  1. Jul 19, 2018 at 2:40 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Does your other window do the same thing given the same variables?
    If so then it's your window motor failing. Common issue on these trucks. If not then I'd grease your window tracks, guides, and motor drive with some grease.
  2. Jul 19, 2018 at 2:49 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Just the driver and now passenger back seat. Passenger front and driver rear works just fine.
  3. Jul 19, 2018 at 2:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I would take the window regulators out of both driver’s doors and grease the gear drive of the motor, and the points of friction like the joints. Clean the window glass runs too. If it still does the same thing then it sounds like your master switch could he at fault or your motors are failing. I suspect master switch because two on the same side is unsual.
    SilverGhost[QUOTED] likes this.
  4. Jul 19, 2018 at 3:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think there is one more parameter that should also be considered when troubleshooting stuff like this. That is the tires.
    My 14" 700# coils on Kings were awesome with 15" C-rated tires (much like you are describing now with your icons). Not so much now that I have gone to E-rated tires and a wheel combo that weighs and additional 8.5 lbs more overall.
    turbodb likes this.
  5. Jul 19, 2018 at 3:16 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm of the opinion 700# is overkill unless you have a 100' steel winch line or 1/4 skids, maybe an extra two batteries. Something with substantial extra weight, a steel bumper and typical winch isn't enough in my mind to get to 700# coils, especially in @Dan8906 case, cause the AP bumper is especially light. My icons felt very nice last time out on my e rated KO2s as well
    Tires are something to consider, but properly matched springs and shocks should be able to make that a non issue.
    BYJOSHCOOK likes this.
  6. Jul 19, 2018 at 3:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I went directly from one to the other. I also went from awesone to less that awesome with that change. In my configuration its the tires.
    All I am saying is it is a factor that should be considered in the discussion.
    turbodb likes this.
  7. Jul 19, 2018 at 3:23 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Maybe ill add an extra battery instead of getting softer springs lol I also have KO2s
    Speedytech7[QUOTED] likes this.
  8. Jul 19, 2018 at 3:29 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    This is why we're going to get the tools to revalve or own stuff; 'cause I have the same problem.
    6 months :fistbump:
  9. Jul 19, 2018 at 3:30 PM
    Speedytech7
    I think I said this to you when we last saw each other, but I think it might be time for a revalve in the front, those tires you had could totally imitate softer suspension than you actually have
    Oh man, that's the dream, I hate this being one of the things I cannot do easily at home. Need that nitro rig and a big stockpile of shims
    turbodb[QUOTED] likes this.
  10. Jul 19, 2018 at 3:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Speedytech7[QUOTED] and turbodb like this.
  11. Jul 19, 2018 at 3:34 PM
    Speedytech7
  12. Jul 19, 2018 at 3:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
  13. Jul 19, 2018 at 3:38 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I have they HREW 4x sliders. I have beat on those things . i do have a nasty dent in one, but so far so good. They do the job
    I have some stock ones with 2 inch pucks if you wanna borrow.
    My passenger side doesnt roll up without someone hitting the passenger switch and me hitting the master....strange
  14. Jul 19, 2018 at 3:38 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    About those bumpstops. Are the wheelers suppose to go in the rear too? I have them in the front
  15. Jul 19, 2018 at 3:39 PM
    Speedytech7
    Clean your switch contacts, really easy to take the switch apart and spray the contacts down, they corrode and get arc fouled
    Fernando[QUOTED] likes this.
  16. Jul 19, 2018 at 3:39 PM
    Speedytech7
    They aren't even supposed to go on our trucks
  17. Jul 19, 2018 at 3:42 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Do i need to take the door panel off?
    Lol...oops. No wonder i split one. Haha
  18. Jul 19, 2018 at 3:43 PM
    Speedytech7
    Nah, just pop the switch portion out and take the back cover off of it to reveal the innards
  19. Jul 19, 2018 at 3:44 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks man. Gonna have at it this weekend. Shits been buggin me
  20. Jul 19, 2018 at 3:51 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Agreed.
    My truck is pretty heavy, and I have 650lb coils on my ADS coilovers.
    Also just had them revalved stiffer on the compression side and love it. D rated tires. Speaking of which @Blackdawg - standard progressive piston for rebound/compression.
