  1. May 17, 2018 at 5:10 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I think he said fuel filter, but looks like a good device for the oil filter
  2. May 17, 2018 at 5:11 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Ah misread. Thought he said oil filter. As for the fuel filter, I had no issue really. The nuts barely wanted to turn, so it took long, but otherwise wasn't difficult for me.
    But yeah that oil filter tool made a world of difference.
    Prayn4surf[QUOTED] likes this.
  3. May 17, 2018 at 5:11 PM
    BeastyDirtSlut
    BeastyDirtSlut Well-Known Member
    2003 Toyota Tacoma 4x4 TRD SR5 3.4 Auto
    2nd Gen Supercharger, URD 7th injector, 6" Fabtech lift, King coilovers, Alcan lift springs 800# over
    Nah man. The oil filter I got to from u der the truck. I slid the filter down from the topside and reached up and screwed it in with my hand.
    I'm talking about the fuel filter. Taking it off and putting it on is easy. For some reason these aftermarket filters wont seal correctly. I've tried three in the last 2 days. Finally went and got an OEM one today from the dealership.
  4. May 17, 2018 at 5:12 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    By chance could the filter be detected? I never had an issue with mine
    Edit mines also a wix
  5. May 17, 2018 at 5:12 PM
    eon_blue
    Azusa, CA
    I used a Wix brand fuel filter that works great....hopefully there isn't something else causing your issue
  6. May 17, 2018 at 5:13 PM
    BeastyDirtSlut
    I put the old OEM filter back on yesterday to get to work and it didnt leak a drop.
  7. May 17, 2018 at 5:14 PM
    BeastyDirtSlut
    I was using duralast. I am about to head out to the garage to put the new OEM one in.
  8. May 17, 2018 at 5:14 PM
    sente3
    sente3 -
    North Jersey
    Oh that might be why. I went OEM right away. Figured it lasted ~180K miles without issue (though I am sure it was well past due), so I'd change it then and be good for quite a while.
    As for the oil filter, how do you manage to get the filter from under the truck? IIRC I couldn't manage to get any grip on it to unscrew the old one without taking the tire off and struggling to barely reach it and get pissed trying to start loosening it lol
  9. May 17, 2018 at 5:16 PM
    eon_blue
    Azusa, CA
    I've never had issue getting my oil filter off by reaching over the tire through the wheel well...have to unclip the splash guards but it's pretty easy from there. Then again I guess if you have bigger tires it might make it that much harder...not too bad with 32s.
  10. May 17, 2018 at 5:18 PM
    sente3
    sente3 -
    North Jersey
    :notsure: I am on stock size tires, so idk why I have such an issue. Maybe shorter arms? No idea. Maybe I just tighten my filters too much.
  11. May 17, 2018 at 5:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Here ya go...
    jubei, Phessor, BYJOSHCOOK and 2 others like this.
  12. May 17, 2018 at 5:22 PM
    BeastyDirtSlut
    Removed the skid plate, you can see the oil filter from under the truck. I reached my arm in and put the filter socket on without the wrench attached. (I used a socket style wrench that attached to a 3/8 drive) the I slid the wrench in and felt for the hole on the socket. I dont tighten my filters to a point where I really need a wrench though. I couldn't remove the old filter from the underside so I balanced it somewhere right there and pulled it out from the top.
  13. May 17, 2018 at 5:24 PM
    BeastyDirtSlut
    Also I put in a k&n filter this time that has a nut welded to the top of it. Super easy to get a small wrench on it.
  14. May 17, 2018 at 5:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Anone know what this vsv does, seems only my year has it...
    Wondering if I can out it from my new intake. Even the supercharger install manual says only this year needs to have a Barb put in for it but doesn't say what it does.
  15. May 17, 2018 at 5:33 PM
    Speedytech7
    Yeah, you see my problem here haha. Bout to bring out the test light and just see what condition lights it up.
    turbodb and m3bassman[QUOTED] like this.
  16. May 17, 2018 at 5:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Looks like part of the evap setup.
  17. May 17, 2018 at 5:43 PM
    Speedytech7
    Just figured it out, apparently later on they used the IACV to control idle up for AC but on this year they essentially used this thing to get air past the throttle body to idle it up.
  18. May 17, 2018 at 5:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol wtf.
  19. May 17, 2018 at 5:47 PM
    Speedytech7
    That's why it has this adjustment screw too, so I could make my AC idle like 1750 haha
    Kinda crude but I suppose it makes sense since this is the first year of the Taco and the AC was a higher option, so I imagine they wanted to make it completely separate to add in. On the other hand you could use one of these to make an electronic idle up for winching :cool:
  20. May 17, 2018 at 5:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    this was literally my first thought when you said:
    haha
    Speedytech7[QUOTED] likes this.
