  1. Jun 3, 2018 at 5:23 PM
    david9kelsey
    david9kelsey Well-Known Member
    David
    Murrieta Ca
    00' Tacoma PreRunner
    I just picked up a set of the regular ones with supposedly less that 25k miles on em for 300$. The guy told me they provide 3" of lift. Im running a camper shell and a small amount of gear. Probably a total of 300 lbs. Im also running 3" lift shackles. Just tryin to figure if i should ditch the shackles or maybe run both? Any info really. Are you happy with your expos? Will i need extended u bolts?
  2. Jun 3, 2018 at 5:29 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Yes and no, expo's are great don't get me wrong. But that's because what I'm about to do with the truck has changed. They are a bit rough with no weight and hold a 3 inch lift well with 500 pounds in the bed. and ride amazing with a extra 100 pounds. I would run with the shackles if I was you. I'm on the original shackles and I feel like I need longer ones lol
    david9kelsey[QUOTED] likes this.
  3. Jun 3, 2018 at 5:33 PM
    david9kelsey
    David
    Murrieta Ca
    Yea thats why i bit on these regular ones. I figured the expos would be way too stiff for my set up. The website states that these are more set up for ride and flex. My factory leafs are frowning so hopefully this is a much better set up haha
  4. Jun 3, 2018 at 5:35 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    They should be, mine are hitting 2 years old now and performed how I wanted them to
  5. Jun 3, 2018 at 5:40 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Not first gen related at all, but are any of you guys good with tv’s? I have a big rear projection Mitsubishi..today I turned it on and it stayed on for a bit, but then just cut out and now it won’t turn back on. Yes it is plugged in lol. I’ve read around online and had no luck
  6. Jun 3, 2018 at 5:42 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I think those old ones have a big light buld that goes out. I had a buddy with the same kind of tv and it did that
  7. Jun 3, 2018 at 5:48 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Cleaned out the interior. Had to clean some grease stains out of the carpet and seats. Industrial maintenance is one of those jobs where some days you come home absolutely coated in 50 year old lithium-ish grease. It was so bad this week I had to fashion seat covers out of some stuff I found in the warehouse at work. Still didn't keep it all of my seats though. Also went ahead and bought a new AirCat impact gun to assist in the install of my Low Range AAL's hopefully next weekend.
  8. Jun 3, 2018 at 5:50 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I have a universal mossy oak seat cover for that reason
  9. Jun 3, 2018 at 5:52 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    I meant the leaf pack too hehe. I was just comparing my front to rear sag. The 5-leafs have held height over lots of mileage.
  10. Jun 3, 2018 at 5:53 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I’ve got a Sony rear projection TV in the bonus room. When the bulb goes out it does the same thing. Had it 10 years, replaced the bulb twice. It’s around $60. It gives me a warning message prior to it going out though for a few weeks.
  11. Jun 3, 2018 at 6:07 PM
    david9kelsey
    David
    Murrieta Ca
    Okay cool. Did you have to run extended u bolts?
  12. Jun 3, 2018 at 6:09 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I did a ubolt flip kit. And welded on new shock mounts to the axle
  13. Jun 3, 2018 at 6:19 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Sorry Ryan. With over 10 thousand posts on the board I should have remembered your name by now. Haha! Glad you got the leak figured out. Any special tools required to replace those lines?
  14. Jun 3, 2018 at 6:20 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    10mm flare wrench is recommend, everything else is commonplace.
  15. Jun 3, 2018 at 6:22 PM
    Kiloyard
    Phoenix, AZ
    Cool, I have a set of those flare extensions for my ratchet. They are kind of a pain to work with, but it was cheaper than buying a proper set for how often I need to use them.
  16. Jun 3, 2018 at 6:31 PM
    04doublecab
    Jeff
    2004 Tacoma
    The front light, for the power, doesn’t work. It hasn’t for years...so I can’t check for codes..
  17. Jun 3, 2018 at 6:35 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  18. Jun 3, 2018 at 7:00 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Interesting. ..i run the same setup. I have no weight in the rear besides my spare on a swingout. Rides good. When im loaded down she doesnt sag much and still runs good. Dont see a need for shackles
    david9kelsey likes this.
  19. Jun 3, 2018 at 7:07 PM
    david9kelsey
    David
    Murrieta Ca
    You running expos or regular packs?
    Fernando[QUOTED] likes this.
  20. Jun 3, 2018 at 7:21 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Expos
    taco71742 likes this.
