  1. May 18, 2018 at 10:45 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Some blow and road head :notsure:
  2. May 18, 2018 at 10:49 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Mine has devloped a squeek the past few weeks as well, although I think my is bushing/shock related. My wheel bearings have started to howl as well, they spin ok and have no play, but man do they howl from 35-45mph.
  3. May 18, 2018 at 10:53 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm confident I wouldn't be able to hear a failing wheel bearing above 40mph with the KM2s
    m3bassman and Captain Magma like this.
  4. May 18, 2018 at 10:54 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    just replace them. Mine howled for 6 months then nuked.
    I don't think so. You'd hear it and KM2s aren't that loud really.
    Captain Magma[QUOTED] likes this.
  5. May 18, 2018 at 10:54 AM
    eon_blue
    Azusa, CA
    a squeak makes me think of a bushing rather than a bearing or joint. If it was a clunk or pop while turning that'd be a whole different set of possibilities
  6. May 18, 2018 at 10:57 AM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    I am dropping it off next thursday for some new ones, my new 30mi highway commute has me terrified of them nuking at 75mph
    Blackdawg[QUOTED] likes this.
  7. May 18, 2018 at 11:45 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    my zerk came off my rear drive shaft last night while greasing it. the slip yoke zerk. is that fixable?? should I be worried
  8. May 18, 2018 at 11:47 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Is there anything left to grab and try to unscrew it? Generally they are replaceable
    Fernando[QUOTED] likes this.
  9. May 18, 2018 at 11:50 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've broke at least 3 of them off against rocks.
    Usually it's super easy to drill what's left of the old one out, and just screw a new one in.
  10. May 18, 2018 at 12:24 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Some of my best thinking was done driving home from work every weekend. Bend Oregon to Spokane after a 10 hour days aren’t fun.
  11. May 18, 2018 at 12:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Why are they so noisy all of a sudden? You must have changed the rolling direction. :stirthepot:
    Hell, my new STT Pros are noisier that the old KM2s were.
    drr likes this.
  12. May 18, 2018 at 12:36 PM
    BHill_teq
    BHill_teq Cruisin Hills
    Brayden
    SLC, Utah
    FJ62 Land Cruiser / 21 Tacoma TRDOR Army Green
    Mounted some Rotopax up in the bed of my truck! Super happy with the end result. I just got their mounting plate for the 2nd and 3rd gens, and drilled a hole into the bed side for it.
  13. May 18, 2018 at 12:37 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Is it okay to bend back my pinch weld where my slider mounts are touching it? After ripping apart the interior to no avail, I have determined my annoying creaking noise to be coming from my sliders where they touch the pinch weld. A test of violently shaking the truck while standing on them semi confirmed my theory.
  14. May 18, 2018 at 12:37 PM
    Speedytech7
    I wasn't alive when tires were made out of whale fat and horse hair so I don't know if that was an issue back in the day. But during the past 60 years or so it has been advised to change direction to even out wear. The bent rim makes the noise kinda soothing haha, that'll all stop when my new rims com in on monday.
  15. May 18, 2018 at 12:38 PM
    aceballos
    aceballos Well-Known Member
    ALFONSO
    Liberty Hill, Tx
    2017 TRD OR ACCESS CAB
    My 2017 Tacoma OR 4x4 Mods..
    Cali Raised 32' LED Light Bar
    TRD Pro Wheels
    Cali Raised Bed Stiffness
    N-FAB Bars
    Red Recovery Hook and Tie Down
    Cal-Trend Digital Camo Canvas Seat Covers
    WeatherTech Mats all the way around
    Neoprene Armrest Cover
    Armrest tray
    Glove box letters in red
    Tell me what yall think!
  16. May 18, 2018 at 12:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    totally fine. Or you could go bash em on some rocks. Then they will self clear haha
    Blue92[QUOTED] likes this.
  17. May 18, 2018 at 12:39 PM
    Speedytech7
    Uh, should we tell him?
  18. May 18, 2018 at 12:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think you're in the wrong thread dude..
    Prayn4surf, ClevSix and BYJOSHCOOK like this.
  19. May 18, 2018 at 12:40 PM
    aceballos
    ALFONSO
    Liberty Hill, Tx
    Hahahaha dammit wrong tbread!
    Prayn4surf likes this.
  20. May 18, 2018 at 12:42 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    What I think is you might be in the wrong thread. Cool seat covers tho
