  1. Jun 9, 2018 at 8:41 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Not here
  2. Jun 9, 2018 at 8:42 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Kicking the anthill tonight.
    Changed out the ball joints and coil over assemblies on the Wife's '98...and I DID NOT use Toyota parts.:anonymous:
    I figured she drives the thing <500 miles a year, I can risk it. Don't hate on me.
    Speedytech7 likes this.
  3. Jun 9, 2018 at 8:42 PM
    turnerk1
    turnerk1 Well-Known Member
    Keith
    1996 4X X-Cab
    Mystery Lift
    After comparing to the new ones from the dealership, I'm thinking no. The new ones are much more finely made with more pronounced machined mating surfaces and a more domed back to the ball socket. Plus, the old one has a pin in the side that the new ones don't. To me, the cross section of the old broken one shows an internal metallurgical defect. What I'm deciding is that if I'm going to keep running this truck the way that trip went, lower ball joints are going to be an OEM 10yr/50,000 mile preventive maintenance item or sooner if play develops. There can be metal fatigue that you can't see. This isn't a daily driver so it will be a long time before these new joints see 50K. I'll be almost 70 by then so let's hope I'm still out there breaking parts. And remembering this post.
    To anyone reading this, breaking a LBJ is a catastrophic event. My spindle got busted at the top (those are semi scarce used, spendy new), the CV pulled out, my fender is dented, the door wouldn't open, and my brand new slider got bent. Plus, our trip was cut short. At that, we were lucky that no one got hurt or even killed. These are a weak point in our IFS. CHECK YOURS! If they've got a lot of hard miles, especially if of uncertain pedigree, give serious thought to changing them out even if they "look" OK. It's not that expensive or hard. Stepping off soap box now.
    TacoYankee, SwampYota and Reh5108 like this.
  4. Jun 9, 2018 at 8:44 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    We all gotta find the boundaries somehow, personally I just make clicking noises with a normal ratchet instead of busting out the torque wrench :anonymous:
  5. Jun 9, 2018 at 8:46 PM
    turnerk1
    Keith
    1996 4X X-Cab
    Mystery Lift
    No hate here. Sounds like you're making rational decisions and acting on them.
  6. Jun 9, 2018 at 8:47 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Bent the slider!? Damn!
  7. Jun 9, 2018 at 8:52 PM
    koditten
    Kirk
    Central Michigan
    Like posted else ware, they are a weak link when aggressive driving off road.
    They are more prone to failure from lack of maintenance. I like to believe anyone habituating this thread is aware that they need checked and replaced periodically.
    In addition, if one is serious about off roading, they will most likely have an additional vehicle that is not a Tacoma. The Tacoma is a wonderful compromise for daily driving and MILD off roading. Its not the best, but somewhat good vehicle for aggressive off roading.
  8. Jun 9, 2018 at 9:18 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I think most of it is good stuff but one thread with links to a few others on related topics wouldn't be a bad way to reduce the # of stickies. And the fire extinguisher thread definitely doesn't need to be a sticky.
  9. Jun 9, 2018 at 9:24 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I think this thread has a mix of “knows everything about a first gen” to “changed oil for the first time yesterday.”
    Threads are everywhere about LBJ but I’ve yet to see an all-encompassing thread about them...which is surprising since everyone warns of untimely death 4 feet from your AM/FM dial.
    Surprised we don’t have a LBJ bible as one of the 27 stickies...that sticky would need to stay.
    koditten[QUOTED] and ClevSix like this.
  10. Jun 9, 2018 at 9:26 PM
    Speedytech7
    Someone should write one... anyone?
  11. Jun 9, 2018 at 9:29 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
  12. Jun 9, 2018 at 9:47 PM
    SwampYota
    Jon
    Floor mats
    I nominate @turbodb. He is an excellent wordsmith. @Blackdawg for photos, talented photographer and should have a few real-world photos. Quite a few others can chime in and get a credit in the LBJ Bible. Stories, pictures, scenarios.
    Buying new truck? Check ———
    Going off-road for the first time? Check———
    Made it back without breaking anything? Check———-
    Use your truck like this? Check—— or this? Use this interval——
    Link to best OEM vs aftermarket——
    When is aftermarket okay?—-
    Instructions for changing——-
    Warning signs off and on road for LBJ failure——
    Would be nice to have a central resource.
  13. Jun 9, 2018 at 9:50 PM
    SwampYota
    Jon
    Floor mats
    Then again I am about six beers in so maybe I shouldn’t be volunteering people for such big projects...
    :drunk::cheers:
  14. Jun 9, 2018 at 9:53 PM
    Tacofart
    Tacofart Well-Known Member
    Brennan
    San Diego
    04 3.4 4x4 Dual cases/ Lockers
    Nuts tacked in. I think the spindle and or misalignments would have to bend to allow the bolt to bend. Regardless it’s just metal so you can cut it and re-weld it anyway.
  15. Jun 9, 2018 at 9:56 PM
    Speedytech7
    @turbodb
    You heard the mob Dan!
    Keep on Truckin' and turbodb like this.
  16. Jun 9, 2018 at 9:56 PM
    Tacofart
    Brennan
    San Diego
    I have broken two upper rings from crawling. I want to say it’s just bad luck but I wheel pretty hard trails with mid-travel, dual cases and f/r lockers so I’m convinced it’s the true weak point of our IFS. only ever busted one cv but ripped two spindle loops open.
    Reh5108[QUOTED] likes this.
  17. Jun 9, 2018 at 10:02 PM
    SwampYota
    Jon
    Floor mats
    He did give about the best answer I’ve ever seen to the often posed question of “what size tire can I fit on my Tacoma with (x) amount of lift.”
    turbodb and Speedytech7[QUOTED] like this.
  18. Jun 9, 2018 at 10:03 PM
    Speedytech7
    My favorite answer to that was always to stop asking the wrong question.
    turbodb and SwampYota[QUOTED] like this.
  19. Jun 9, 2018 at 10:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    After a little drama, both trucks are up and running.
  20. Jun 9, 2018 at 11:02 PM
    1997tacomav6
    Denver
    Installing this today not cuz I need but cuz I want it[/QUOTE]
    That’s the 4Runner radiator going in a Tacoma?
    From another post said you had to modify the radiator to fit?
    Did you have to modify the inlet or outlet or radiator cap section or
    just remove the hood support rod and you were good?
