  1. Jul 15, 2018 at 3:40 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Second Saturday of every month it’s at IMS. Check out Indianapolis Cars and Coffee in Facebook and/or IG for updates and stuff. They have one every week at Gator Mototsports off Michigan Road and 96th Street as well although most of the older car crowd and stuff typically only go to IMS
  2. Jul 15, 2018 at 3:42 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Is this what you’re looking for? I used this part number to replace mine.
    Speedytech7 likes this.
  3. Jul 15, 2018 at 4:04 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
  4. Jul 15, 2018 at 4:17 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Ok... here's what I did.
    For the positive side.
    1) There's a white wire running in to the fuse box (8 guage) I cut the eye off the factory wire and spliced the pictured clear jacketed wire, with the red butt connector and used a piece of heat shrink to protect the connection. (make sure you get the wires all the way in the butt connector, and use your gorilla grip to make the crimp).
    2) The main cable from the alt is 4 guage. I bought the cable extender (pictured) at O'Reillys. I then cut the cable terminal, and small wire, off right behind the clamp. I got this one because it splices 4 guage with an allen screw. I didn't want to trust crimping 4 guage without the right tool (because THAT would be a mutherfuker).
    The connections to the positive side battery clamp are allen screw.
    For the negative side
    1) The body ground was too short (and thin, I think the factory one was just 8 guage). I had a piece of 4 guage amp wire that already had an eye crimped to it. I just cut it down to the right length.
    2) The main ground from underneath (the 4 guage ground) was actually long enough. I just had to unwrap some of the (factory) elect tape, on the main harness, to get enough slack.
    All of the connections to the negative side battery clamp are with an allen screw. (Note)
    These battery clamps are for positive posts. A positive post is slightly bigger than a negative. I used a post shim (pictured) to make it get a solid connection to the negative post.
    I tried to use as many allen screw connections as I could because I don't trust crimps (without the right tool).
    Prayn4surf[QUOTED] and SwampYota like this.
  5. Jul 15, 2018 at 5:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    too specific for TW standards. There will always be BS in every thread. And that thread will just get confused with this thread :p haha
    worth a shot.
    Crodell6 likes this.
  6. Jul 15, 2018 at 5:46 PM
    Gyrkin
    Wyoming
    You know I had all those same thoughts, but because I'm an eternal optimist I started the thread anyway. :p
    Sperrunner and Blackdawg[QUOTED] like this.
  7. Jul 15, 2018 at 6:19 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    I got my first Check Engine light! P0303 so I ordered new ignition coils...
    what road likes this.
  8. Jul 15, 2018 at 6:20 PM
    travis.diller
    Travis
    Kitsap Peninsula
  9. Jul 15, 2018 at 6:57 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    If you want it pm me.
  10. Jul 15, 2018 at 7:05 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Idek what it is lol
  11. Jul 15, 2018 at 7:25 PM
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    Well I finally got rid of the ugly chrome grille! I was planning on doing this to it but I’m too busy right now with “life” hahahah it’ll be up for grabs in a while. It’s only the center piece that I will be selling.
  12. Jul 15, 2018 at 7:36 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks brother!!!
    TacoYankee[QUOTED] likes this.
  13. Jul 15, 2018 at 8:01 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    no, everything is okay now :)
  14. Jul 15, 2018 at 8:11 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    So I was helping someone install a magnuson supercharger on an ‘04 v6, it’s drive by wire, we did everything correctly but there is a barb on the backside of the supercharger near the throttle body that we had absolutely no idea what to do with, it says it’s supposed to go to the vacuum throttle opener, but we don’t know where that is on a drive by wire truck, it runs and drives but the idle is really rough and it’ll die pretty quickly if you don’t stay on it. We blocked off the barb and it still made no difference. Any ideas?
  15. Jul 15, 2018 at 8:22 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Your pictures make me want so many things
    m3bassman[QUOTED] likes this.
  16. Jul 15, 2018 at 8:29 PM
    tony2018
    tony2018 Well-Known Member
  17. Jul 15, 2018 at 8:29 PM
    JKO1998
    Utah
    Like an RTT, cause they look way Overland, and a nicer camera.
    We percolate our coffee :notsure:, thats all I know other than the stuff you get from 711.
  18. Jul 15, 2018 at 8:33 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Pic? Think thats for the egr if you have it. If you dont thats where you run a 7th injector
  19. Jul 15, 2018 at 8:33 PM
    JKO1998
    Utah
    I hope you saw the sarcasm in the overland part haha
    But they do look like they’d be fun for stuff like that.
    No one in my family drink coffee, so we don’t have anything. I only drink it when I hunt/ work days in a row.
  20. Jul 15, 2018 at 8:55 PM
    eon_blue
    Azusa, CA
    Tagged my rear diff again today on the same rock on the same f****g trail as before :annoyed:
    Can't get a socket on it now at all...gonna see if I can maybe bend the metal out of the way with a screwdriver or chisel, unless anyone had any other ideas.
