  1. May 17, 2018 at 1:58 PM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    jubei, Jebediah, TacoYankee and 9 others like this.
  2. May 17, 2018 at 2:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    @drr Dan has convinced me to try a 5 tire rotation. It will be the first time I've ever done that on any vehicle.
    One of the (many) curses of being old is remembering when cross-rotations caused premature tread separation. Cross rotating means changing the rolling direction of a tire. I am told that this is no longer an issue.
  3. May 17, 2018 at 2:08 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I rotate in my spare, figure it cant hurt and at least the tire gets used vs sitting on my swingout. When i need new tires Ill swap em all out.
  4. May 17, 2018 at 2:10 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Pretty sure you're supposed to as long as it's the same size. Which is why a lot of us don't. When I get another set of tires I'll have my full size spare so I'm going to rotate it in
  5. May 17, 2018 at 2:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I used to do a 5 wheel rotation. But now my spare is too far gone from the other 4 so I'll just do a 4 on Igor. Same for Frank right now the spare has too much life..but im due for new tires there anyways.
  6. May 17, 2018 at 2:23 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I do a 6 tire rotation every oil change. It’s nice having dual spares.
    jubei, BYJOSHCOOK, Prayn4surf and 2 others like this.
  7. May 17, 2018 at 2:29 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have the original factory 15" spare with the original tire on it with a 1997 date code. It still has the neon green paper sticker on it that says 'DEALER'
    I don't think it's a good idea to rotate that one in, considering my current rim and tire size is completely different.
    FLBAdrian likes this.
  8. May 17, 2018 at 2:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I had that too, was so dry rotted.
    Also your spare doesn't fit over your front brakes...
    m3bassman and Prayn4surf like this.
  9. May 17, 2018 at 2:29 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I came up with an overly complex pattern that ensures each tire changes rotation direction every time you change them. I have been rotating them every 5000 miles. Hopefully that’ll maximize tread life and keep the spare at the same level as everything else.
  10. May 17, 2018 at 2:31 PM
    Prayn4surf
    Socal
    Mine as well, the sticker looked like it almost burnt off.
  11. May 17, 2018 at 2:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'll probably pick up a 16" Tundra steelie if I can find one.
    You know what, this never occurred to me. I guess if I got a flat, I would swap a rear one up front and use the spare on the rear.
  12. May 17, 2018 at 2:32 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    To you guys with lifted trucks, does the factory bottle jack do anything to jack up the truck?
  13. May 17, 2018 at 2:34 PM
    Speedytech7
    Yeah, don't jack from the frame, jack from arms or axle. Only things that affect that distance are tires. Also get a HF 6ton hydraulic bottle jack fits in the stock location and is way easier to use.
  14. May 17, 2018 at 2:35 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It fits in the same spot? I was looking at that but I've heard those cheaper bottle jacks don't like being stored sideways.
  15. May 17, 2018 at 2:36 PM
    Speedytech7
    Worked fine for me for 4 years. Still use it from time to time, worst case scenario you fill it with ATF ever other year haha, but mine hasn't leaked ever
  16. May 17, 2018 at 2:38 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I remember when I was doing my PreRunner swap, I was trying to drop the transmission with their transmission jack. It decided to lose all hydraulic pressure and hang the jack on the transmission.
    Ended up using my Hi-Lift jack and some strategically placed cinder blocks and cribbing to hold the transmission back in place. Topped it off with ATF and it worked fine again.
    I actually cracked my old bellhousing from that. It's sitting in my scrap heap.
  17. May 17, 2018 at 2:38 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Hummmm. With LT I just stare at it and wonder why I have a bottle jack:p
  18. May 17, 2018 at 2:40 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I used it once, I was trying to push my rear fenders out before I had fiberglass
  19. May 17, 2018 at 2:41 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    :eek::rofl::rofl:Did it work :p
    Cr250jumper[QUOTED] likes this.
  20. May 17, 2018 at 2:42 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Just added photos, it kinda worked
    SilverGhost[QUOTED] likes this.
