to agree that xmember looks like a nghtmare. Hope they did a new clutch already hah
    malburg114[QUOTED] likes this.
  3. Apr 27, 2018 at 11:56 AM
    malburg114
    Las Vegas, NV
    I know it'll work but to take anything out they have to undo the links to undo the crossmember to have room for a tranny jack in there.
  4. Apr 27, 2018 at 12:04 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Ew look at that body lift :puke: Should've put Billie 5100s instead :cookiemonster:
  5. Apr 27, 2018 at 12:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ok sorry, disregard my comments.
    It is too tall though, seems like that’s a problem with the majority of sas’s.
    Go pick apart his tundra too if you want.
  6. Apr 27, 2018 at 12:41 PM
    Speedytech7
    We're a picky bunch of pricks. When do we get an upgrade on your trailer build. I saw one the other day that made me fear for humanity...
  7. Apr 27, 2018 at 12:46 PM
    JKO1998
    Utah
    Soon as I get a job, so far the plan is just to flip the axle, maybe just get a new axle, Taller tires, sliders just because.
    Already put a new line in for a heater, new battery. Trying to decide if I wanna get a little solar panel, monstaline it. You know, pull a @BartMaster1234 and do a bunch of unnecessary work.
  8. Apr 27, 2018 at 12:52 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Well shit
    :tinfoilhat:
    Speedytech7[QUOTED] likes this.
  9. Apr 27, 2018 at 1:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Oh-Oh...
  10. Apr 27, 2018 at 1:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Can you share the XGauge codes you used to program your ScanGauge? I'd like to try this on mine.
  11. Apr 27, 2018 at 1:12 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Gimme a minute to find them. They’re on the scanguage site.
    Digiratus[QUOTED] likes this.
  12. Apr 27, 2018 at 1:14 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
  13. Apr 27, 2018 at 1:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There were several variations that I saw, just wasn't sure which ones work with our application. Definitely looks like these two do. Thanks.
    @turbodb see about getting this going this evening and give you some feedback on what mine are.
    turbodb likes this.
  14. Apr 27, 2018 at 1:20 PM
    WizardsAndBooze
    WizardsAndBooze Well-Known Member
    Maryland
    2003 Tacoma ex-stepside
    Ive got a question for you all. I finally got fender flares for the bed I put on my truck, and I also have the plastic clips the hold the flare onto the side of the bed. My question is what bolt holds the flare onto the inside of the wheel well? (pictured for reference) is it the same bolt/screw that is on the bottom of the front flares? (I took one off the front for reference) If so where can I buy these?20180427_161622[1].jpg 20180427_161637[1].jpg
  15. Apr 27, 2018 at 1:23 PM
    WizardsAndBooze
    Maryland
    Wish my ARB still looked this good!
  16. Apr 27, 2018 at 1:33 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Found out why the Crapmobile won’t start. IGN fuse was out.
    This truck is burning fuses left and right for some reason.
  17. Apr 27, 2018 at 1:36 PM
    Speedytech7
    Time to start patching and tracing. One if the most useful tools I ever bought was my PowerProbe III thing is invaluable.
  18. Apr 27, 2018 at 1:50 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    why what did you do to it lol
  19. Apr 27, 2018 at 1:54 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Ship it to the rust belt for a year. You'll be replacing rusted shit for years.
  20. Apr 27, 2018 at 1:55 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    @Speedytech7 so time to start looking for leaks then I guess?
