  1. Jun 26, 2018 at 9:34 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    I'm also not a fan of semi metallics. I got some Akebono ceramic pads, nice and quiet so far and dust is basically non-existent.
  2. Jun 26, 2018 at 9:42 PM
    1997tacomav6
    Denver
    Did the same thing a few weeks ago including the rear stain steel line and added the Toyota heat shims too for the pads.
    A very nice return I got from it too
  3. Jun 26, 2018 at 9:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do you know their compressed and extended lengths. Are they currently mounted in the stock locations?
  4. Jun 26, 2018 at 9:45 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I don’t know the lengths, but yes I’m the stock mounts
  5. Jun 26, 2018 at 9:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah,hard to guess without knowing that. I ran my 8.5" foxes for a while in the stock locations. They are 22.5" extended and 14" compressed IIRC.
  6. Jun 26, 2018 at 9:56 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yeah, I've already got a SS extended line for the rear. Installed it when I lifted my truck in '05. The kit I got came with a rear also but it's shorter than the one I have on. I guess it's stock length, not sure I don't have the stock one to compare. Guess I'll put it up for sale one of these days.
    1997tacomav6[QUOTED] likes this.
  7. Jun 26, 2018 at 9:56 PM
    1997tacomav6
    Denver
    New Champion aluminum radiator works great but the Champion radiator cap is junk, the caps locking tabs are week and small in design so they bend.
    Opened the hood and saw this happening today, so got a new quality cap.
    If you bought one of these radiators you might want to replace the cap for a quality one that doesn’t leaks, 8.00 it cost
  8. Jun 26, 2018 at 10:00 PM
    Dan8906
    Daniel
    Concord, California
    I can’t find the lengths unfortunately. Im going to run the for a while, I’ll have to look into a relocation and correct shocks
  9. Jun 26, 2018 at 10:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Idk. Might not have any droop really.
  10. Jun 26, 2018 at 10:07 PM
    Dan8906
    Daniel
    Concord, California
    :eek: That would not be good
  11. Jun 27, 2018 at 12:13 AM
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    Added a touch of blue.
  12. Jun 27, 2018 at 12:29 AM
    eon_blue
    Azusa, CA
    Welcome to the club :cheers:
    Did you have to add a lot of preload to get the height you wanted? I think I ended up with 19 threads showing on mine, I had to lower it some...initially I had too much lift and blew a CV boot.
  13. Jun 27, 2018 at 12:38 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ive done belts with over 200k that look better than that... and i've also done belts with 40k that were half the thickness of new.. (the 40k ones were Mitsubishi belts... junk design..)
  14. Jun 27, 2018 at 12:52 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I saved this post from Shubin. It was in the 1st gen marketplace back in Dec. I’m running the Icon VS 0-3” 2.0 non resi shocks in stock locations w/ a 2” AAL for now. I didn’t know the correct measurements either. So here they are.
  15. Jun 27, 2018 at 3:16 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    If you ever get the chance to get 100 feet of bubble wrap and run it over in a big rig lol best damn thing to do if your still a kid at heart
  16. Jun 27, 2018 at 6:11 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    This makes me miss my fenders
  17. Jun 27, 2018 at 6:42 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Damn ankle bitters is what I call small dogs. I can't stand em, I'll never own something under 40 lbs haha
    Worst case they do limit your droop but it'll still work, just not ideal
  18. Jun 27, 2018 at 6:55 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I don't mind some small dogs. We have a pug/frenchie and she is a delight. Doesn't bark at my neighbors like their dachshund does to us. My dog will actually sit and watch my neighbor work while his dog barks at my dog. She is chill AF, just a little sausage of muscle.
  19. Jun 27, 2018 at 7:08 AM
    Dan8906
    Daniel
    Concord, California
    Hmm, my truck was rummaged through last night, not sure what they were looking for, they cleaned out the center console, which was mostly junk and everything else looks to be in place. Which im grateful for, my tool box was in there, compressor, K-bar knife and thats really it. I wonder if they got spooked by someone or something. Im usually good about not leaving anything in my truck, but ive been camping alot so I got tired of taking things out to put them right back in, but I guess ill get back to doing it.
    SwampYota and HansWorldTravels like this.
  20. Jun 27, 2018 at 7:16 AM
    Dan8906
    Daniel
    Concord, California
    lengths are below
    Appreciate it thanks!
    Sicyota04[QUOTED] likes this.
