  1. May 17, 2018 at 4:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I like the hi lift, but all of the areas of my truck I use it on trap it in some way too. Bit safer when you know it isn't gonna slingshot out at you. I had a little chuckle to myself at the off-road expo in Scottsdale last month. The folks in the proeagle area make the hilift out to be the worst most evil hatred filled invention since moldy sliced bread. Mean while they're pushing a $350 dollar Costco floor jack with some 4" wheels about like it decended from heaven to give them all boner pills and sandwiches.
    jubei, A Mo Cat and Reh5108 like this.
  2. May 17, 2018 at 4:17 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    was there a bowel of crystal meth next to them?
  3. May 17, 2018 at 4:18 PM
    Speedytech7
    I try to refrain from checking people's bums for drugs
  4. May 17, 2018 at 4:18 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Best leave that one for the TSA
    Speedytech7[QUOTED] likes this.
  5. May 17, 2018 at 4:19 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    i ment bowl sorry im tired
  6. May 17, 2018 at 4:20 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Only necessary if you have Michelins. :p
    Aside from smashing a valve stem on a rock, I've not had one single tire issue in all my miles of offroading.
    SilverGhost[QUOTED] likes this.
  7. May 17, 2018 at 4:21 PM
    Speedytech7
    Metal valve stem or rubber? I'm having rubber ones put on my new steelies, feel like I'm gonna break the little metal ones.
  8. May 17, 2018 at 4:23 PM
    Squeaky Penguin
    Brett
    Rubber. The outside metal bit was smashed and was pressing on the valve.
    I tried to "fix" the issue by unbending the smashed bit, but just made it worse. :D
    Guessing one of those fancy sealing valve caps would have solved the issue.
  9. May 17, 2018 at 4:24 PM
    Speedytech7
    Good tip! It's not super easy but you can put a new rubber stem in backwards with soapy water and then refill. Carrying a spare stem or two cost like $3
    Seagull233 likes this.
  10. May 17, 2018 at 4:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well you won't like other brands. BFGs have soft side walls..
    Yeah i can't imagine MTRs in a d or E. Even my Cs are stiffer than most other Cs.
    yeahhh...not the first time Frank's been held up by just a hi lift. I don't really care, never has bothered me working on the truck while up on one.
    You obviously don't wheel hard enough :luvya: And don't buy BFGs
  11. May 17, 2018 at 4:41 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Coming from E rated KM2’s, the D’s were a nice change. They squat just fine at about 4psi :D
    Yetimetchkangmi likes this.
  12. May 17, 2018 at 4:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    mine squat good at 10 haha never had these down that low. Had my km2s down that low once though.
  13. May 17, 2018 at 4:55 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Ha! Damn low blow. He isn’t ever here to defend himself :p It also helped James out too. I like having a floor jack just because I know others have hi lifts.
  14. May 17, 2018 at 4:57 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Not sure if it makes much difference in dry powder, but in the wet snow we get (lovingly referred to as Cascade concrete), low pressures make a huge difference. The snowtrek.org guys are from out here, they say they start at 5 psi and go down from there haha.
    That’s a great way to do it, especially if you’re sticking with your current tire size.
  15. May 17, 2018 at 4:59 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Damm lowest ive aired down to was 12.
    My buddy rocks the floor jack too, but we havent had to use it or my highlift...yet.
  16. May 17, 2018 at 5:01 PM
    eon_blue
    Azusa, CA
    Mine was 8psi and it was to get out of some really deep, soft sand that I was stuck in at 15psi. Worked like a charm, too.
    The worst is when you hit pavement for short stretches with ~15psi in the tires...some of our local trails connect to one another via entrances that are a few miles apart down the highway. Feels like you're steering a boat.
    Prayn4surf[QUOTED] likes this.
  17. May 17, 2018 at 5:03 PM
    Prayn4surf
    Socal
    Yeah havent gotten burried in sand yet, im sure it will happen eventually, was surprised it didnt happen in superstition this past winter.
  18. May 17, 2018 at 5:06 PM
    BeastyDirtSlut
    BeastyDirtSlut Well-Known Member
    2003 Toyota Tacoma 4x4 TRD SR5 3.4 Auto
    2nd Gen Supercharger, URD 7th injector, 6" Fabtech lift, King coilovers, Alcan lift springs 800# over
    Fckn 3.4 fuel filter.....makes me feel like I should not be working on cars. How is something so simple so damn hard.
  19. May 17, 2018 at 5:08 PM
    BeastyDirtSlut
    20180517_164516.jpg 20180517_164456.jpg Some pics of the chem burns from the gas. I have taken off and put back of the filter probably 20 times for hours and the inlet still leaks
    TacoYankee likes this.
  20. May 17, 2018 at 5:08 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
