  1. Jun 29, 2018 at 6:43 PM
    eon_blue
    Azusa, CA
    According to the instructions, this bracket is supposed to be up front by the steering rack and that's where I'm supposed to install the supplied crossmember, while the rear of the skid mounts to an "existing crossmember". Were there two styles of Tacoma 4x4s? This is strange.
  2. Jun 29, 2018 at 6:45 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    That is strange. Dont know why that would not be there :notsure:
  3. Jun 29, 2018 at 6:49 PM
    aarcarr
    aarcarr Well-Known Member
    Arizona
    23 Tacoma TE | 18 4Runner SR5
    08 4Runner SR5 sold 03 Tacoma TRD sold
    I didn't buy the LC grille, was looking into doing it up like that but its way too expensive! looks really good though
  4. Jun 29, 2018 at 6:51 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    not really related but i was looking at the FSM and noticed that the frame/crossmembers for the prerunner and the 4wd models does not look the same at all. I was under the impression that they were the same frame. learn something new everyday i guess...
    SwampYota likes this.
  5. Jun 29, 2018 at 6:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks like mine, maybe the instructions are for a DC?
    eon_blue[QUOTED] likes this.
  6. Jun 29, 2018 at 6:55 PM
    Speedytech7
    That's single cab vs extra, so yeah they'll be a bit different
    Area51Runner[QUOTED] likes this.
  7. Jun 29, 2018 at 7:01 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Looks good bud
    david9kelsey[QUOTED] likes this.
  8. Jun 29, 2018 at 7:11 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    It's possible, door jamb switches do go bad. Easy to test with a multimeter.
    EDIT: BTW, driver side is easy to test, do you get the chime with your key in the ignition & the door open? Chime stops when you close the door? If yes then the driver side door jamb switch is working.
    You have two doors, not likely for both door jamb switches to fail but again possible. If opening either door doesn't make the lamp turn on then it's probably the dome light switch. Take the lens off, you can see the connections. Test with a multimeter.
    HansWorldTravels likes this.
  9. Jun 29, 2018 at 7:13 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Did a little wheeling yesterday up near Silverton, CO. I've done a bunch of trails up there with my Dad in his Tacoma, but never in mine. Since I only live like a hour away, I figured why not. Excuse the smoke/haze in the photos, we've got a pretty massive wildfire burning up here.
    Clear Lake
    Views on the way to Clear lake. Trail was littered with tourists in rental Jeeps who have no concept of trail etiquette...
    This is at the summit of Hurricane Pass. Elevation 12,407 feet.
    Coming down off of California Pass. Elevation 12,960 feet.
    This is at Animas Forks, an old mining town north of Silverton.
  10. Jun 29, 2018 at 7:15 PM
    Speedytech7
    Really not sure what it could attach to if it doesn't supply a bar of some sort.
  11. Jun 29, 2018 at 7:15 PM
    eon_blue
    Azusa, CA
    Could be, just odd they don't mention that anywhere...but given the overall clarity and grammar of the instructions in general I'm not too surprised lol. Anyhow I think I'm getting it to work by using the supplied crossmember as the rear crossmeber....only issue is that the welded plates for my sliders are just every so slightly in the way making it slightly not-flush with the frame, but I think it'll still work.
    Prayn4surf likes this.
  12. Jun 29, 2018 at 7:15 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Generally they're called door jamb switches. IIRC Toyota calls them courtesy lamp switches.
  13. Jun 29, 2018 at 7:17 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Tape seemed fine, had a nice crisp line. Perhaps I sprayed it on too thick, too close to the tape. Meh, if I decide I like the look, I'll do it the way I know how, with real paint. But I do like the fact that if I don't like this, no harm, just peel and forget.
    Sperrunner[QUOTED] likes this.
  14. Jun 29, 2018 at 7:20 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Great pictures.
    aknickyota22[QUOTED] likes this.
  15. Jun 29, 2018 at 7:23 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Hey, hey, hey, I resemble that remark!!!
  16. Jun 29, 2018 at 8:33 PM
    eon_blue
    Azusa, CA
    Got it done, pretty snug fit....will see how it holds up on the trail tomorrow.
    Gonna be a huge pain in the ass when it comes time to do my t-case and transmission oils :bananadead:
  17. Jun 29, 2018 at 8:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah frank jumps up to around 2k. Lil truck is only around 1.5ish
  18. Jun 29, 2018 at 8:40 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    It was surprisingly easy. Six bolts, and unhook the taillight wires.
  19. Jun 29, 2018 at 8:55 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Got the bumper and rack dropped off for powder coat today.
    Also my truck runs out of gas at 338 miles of mostly highway driving :anonymous: I barely, just barely made it to the pump. Yes I know it’s bad for the pump and filter 8585FCD0-14E4-4320-825C-2B4FE0684341.jpg
  20. Jun 29, 2018 at 9:03 PM
    Prayn4surf
    Socal
    It looks REALLY good. I came to the same conclusion...too much money
    what did you use?? Edit: read your post my bad
