  1. Jul 11, 2018 at 7:47 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    It’s horrid in Indy, nobody can drive worth a damn
  2. Jul 11, 2018 at 8:09 AM
    Wulf
    rock raisin
    Need to do some more trimming and fitting but getting there with the main hoop
  3. Jul 11, 2018 at 8:31 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Might also want to replace the fan clutch as well since you're already there. Adds an extra 85 bones to the parts list but IMO worth doing.
    https://www.amazon.com/dp/B00829HBEE
  4. Jul 11, 2018 at 8:36 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
  5. Jul 11, 2018 at 9:03 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  6. Jul 11, 2018 at 9:08 AM
    Area51Runner
    I don't know about failing but will say at 155k my original was starting to freewheel a bit. Didn't have that customary roar at startup either. Swapped it out and definitely can hear/notice a difference. I can't remember where I saw it but I do recall someone else on here mention changing it out with water pump. Anyway, up to you. Just wanted to throw it out there.
    Tim has some info on checking out the fan clutch.
    https://youtu.be/WzhlACxqeqQ
    Rocan, m3bassman and what road like this.
  7. Jul 11, 2018 at 9:25 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I plan on doing the WP, TB, valve cover gasket and champion radiator all at once sometime in the future. Should be a big endeavor, kinda putting it all off....
    jubei, what road and Area51Runner like this.
  8. Jul 11, 2018 at 9:38 AM
    eon_blue
    Azusa, CA
    Had to bleed my brakes late last night. A month back when I put in my SS brake lines up front, I accidentally reused my old banjo bolts not realizing the kit came with new ones that allowed more fluid to pass through. So I unbolted each caliper line last night and swapped them....in my naïveté I didn't realize that would mean that I'd then need to bleed the system and I nearly flew out of my driveway without any brakes when I went to move my truck lol. Good thing my e-brake isn't totally useless.
    Weird thing is though, this morning I've got a gnarly creaking sound coming from my front suspension/passenger side when it goes up/down...dunno why that would have anything to do with me working on my brake lines but I'm wondering if maybe some brake fluid spilled onto a bushing and corroded it some. Since it was so late and I was trying to bleed each wheel before bed, it did get a little messy. I sprayed some white lithium grease over the UCA and LCA bushings and the lower heims on my Kings and the noise went away, so I'm not sure which one was the culprit. Hoping I didn't ruin one of the bushings though.
  9. Jul 11, 2018 at 9:53 AM
    snotaco
    snotaco Well-Known Member
    Lewiston, Idaho
    2003 prerunner tacoma
    2003 tacoma double cab, prerunner, 4wd conversion, 5 speed conversion, dual cases with inchworm clockable adapter, toytec ultimate coil overs, trd supercharger with urd 7th injector, 37 inch mastercraft mxt's, arb front locker
    more information on this?? ive been trying to research this swap but so far the only person ive seen thats done it is front range off road on their 4runner.
  10. Jul 11, 2018 at 10:45 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    White looks good. I’ve been debating what color to paint my 5-lug for a while. Is that an OEM Toyota white, or something else? I noticed the 4Runner mirrors are a little off.
    FLBAdrian[QUOTED] likes this.
  11. Jul 11, 2018 at 12:30 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    replaced my O2 sensors today. Spent the day chipping away at the rusty nuts with a cold chisel. My hands are sore now.... but my p0141 is gone now yay!
    The worst thing was that there is no room to work, especially for the front sensor
    Area51Runner likes this.
  12. Jul 11, 2018 at 12:38 PM
    fortiz619
    fortiz619 yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    Some guy on my local offer up was selling a bed for 100 dollars I guess he had to remove it ASAP ,I was on my way to pick it up then a god damn flat tire, took a while to fix , the guy scraped it to the local dump , what an ass
  13. Jul 11, 2018 at 12:40 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    And this is why I have yet to fix this code. Owned the truck since 2016 and the lights been on since 2012 lol
  14. Jul 11, 2018 at 12:49 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I wish it worked like that. By the time I consider the cost of wear and rear on the truck and fuel when I drive out and back to Boise, pay for food and lodging for a couple days while they do the work... I'm right back in a similar price range.
    Glad to hear you're doing it yourself. I think you'll have fun!
    m3bassman[QUOTED] and Digiratus like this.
  15. Jul 11, 2018 at 12:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That sucks.
    I’m actually in the process of transferring the good bedsides from my existing bed to a donor bed that has a non-rusty deck on it. It’s really not that bad, just a lot of spot weld drilling and plug welding.
  16. Jul 11, 2018 at 12:53 PM
    onakat
    Canada
    2000 indestructaco!
    have you checked rockauto?
    won't harm the truck, but it will give you crappy MPG over time
  17. Jul 11, 2018 at 1:08 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    I found corner lights, I didn't even realize I posted that, I deleted it on my end then refreshed the page but I guess it posted anyway. Currently averaging 20.5 mpg which seems to be better than most that I have talked to.
  18. Jul 11, 2018 at 1:17 PM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
    Changed my Factor 55 FlatLink to an UltraHook
    Area51Runner and Teke like this.
  19. Jul 11, 2018 at 1:18 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I believe your masking tape hose just vents into the frame rail. The open nipple goes to the intake box.
    The extra part looks like the check valve that goes near the EGR. It could also be 4x4 vacuum related, but I'm not sure.
    Dalandser[QUOTED] likes this.
  20. Jul 11, 2018 at 1:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Thanks man - I haven't installed my airbox yet so that's why I haven't hooked up the other line. I've seen a video where a guy has that port I'm talking about just open to the atmosphere. I guess that's why it could vent to the frame rail w/o any problems. Weird it seems to be overlooked in a lot of vsv diagrams!
    I'm still not sure about the other part - it's a one-way valve and my truck wasn't equipped with egr... could be 4x4 :notsure:
