  1. May 31, 2018 at 2:04 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    ahhhh I see. They sound good until the whole lug nut fitment. I saw on their site they had hubcententric now for 106mm but the lug nut thing is a deter.
  2. May 31, 2018 at 2:06 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Well im a 5lug so im not sure about the 6lug ones
    chowwwww[QUOTED] likes this.
  3. May 31, 2018 at 2:09 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    ill research more and find out.
    Will is this the same size lug nuts and studs for our trucks?
    Set of 4 Sixity 1.25 Inch (30mm) thick, 6x5.5in to 6x5.5in Hubcentric Wheel Spacers Adapters with M12x1.5mm 1.25 Inch Lugs Studs and a 106.5mm centerbore.
  4. May 31, 2018 at 2:17 PM
    eon_blue
    Azusa, CA
    I think that's what @HamerMan was planning on doing. Doesn't meth work by not only cooling the charge but raising the octane to prevent leaning out, whereas the 7th is literally adding more fuel to the mix to prevent lean out...so both working together would be an even better chance at keeping pinging and leaning out at bay. Unless I'm misunderstanding something
  5. May 31, 2018 at 2:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, you usually end up having to turn down the duty cycle on the 7th because of all the xtra fuel
    eon_blue[QUOTED] likes this.
  6. May 31, 2018 at 2:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What if i just use 2jz injectors and a better fuel pump then get meth...
    eon_blue likes this.
  7. May 31, 2018 at 2:20 PM
    eon_blue
    Azusa, CA
    I think that's another solid option, URD offers a larger injector kit as an alternative to the 7th for people that can't run the 7th (trucks with EGR, for instance).
  8. May 31, 2018 at 2:21 PM
    Speedytech7
    Could work well, I don't know what the flow on the larger injectors is, usually it is nice to have a method of tuning fuel with bigger injectors.
  9. May 31, 2018 at 2:22 PM
    Speedytech7
    Fuel pump should be a mandatory upgrade anyway with boost of any kind
    Sperrunner and eon_blue like this.
  10. May 31, 2018 at 2:23 PM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Well, I'll be replacing my CV axles this weekend. Boots have been torn for a while, but now I'm getting diff oil out of the driver's side. Sounds like removing the CVs can damage the differential seal (and one of mine is likely toast already,) so I wanna grab a couple, anyone have a PN?
  11. May 31, 2018 at 2:24 PM
    eon_blue
    Azusa, CA
    yeah I think the URD kit includes a piggyback for tuning them (same as the 7th does). Saw the URD larger injector kit going for $300 on the TW Facebook page, solid deal considering I think it retails for nearly $1k.
  12. May 31, 2018 at 2:28 PM
    eon_blue
    Azusa, CA
    not sure but is this what you're referring to?
    https://onlineparts.toyotasouthatla...AFT-SEAL-Front-Right/49332856/9031147026.html
  13. May 31, 2018 at 2:28 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I thought it was about the same as the 7th kit. I wonder what the difference would be between the two on a non egr engine
  14. May 31, 2018 at 2:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thanks for posting this. I was beginning to wonder if I was the only one feeling this way.
    I have resorted to using the ignore button on occasion when it becomes too obnoxious. I suppose that is a bit passive/aggressive on my part tho. Maybe instead I will start using the 'stay on topic' emote instead. :cookiemonster:
    SwampYota and Speedytech7 like this.
  15. May 31, 2018 at 2:31 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its ok we have are own thread now to BS in
  16. May 31, 2018 at 2:33 PM
    eon_blue
    Azusa, CA
    I don't know anybody running the larger injector kit...for some reason it seems like most people opt for the 7th if they can. Really though if you think about it, the 7th sort of acts like a band-aid to an issue with the lack of proper fuel whereas the larger injectors would be more of a solution to the problem.
  17. May 31, 2018 at 2:34 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Maybe I should be the first then...
  18. May 31, 2018 at 2:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If you read about it on urd site they say get the 7th for non egr trucks and its not street legal in ca and the 7th isnt street legal either. But idk why that is...
  19. May 31, 2018 at 2:42 PM
    eon_blue
    Azusa, CA
    yeah if you have EGR then you cant run the 7th, because the 7th injector plugs into the EGR port. I don't think you have EGR though being a 2004 but should check anyway.
    and yeah, it's not CA street legal because URD hasn't gotten any of their stuff CARB certified....takes big $$$$$$ to get that. Took Magnuson forever even though TRD offered the same blower with a CARB cert, because they dished out the dough for it. You could run the same blower from Magnuson and not pass smog visual even though there's no mechanical difference. All about that CARB sticker. Was the first thing the smog tech checked when he opened my hood and saw the TRD blower. Same with my TRD headers.
    I managed to pass smog with my 7th injector last year...smog tech didn't say anything about it. I was pretty worried too, thought for sure I would get dinged for it. I wrapped the steel braided line in electrical tape for it though so it wasn't so glaringly obvious in the engine bay, and looked more like the other vacuum lines in there...maybe that helped.
  20. May 31, 2018 at 2:43 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Driver 90311-47027
    Passenger 90311-47013
    Make sure you press them in just past the metal lip or they will leak again, ask me how I know...
    lukester78[QUOTED] likes this.
