  1. May 2, 2018 at 7:25 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I just did a trip with a guy who has a very well done 3-link front that showed me that you can keep a relatively good width, good frame height, stronger axles and still go pretty fast off-road. I’m very torn between 3 link and LT now, but I don’t have money for either so I guess I don’t have to worry too much. :rofl:
    Regular IFS:
    Vs 3-link in nearly the same spot...
    Wish we had a LT truck there to compare too.
  2. May 2, 2018 at 7:43 PM
    Hunt/Taco
    Hunt/Taco Well-Known Member
    Coleman
    2003 Tacoma, Reg Cab, 2.7, 4wd, Auto. 90,xxx miles
    Pioneer Radio, New rear bumper (that does not really count though). Going to be upgrading it more and more as time goes on.
    Wow the 3 link one looks awesome!! How much would it cost to do some thing like that to our trucks?
  3. May 2, 2018 at 8:09 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    About 99% sure. Lets do it brotha
  4. May 2, 2018 at 8:11 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    That's what I keep telling my girlfriend.
    A lot. Unless you can fab everything yourself, which most can not.
  5. May 2, 2018 at 8:14 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I think my favorite sas that I’ve seen so far is Alec Overtons, if you have Instagram you should go look him up. The thing looks great. Might be on Facebook too i don’t know for sure.
  6. May 2, 2018 at 8:20 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Did you ever get any info on this?
    04doublecab likes this.
  7. May 2, 2018 at 8:23 PM
    JKO1998
    Utah
    The body mounts? I never found any write up no.
  8. May 2, 2018 at 8:29 PM
    eon_blue
    Azusa, CA
    Last week or so I've devrloped this dull 'thunk' coming from my front end, sounds like passenger side but maybe center. Mostly noticeable at slow speeds and almost always when I accelerate from a stop, or start reversing. Checked my LBJs and calipers (recently did my brakes) and they're good.
    One thing I noticed when I had my wheel off though was that my rotor knocks against the wheel stud when turned (the slot where the stud goes through the rotor knocks against the stud)...is that normal or maybe that's the noise I'm hearing when I accelerate from a standstill?
  9. May 2, 2018 at 8:33 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    I'm thinking of doing a AAL but it be no use since I'll be replacing my leaf springs anyway with a custom made set.
    also depends on the offroading you be doing. I don't plan on rock crawling much so I'm doing a LT just for the more bolt on appeal. I know there's still some modification to be done but not much compared to SAS. Not saying SAS isn't good just not for me.
    Also today the truck is dropped off by the shop. I miss it already
  10. May 2, 2018 at 8:58 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I'm using Valvoline SynPower w/ moly for my drive line.
  11. May 2, 2018 at 9:19 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Dangerous is a 95 Geo Tracker that only runs on 2 cylinders. I once kept it on the floor for 8 minutes straight on a flat straight road... made it to 62. That little thing would go anywhere though!
  12. May 2, 2018 at 9:51 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Installed my Wheelers 1.5" AAL and rear Bilstein 5100's this past weekend. Didn't take any pics of the install, but was pretty straightforward. Rides a million times better than just my worn out leafs and cheap Gabriel shocks. I don't know exactly how much lift I got out of the back because I didn't measure before hand, but I'm gonna guess around 1.5".
    Here's my final measurements, center of hub to bottom of fender flare in case anyone's interested:
    (I have 5100's with 880's on the bottom setting up front btw)
    Driver front: 22"
    Driver rear: 23"
    Passenger front: 22.5"
    Passenger rear: 23.5"
    Also a couple of questions:
    Why does the longer rear Bilstein 5100 go on the passenger side? I would think it would go on the driver side to combat taco lean?
    Should I be worried about my ebrake cable being so close to the top of my leaf springs? The cable is pretty close but not quite touching.
    Do I need to get a BPV relocation bracket?
  13. May 2, 2018 at 9:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What paint / clearcoat did you use?
  14. May 2, 2018 at 9:59 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Looks good!
    The longer 5100 goes on the passenger side because the mounts are slightly further apart. Putting it on the driver wouldn't help with lean anyway - it's the leaf springs that hold the back up, the shocks just dampen compression/rebound over bumps.
    Don't worry about your ebrake cable if it's not touching.
    A BPV is a good idea with any sort of lift, otherwise you aren't getting full braking power anymore. And while you're back there, make sure you don't need an extended brake line (if you didn't replace it already).
    aknickyota22[QUOTED] likes this.
  15. May 2, 2018 at 10:03 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Get a leaf spacer, i have one its about 1” and helps with the lean.
  16. May 2, 2018 at 10:09 PM
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Thanks!
    Braking does seem slightly less effective than before the lift. I guess a BPV would be a cheap way to ensure I'm getting full braking. Still have the factory rear brake line, but it doesn't seem to be under any stress, parked on a level surface anyways. It'll probably be stretched to it's maximum at full droop though, so maybe a extended brake line would be smart.
    turbodb[QUOTED] likes this.
  17. May 2, 2018 at 10:20 PM
    Dan8906
    Daniel
    Concord, California
    I thought about doing that but I feel like that is just a bandaid, I feel like the right way to do it is by increasing the spring rate of the driver side leaf. I just got deaver leafs qmkfor my gfs truck and they gave me side specific leafs so it will be level.
    Did you need longer u bolts for the spacer?
  18. May 2, 2018 at 10:21 PM
    Prayn4surf
    Socal
    I have the extended ubolts from wheelers
  19. May 2, 2018 at 11:34 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    jubei likes this.
  20. May 2, 2018 at 11:38 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Driving the ridgeline the first time. Thing turns quick and rides nice on pavement but dirt is a meh but my tacoma ain't stock
