  1. Jun 24, 2018 at 7:51 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Took the grill and the skid plates off to make it easier for the tech that will be working on my A/C.
    I found one of my corner lights is an aftermarket piece of CAPA shit. I'm not having it so I ordered a left and right from Toyota
  2. Jun 24, 2018 at 8:14 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  3. Jun 24, 2018 at 8:19 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  4. Jun 24, 2018 at 9:08 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Question for those of you who have worked with plastidip. Is it possible to layout a panel, and using narrow masking tape, lay out a second narrow strip around the main panel, and paint it all in one pass, then pull up the narrow tape? See the example in the image. I have not worked with plastidip, but have done considerable painting/stripping, layout of graphics, airbrush work. Just not sure if the bond with the plastidip would allow you to create the fine stripe. I have done this with paint, back in the day.
    I'm just not sure if I will like the look of the hood mostly black, so thought I would do it in something not as permanent as paint.
  5. Jun 24, 2018 at 10:00 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    if you use a razor blade to gently cut the plasti-dip i guess it would work. but i wouldnt try it
  6. Jun 24, 2018 at 10:42 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  7. Jun 24, 2018 at 10:44 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    was just for an example. i cant find one yet lol. any suggestions?
  8. Jun 24, 2018 at 10:47 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I use a blue sea ml-acr. It's ideal for my needs bit it is more expensive.
  9. Jun 24, 2018 at 10:50 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    i rather spend money knowing its not going to burn my truck down lol. I'll have OBA, fridge, lights and winch thats my heavy draw stuff. so im going to guess it'll handle my needs as well.
  10. Jun 24, 2018 at 10:52 AM
    jp59inh
    jp59inh Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    Cam seals today.
    Dalandser likes this.
  11. Jun 24, 2018 at 10:56 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yep. Staying on 15s. Cheaper tires. Works great with 35s. I'd go to a 16 for 37s though. But I won't run 37s until I can retro fit a 2nd gen front diff. 35s are good enough anyways really. Plenty of tire
    Dalandser[QUOTED] likes this.
  12. Jun 24, 2018 at 10:56 AM
    eon_blue
    Azusa, CA
    You want to pull the tape off carefully before the PlastiDip dries completely...if you wait until it dries, you'll end up peeling the PlastiDip off with it.
  13. Jun 24, 2018 at 10:57 AM
    HansWorldTravels
    HansWorldTravels Well-Known Member
    Hans
    Colorado/NY/Germany
    '03 Toyota Tacoma 3.4L Ext Cab TRD
    Roll & Ram repairs on '95 Front end crash repairs on '03
    hey guys, what’s this bearing called? Can I get it as a greasible bearing? It’s got 1/2” play.
    2nd question, if my count is right there are 6 UJs on the driveshaft (4 rear & 2 front), are they all the same sizes.... gonna replace all 6 while I’m at it.
    Thanks
  14. Jun 24, 2018 at 10:58 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    its a carrier bearing and i dont think you can replace the double ujoints stacked next to eachother.
  15. Jun 24, 2018 at 11:01 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Just remember that most of that stuff is running when the engine (and alternator) is running; so you may not need a second battery. Depending on your adventure style, you may find that you can even support the fridge on a single battery.
    I've run 1 battery to this point and not had a problem at all (esp. since the fridge has a low voltage shut-off; and it's only triggered once), but that's with trips where you're basically driving all day. If you're the type that heads to a beautiful spot and stops for a week, then you'll obviously want a second battery for that.
    Edit: @Digiratus - what's the difference between the Blue Sea controller you have and the RedArc stuff? (just brand?)
  16. Jun 24, 2018 at 11:03 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    yea, i kinda want to do both. and figured a second battery is good insurance regardless.
  17. Jun 24, 2018 at 11:07 AM
    HansWorldTravels
    Hans
    Colorado/NY/Germany
    Thanks at @zero4
    They’ve quite a selection of “packages” - and maybe the “complete” kit isn’t best for me as I just put in new rear springs & front shocks. Would like to not have to do 2 front alignments, but I might not be able to get all the front done b4 I put some miles on after the 4th.
    http://www.energysuspensionparts.com/products/toyota_tacoma_4wd_2003
    zero4[QUOTED] likes this.
  18. Jun 24, 2018 at 11:07 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Just adds a lot of cost by the time you get it isolated, wired, etc. My "insurance" so far has been to have a LiIon jump starter in case I somehow kill my battery.
  19. Jun 24, 2018 at 11:12 AM
    HansWorldTravels
    Hans
    Colorado/NY/Germany
    Thanks at @what road .... I seem to recall reading that about the stacked UJs too, although I see removable ring clips on all 4 sides of both.
    More research needed :D
  20. Jun 24, 2018 at 11:13 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    true, i'll try a single battery setup first and see how it goes i guess. probably best to wait till i get out there more to see where im getting left behind on.
