  1. May 6, 2018 at 10:47 AM
    eon_blue
    Azusa, CA
    I do this too but only if I know I'm going to get moving again quickly. If you're waiting at a light though I've heard its not great on the clutch/pedal to keep it pressed for extended periods of time.
    mechanicjon and Kiloyard like this.
  2. May 6, 2018 at 10:52 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Manual cars actually use gas while in neutral so they dont cut off, if you leave it in gear till your just about to stop the engine doesn’t use full because the drive train is spinning it. So if you really care about your mpgs then do that. But if u dont car then just coast to a stop in neutral like a normal person
    eon_blue[QUOTED] likes this.
  3. May 6, 2018 at 10:52 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Agreed. Always shift to neutral when you're stopped at a light to prevent unnecessary wear on the throw-out bearing.
  4. May 6, 2018 at 10:52 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    it was a lot of fun. Always great to get together with you guys.
  5. May 6, 2018 at 10:59 AM
    Kiloyard
    Phoenix, AZ
    You're telling me your engine can run without using any fuel? Interesting. I am not very knowledgeable about engines, but it seems to me that it will use more fuel coasting in low gear as long as the RPMs are higher than your idle RPMs (about 680 for me). My assertion is based on the fact that combustion is still happening in the engine at all times. Higher RPMs = more fuel usage.
  6. May 6, 2018 at 10:59 AM
    eon_blue
    Azusa, CA
    Yup. I'd rather replace the shifter seat bushing if it gets to be too big of a pain to move the shifter at a standstill than have to drop the transmission and clutch assembly to replace the TOB. Even though mine has been chirping like mad since it was practically new anyway...1st gen problems
  7. May 6, 2018 at 11:02 AM
    climber-420
    climber-420 I love tight cracks
    CO
    2004 Gold Ext Cab TRD 3.4L V6 Manual
    255/85/16 BFG KM2's, 3" OME lift, Dakar's, Nitrochargers, Grey Wire Mod, ARB Bumper, ARB CKMA12 air compressor, WIts End Pacifier, Warn M8000, Uniden 520 XL CB, rear diff breather mod, full time power to aux 12V outlets, Rago Fab ditch brackets, Titan Rod Vault, Extreme LED's front and rear,
    HAHA! Yeah living in the PNW, its the only color we have. Best of luck with your Trip:help:
  8. May 6, 2018 at 11:06 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    I just couldn't justify spending the money for something as small as a Tacoma. I loved my taco and Tacomas are verry nice trucks. They are in such demand right now,and people are willing to pay. The tundra was allot cheaper with more room .
    The tauna cover is for sale also
  9. May 6, 2018 at 12:52 PM
    JakesTacoTRD
    JakesTacoTRD "Winona the Tacoma"
    Jacob
    Gainesville, FL
    2001 White Tacoma SR5 TRD 4x4 5 speed
    Today I changed my pcv valve and tubing... the boot fell in so I had to fish that out, but an easy task. Also planned on plugs and wires, but saw my battery terminal and figured I should fix that at the same time. So up on the to do list is plugs, wires, battery terminal, back window pins, and hook up this bushguard I got for 50 bucks!
    TacoYankee, SwampYota and Teke like this.
  10. May 6, 2018 at 2:27 PM
    eon_blue
    Azusa, CA
    Wired up my AFR gauge...ignore the zero on the gauge (camera phone doesn't catch the LED lights) and the gaff tape mounting job lol...not exactly sure where I want the gauge yet.
    Only did a couple neighborhood pulls so far, seeing 14 - 14.7 at idle and cruising and as low as mid 12s when hitting ~5psi boost. Haven't gotten to see my lean pinging numbers yet, usually it's worst when entering the freeway or climbing a long freeway grade at speed. Still trying to learn how to decipher the numbers.
    SwampYota likes this.
  11. May 6, 2018 at 2:57 PM
    Brodylbaker
    Brodylbaker Member
    Mobile, Alabama
    Found a 01 and up grille for $5 while looking for a new radiator for my 4Runner. I guess it’s time for a face lift.
  12. May 6, 2018 at 3:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Can you guys see the bear or are ya still too dumb?
    Tacoma related cause it ran in front of me on the road.
  13. May 6, 2018 at 3:39 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  14. May 6, 2018 at 3:41 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    First one to guess what this is gets a prize!
  15. May 6, 2018 at 3:42 PM
    JKO1998
    Utah
    Looks like one of those homemade air drums thingys
  16. May 6, 2018 at 3:45 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Hit the top of the pipes with your flip flops
  17. May 6, 2018 at 3:45 PM
    JKO1998
    Utah
    I take my answer back
    Speedytech7 likes this.
  18. May 6, 2018 at 3:48 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    It looks like something a hipster would own
    BartMaster1234 likes this.
  19. May 6, 2018 at 3:50 PM
    JKO1998
    Utah
  20. May 6, 2018 at 3:54 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That. It's that.
    I'm surprised no one has mentioned the Dodge RAM suspension yet.
