  1. May 13, 2018 at 9:54 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    last "scary" pop i got was on my 2000 tacoma. the driver side closest to the cab leaf spring mount punched through the bottom of the frame. at first i didnt know what it was until i got home and saw my truck leaning more then usual. damn frame rust
  2. May 13, 2018 at 9:57 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My frames definilty a little Holier than me but I don’t think that’s it.
    I think it’s the Billy shocks thatve been blown for years and the fact that I have zero bump stops to stop me from getting extra flexy.
  3. May 13, 2018 at 10:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    he doesn't have the dual. Just the single.
    Mikes did my 35s in about 1:45 or so. Slightly longer maybe.
  4. May 13, 2018 at 10:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Ah okay, that would explain it, yeah the single is probably a bit undersize for airing up four at once haha. But a 35 in under 2 mins for the dual is damn good I think.
  5. May 13, 2018 at 10:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    its not bad. No where near as fast as CO2..but still good.
    Not sure you've really had "more use" from yours than me...
  6. May 13, 2018 at 10:10 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Totally forgot it was Mother's Day, had to stay home. Haha.
    I'll put it back as soon as I get a new coat of paint on it.
    eon_blue[QUOTED] likes this.
  7. May 13, 2018 at 10:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    And that was after I had just aired up my four tires. The longer it runs and the hotter it gets, it slows down a little.
  8. May 13, 2018 at 10:14 PM
    Speedytech7
    @turbodb and @m3bassman
    I thought more about that air up 4 at once idea and the limiting factor other than single piston air compressors would be the amount of throughput on the inflator itself. It's adequate for what a single valve stem down stream can flow but I bet if you have a twin piston compressor (or really any compressor that flowed more) that that would be the bottleneck.
    turbodb likes this.
  9. May 13, 2018 at 10:17 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I still don't really see how it'd be any different than airing them up one at a time. You're taking four tires from ~17 to 40psi, regardless. Perhaps it's time for an experiment. I do have plenty of hose...just need the fittings.
    EDIT:
    This is a great point. Will need to noodle.
  10. May 13, 2018 at 10:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You should see the rest of my garage.
    I decommission small business computer equipment when they upgrade. I have the computers, servers, and communication systems from 2 dental offices and an IT consultant.
    Seagull233[QUOTED] likes this.
  11. May 13, 2018 at 10:19 PM
    Speedytech7
    You're assuming it is linear, but the compressor efficiency changes with higher pressure, so we end up with a curve provided there are no timelords around haha. So my guess is it will be fast getting to say 25 or so and struggle getting up to 32 or whatever you run.
  12. May 13, 2018 at 10:21 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Even if you could do two tires at once i think it would be a win.
  13. May 13, 2018 at 10:22 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I get that efficiency curve, but running the curve once vs. four times shouldn't be any different really. The flow rate though is a really interesting tidbit. As I've noodled for 3 minutes on that, I've wondered if the fittings are actually restricting flow, if having a manifold (less restriction) will actually decrease overall time...
    Edit: ...we know the gauge can handle more flow than a single compressor can provide - b/c it's the same gauge for the dual compressor... so 1 more minute of noodling and I'm back to "it'll probably be the same."
  14. May 13, 2018 at 10:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Then why make the statement in the first place?
    To me from the photo you posted. It looks like you haven't treated it very well. All I'm saying is I've had mine for longer than you..and for all intensive purposes..used it just as much as you have. Mine gets packed in a metal ammo can with other hoses and can not move around or get beat up in the ammo can.
    Do you throw things on top of your gear bag it sits in? Is it protected in the gear bag? What else is in the gear bag?
    To me it looks like a storage and handling issue more than anything.
    But that's just my thought
  15. May 13, 2018 at 10:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You're not the first to try it. Brandon in Colorado has done this. I can't remember if he did 2 at a time or all 4...
    Need to look up his screen name.
  16. May 13, 2018 at 10:34 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Don't forget about head loss through the system from fittings, manifolds, connections, etc. The ideal setup would be a single hose straight from the compressor to the tire with no gauges, quick disconnects, or anything else. Everything you add on in addition to that will reduce flow rate, and by the time you have a setup that could attach to all four tires at once, those losses will become significant.
    turbodb[QUOTED] likes this.
  17. May 13, 2018 at 10:37 PM
    Speedytech7
    Mine just bumps around with the hose behind my seat. No special storage. I do think the gauges aren't particularly good anyway. Mine is a solid 3-5psi off from all my other gauges so I don't bother treating it like a precision instrument.
  18. May 13, 2018 at 10:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Stig and turbodb like this.
  19. May 13, 2018 at 10:41 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    I find it kinda funny that theres always an argument over what the fastest method is to air up, half the time personally Im just sitting around BS'ing waiting for everyone else anyway lol
    malburg114 and m3bassman like this.
  20. May 13, 2018 at 10:42 PM
    Speedytech7
    If the weather is nice it ain't a big deal. When it's less than nice I prefer to be done first and sit in my warm truck.
    Lux[QUOTED] likes this.
