  1. Jul 9, 2018 at 5:37 AM
    1997tacomav6
    Denver
    The other great thing about these skid plates is if you drop a bolt or screw driver or wrench in the engine Bay Area you have access from the side or center access hole in the center of the skid plate.
    The stock skid plate has to be removed if you drop anything in the engine Bay Area.
  2. Jul 9, 2018 at 6:10 AM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Spent all day pulling it home on a stupid uhaul because...
    One mile into our 8 hour trip home getting on to the freeway, shift into 5th gear, let the clutch out and boom... either the clutch gernaded or I blew the input shaft on the trans... had no clutch slip before that. Had 120k on an oem clutch. Something just let go.. A guy stopped and pulled us off the freeway and we grabbed a stupid garbage towing uhaul and drug her home.. Good thing for the winch or we wouldn’t have gotten the pig on the trailer.
    Never go full Monte..
    BYJOSHCOOK and BurntTaco14 like this.
  3. Jul 9, 2018 at 6:49 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    that sucks, least you can get her home
  4. Jul 9, 2018 at 6:53 AM
    1997tacomav6
    Denver
    Sucks, and only 120k, Mmmm my clutch lasted 250k and original transmission at 565k,
    Hopefully it’s something else as these items usually last a lot longer than 120k.
  5. Jul 9, 2018 at 7:16 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    my friend had all the tools except the belt tension guage. Ill end up buying it cause im curious about my power steering belt. All in all with water coolant auto trans fluid n parts, $450 plus or minus. If i did it myself which im definitely going to do next time. Id prob spend close to what @turbodb spent with tools and parts.
  6. Jul 9, 2018 at 7:43 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    A little bit. We scored a 4 day time share hence we left the taco at home sad . 4 day’s wasn’t enough time we’ll be going back for sure. Slc local but wouldn’t mind living there ! Got out of town a couple of the days for sure. You’re stoked to so close to there!36530DF7-E945-4655-BF3C-FDD9A5351CC6.jpgABB4779D-7018-4543-BA85-B9C7BD3DF9B1.jpg
    Keep on Truckin' and BYJOSHCOOK like this.
  7. Jul 9, 2018 at 7:45 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  8. Jul 9, 2018 at 8:13 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Took off the camper shell so I could put the RTT on in a few weeks. Then washed it and promptly put it back in the garage after a short drive. Then washed the daily. Got some plans for the truck here soon :spy:
    Titus94, SwampYota and jubei like this.
  9. Jul 9, 2018 at 8:13 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    ah the mythical pissing rocks you hardly see those in the wilds lol. looked like loads of fun
    m3bassman likes this.
  10. Jul 9, 2018 at 9:03 AM
    Prayn4surf
    Socal
    Cheapest quote out of a toyota certified shop was 2k, toyota down the street wanted 2800 for the 90k service. It includes spark plugs n shit but i felt that was way waaaayyy too much. May have someone do the spark plugs cause i did that last time n it sucked.
    If you can have it done w parts for under 1k it might be worth it, but if you spend the 800 on parts n tools...next time it will be half that. Its only 8-10 hrs of your life hahah n some cash
    Dan8906 likes this.
  11. Jul 9, 2018 at 9:20 AM
    Prayn4surf
    Socal
    That is a valid point, im at 180k so it makes more sense for me, may not in your case.
  12. Jul 9, 2018 at 9:27 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    That’s how I feel, fingers crossed it’ll go another 30k
  13. Jul 9, 2018 at 9:29 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Holy shit, they charge $2K for timing belt job at the dealer?
    How many miles do you have?
  14. Jul 9, 2018 at 9:29 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Shit I hope, at the rate I've been putting miles on my truck I'll hit 300k in 2020. I'm averaging 20k a year.
    Prayn4surf and m3bassman[QUOTED] like this.
  15. Jul 9, 2018 at 9:30 AM
    JKO1998
    Utah
    Just about 270k
  16. Jul 9, 2018 at 9:33 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Why do you say fingers crossed for another 30K, does the engine feel sluggish or unreliable in some way? Just curious, I have 214K now and mine feels like it still putting along perfectly fine.
  17. Jul 9, 2018 at 9:34 AM
    JKO1998
    Utah
    Rust
  18. Jul 9, 2018 at 9:34 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I still haven’t hit 90k... but im almost there, debating if i wanna do it my self or not
    Dan8906 likes this.
  19. Jul 9, 2018 at 9:38 AM
    1997tacomav6
    Denver
    Haha I can tell you YES it will, 568,00 and counting
    jubei, nw_chris, Prayn4surf and 2 others like this.
  20. Jul 9, 2018 at 9:49 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
