  1. May 17, 2018 at 2:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    lol no shit. I have to use a 4x4 block with a jack to get Frank up on jack stands...and the jack stands are on 4x4 blocks too haha
  2. May 17, 2018 at 2:57 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Right, I need to find a spare anyway
  3. May 17, 2018 at 3:00 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Five tire rotation for me as well. Spare to passenger rear; passenger rear to passenger front; passenger front to driver rear; driver rear to driver front; driver front to spare.
    The idea of having two new tires would only work for your first flat - at that point, whatever tire ended up being your spare would no longer be new... and so you'd have to change your methodology (well, I guess depending on how used it was)
    I used it for a while, and it worked; just a bit sketchy and you had to make sure you built a solid platform for it.
  4. May 17, 2018 at 3:00 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I hear ya lol, I have to use a combo of jacks and then wheels have to come off to fully rest and droop on jack stands. If I dont have the jack stands all the way up the jack gets stuck under the axle lol
  5. May 17, 2018 at 3:03 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Timmah! likes this.
  6. May 17, 2018 at 3:03 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Well shit, the jokes on me. Not half bad....
    Oh I hear ya. I stack red pavers under mine. I ended up making a set of tall ones. I want to make another set but I’ve been to lazy :anonymous:
  7. May 17, 2018 at 3:06 PM
    eon_blue
    Azusa, CA
    I just use my hi-lift (unless I'm at home and have access to my floor jack). Hi Lift stays bolted to my bed rack so it's my go-to jack if I'm out somewhere. Just keep it well oiled...I've seen more than one Hi-Lift fail because the person that it belonged to never oiled it. I spray mine down with Tri-Flo before each use and it's never dropped my truck, used it countless times before I had a floor jack at home.
    Problem with my floor jack is that it's not even high enough, need an extension for it (if they make one..?). Works well to lift the rear by the pumpkin but I have to use the front skid plate to lift the front, which makes me a little uneasy. I've also used the LCAs as a jack point but the floor jack is a little tricky to fit under there safely. But that works really well to get a tire off the ground if you're only needing to do one side.
  8. May 17, 2018 at 3:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, that doesn't look sketchy at all...
  9. May 17, 2018 at 3:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Would you care to share that rotation pattern?
  10. May 17, 2018 at 3:11 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Why not put the jack on the axle in this situation? That way you aren't drooping out your suspension.
    I keep the stock bottle jack for just that, it's usually easier than letting the rear droop out with a hi-lift. If I had to do it off the frame, I would find a way to strap the axle such that it doesn't droop out.
    Front's not an issue with the hi lift.
    malburg114 and Speedytech7 like this.
  11. May 17, 2018 at 3:12 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    HEY. Try not being that stirthepot guy with me. Just state directly and clearly what it is you want to say instead of trying to imply something with indirect comments meant to elicit a desired response.
    :luvya::luvya::luvya:
    Sorry, couldn't resist, that was just too easy.
    Totally sketchy. I believe my first purchase after that trip was the Hi-Lift!
    koditten, BYJOSHCOOK, Teke and 3 others like this.
  12. May 17, 2018 at 3:13 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yes, cost and useful tread life. The leading edge of the tread blocks wears more quickly than the trailing edge, so reversing the direction of rotation evens that out, and the shoulders of the front tires wear more quickly than the rears, so switching back to front keeps those even.
    For example, my MTRs can probably go 40k miles (if I’m lucky). By adding in a 5th tire to my rotation, I should be able to get (5/4)*40k = 50k miles before I need all new tires.
  13. May 17, 2018 at 3:13 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Lack of experience at the time is my only excuse.
  14. May 17, 2018 at 3:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Dooooood. That looks sketchy as shit. :luvya:
    turbodb[QUOTED] likes this.
  15. May 17, 2018 at 3:18 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yes, I have a sweet graphic on my computer of the pattern that I will share when I get home. I think it is similar to what @turbodb described.
  16. May 17, 2018 at 3:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The other Dan's rotation is the standard 5 tire rotate but does not ensure the rolling direction is swapped on all tires each time. In his, some tires do 2 stints in a row rolling in a given direction.
  17. May 17, 2018 at 3:23 PM
    Squeaky Penguin
    Brett
    Every single time using a hi-lift is sketchy IMO. Makes the bottle jack look way safer in most situations, but they sure are handy.
    Useful tool, but always exercise caution. Make sure to have a can of WD-40 or something around too. Mine likes to not go down unless you give it a little spray.
    Valid excuse. :D
    SilverGhost likes this.
  18. May 17, 2018 at 3:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    What about the new arb hydraulic high lift they are making
  19. May 17, 2018 at 3:24 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Wow the bottle jack goes that high? I’ve never noticed.
  20. May 17, 2018 at 3:24 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Mine doesn't change tire direction every rotation - takes 2 rotations to do that; which I figure is fine for me. Also, makes my rotation more "standard" which is good in case someone else ever does one. Curious to see yours though; because the reasoning sounds good, at least conceptually.
