  1. Jul 9, 2018 at 10:59 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    That's a really good CV axle hack I got to put that in my tool box lol
  2. Jul 9, 2018 at 10:59 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Do share my friend :)
  3. Jul 9, 2018 at 11:04 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Not sure if 95.5-00 & 3rd gen 4 runners actually have more room but for 01-04, using that airaid tube as is would leave no room for the couplers to flex with the engine & I'm sure it would cause the stock air box to crack.
    My stock tube was no longer soft & very flexible anymore, when that happens the tube starts cracking which is common on lots of other cars. I suppose it would be possible to cause the air box crack instead of tube.
  4. Jul 9, 2018 at 11:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    So you'd have to make your own shorter air tube but that's an easy fix you can do at home in 30mins. But they have bolt on necks for making your own pod filter setups that you could just bolt to where the neck has broken off. After that you can use a coupler to a aluminum MAF holder (fairly common just have to get the right size so the metering stays the same), then it's smooth sailing to use a shorter pipe to connect to the TB. If I had a vehicle with a 5VZ to mess with I could make a setup for people with broken boxes but I don't have access to one here so it would just be me futzing around with one for my 4cyl.
  5. Jul 9, 2018 at 11:08 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I can send you my stock 5vz air box with air tube if you want. If it works I'll gladly compensate you and we get a repair guide for TW.
  6. Jul 9, 2018 at 11:11 PM
    Speedytech7
    Lemme put together a parts list, maybe we can make this happen.
    jubei and what road[QUOTED] like this.
  7. Jul 9, 2018 at 11:16 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I'll be more than happy to do it. And I'll get you some pictures of measurements from grill to throttle body for you. I'm assuming that will be different from a 5vz to the 4 cylinders. But pm me when you're ready :)
    Speedytech7[QUOTED] likes this.
  8. Jul 10, 2018 at 4:09 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
  9. Jul 10, 2018 at 4:10 AM
    AZ4x4Taco
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Flips up for access and some random storage pouches. Made it more for my dogs then myself
  10. Jul 10, 2018 at 4:41 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
  11. Jul 10, 2018 at 6:00 AM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Found out why she wouldn’t move..
    Blue92 likes this.
  12. Jul 10, 2018 at 6:17 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    SwampYota likes this.
  13. Jul 10, 2018 at 6:18 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Damn son to many :burnrubber::mudding:lol
  14. Jul 10, 2018 at 6:52 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Instead of making that tool you could've just used the hook attachment on the slide hammer and put in on the CV and use it that way. Just food for thought next time.
  15. Jul 10, 2018 at 7:25 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    o_O
    Zam15, jubei, BYJOSHCOOK and 5 others like this.
  16. Jul 10, 2018 at 8:13 AM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I made a reply that somehow got lost, but to the same effect, I don’t know what the hell youre talking about hook attachment.
    I could have also wrapped wire around it or duct tape, instead, I fabbed something up that took minutes to make, is easy to use, is robust enough to take a beating and can be used on multiple vehicles.
    I guess you can do it your way, I’ll do mine. There’s your food for thought
  17. Jul 10, 2018 at 8:17 AM
    Laxtoy
    Maltby, WA
    That would make sense considering the climate
  18. Jul 10, 2018 at 8:37 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Seems like a lot of unnecessary aggression already floating around this morning.
  19. Jul 10, 2018 at 8:57 AM
    BurntTaco14
    BurntTaco14 Well-Known Member
    Andy
    Lewisville, TX
    2004 Black Tacoma 4x4
    2in Old man emu suspension Baja design ditch lights Cb radio Custom mesh grill SCS Ray10s 17x8.5in Cooper STT pros 255/75R17 Stubby antenna Led highlights
    :rofl:
  20. Jul 10, 2018 at 9:14 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Also thoughts of food..... I want a turkey sandwich now lol
    outlawtacoma likes this.
