  1. Jun 20, 2018 at 3:22 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    So I could get the camshaft plug "1118862010 engine, camshaft & timing, plug All Models" out and replace it.
    nagorb and JonRambo like this.
  2. Jun 20, 2018 at 4:09 PM
    Jonnyricogalabiz
    Jonnyricogalabiz Well-Known Member
    Jonny
    Redlands ca
    02 Prerunner
    N/A
    Hey do u guys think it be a good or bad idea to run different control arms? I'm purchasing lower TC control arms but i'm currently running JBA upper control arms with fox shocks also buying king bump stops
  3. Jun 20, 2018 at 4:24 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Had an ‘87...loved that truck.
    buckmaster243[QUOTED] likes this.
  4. Jun 20, 2018 at 4:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Wait, is it a pending code or a not ready system. The drive cycle isn't dependent on how many times you start it, it is dependent on testing conditions, typically each system has a certain set of conditions to be met like speed and duration.
  5. Jun 20, 2018 at 5:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    TC doesn't make lower control arms for our trucks...
    Titus94 likes this.
  6. Jun 20, 2018 at 5:15 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    They are awesome. One day I’ll restore mine and put a ls motor in it.
    TacoYankee[QUOTED] likes this.
  7. Jun 20, 2018 at 5:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Where's a good place online to buy metric bolts in small quantities? Fastenal wanted $5 a bolt for some diff bolts - if the factory bolts weren't torx head I'd pay way less and get them. The bolts ol truly to replace are the ones that connect the tube to the clamshell.
  8. Jun 20, 2018 at 5:29 PM
    Speedytech7
    McMaster Carr, but usually I'll go to a Grainger or ACE as they both have good hardware selections in store. You may have a Tacoma Screw near you and they're also good
    Dalandser[QUOTED] likes this.
  9. Jun 20, 2018 at 5:30 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  10. Jun 20, 2018 at 5:31 PM
    Speedytech7
  11. Jun 20, 2018 at 5:41 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    No one said anything about stock size or LT, just "TC LCAs." Clearly, more clarification is needed.
  12. Jun 20, 2018 at 5:42 PM
    Speedytech7
    I thought it was implied because people don't typically mix and match LT parts as their geometry is proprietary.
  13. Jun 20, 2018 at 5:44 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Had the same issue with mine. Forget what code I had that was pending but ended up replacing the 02 sensors. Drove 60miles and passed first try.
    Speedytech7 likes this.
  14. Jun 20, 2018 at 5:59 PM
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    The System is not ready is what the smog shops have told me. On my snacgauge it will say pending code of po136 but it hasn’t thrown an engine code in over 400 miles.
  15. Jun 20, 2018 at 6:00 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    ORW solid. :cool:
    BYJOSHCOOK and ClevSix like this.
  16. Jun 20, 2018 at 6:00 PM
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    I just replaced both o2 sensors last month. That’s where I’m lost because everything is pretty much new even some vacuum lines and it’s still not ready.
    malburg114[QUOTED] likes this.
  17. Jun 20, 2018 at 6:02 PM
    Speedytech7
    You likely have two issues, one is your system is on watch for another occurrence of your O2 malfunctioning (high or low or possibly slow response) which will stop it from setting the O2 system as ready which will stop you from smogging. I would start diagnosing your O2 sensor circuit issue, it is the one after the cat.
  18. Jun 20, 2018 at 6:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    he has JBA uppers. Those are stock width.
  19. Jun 20, 2018 at 6:29 PM
    ThatRedYota
    ThatRedYota Well-Known Member
    Nikola
    2003 Red Prerunner TRD Offroad
    Fox 2.5 IFP Coilovers, BTF uniball UCA's 295/75/r16 Toyo AT2s, front tube bumper (custom), rear tube bumper (custom), radiator guard, Assault light bar, Stereo, 3D printed Offroad switch panel/ mount
    I always do the filter every other oil change
  20. Jun 20, 2018 at 6:32 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You don’t need to use Torx head bolts again. No reason why you couldn’t just use standard Metric bolts.
    I replaced one of the bolts on my front differential, and I believe an OEM Torx bolt was something like $1.50 each from Camelback Toyota.
