  1. Jul 23, 2018 at 9:07 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Yeah I got that harness, I think you mentioned it once before when I asked what headlight you were running. Those are the only aftermarket headlight that didn't seem to break the bank and didn't look like garbage lol
    Speedytech7[QUOTED] likes this.
  2. Jul 23, 2018 at 9:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The ones that these ones we have are based off of are from Rigid industries and are about $375 a pair
  3. Jul 23, 2018 at 9:21 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    $100 was like the max I'd spend. I have plenty of money but didn't feel like dumping it into headlights on my truck when I could more wisely use that money
  4. Jul 23, 2018 at 9:37 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Reh5108 likes this.
  5. Jul 23, 2018 at 9:37 PM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    The additives would be for the clutch packs in the limited slip your elocked doesn’t have any clutches
  6. Jul 23, 2018 at 9:46 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Almost every truck had the same 5x7 chrome/glass headlight, it's just a very 80-90s look. I don't hate the 5x7 look just wanted to get away from the chrome look I guess. These just look a lot more modern https://www.amazon.com/dp/B074LT5B1M
  7. Jul 23, 2018 at 11:17 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Manual states 75w-90 for front diff, 80w-90 for rear diff. LSD was not available on 1st gens so no additive needed.
    But In the past I've alwaysed used Mobil1 75w-90 synthetic, my stock gears still looked good at 215K mi.
    I actually just replaced rear diff oil (& trans) today. Just finished running break in on my new gears. I'm using Lucas 85w-140 dino from now on.
  8. Jul 23, 2018 at 11:24 PM
    Phessor
    Phessor Well-Known Member
    That is what I just went with after my gear change.
    zero4[QUOTED] likes this.
  9. Jul 24, 2018 at 6:25 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The Truck-lite version is $184 each. I've heard good things but it's not worth $370 for headlights to me. For that much I could retro HID projectors that will easily outperform any LED setup for 200mm headlights.
  10. Jul 24, 2018 at 6:35 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    K, another steel bumper question,
    Do all your bumpers have a little mounting bracket like trail gear uses?
    Or do just use the bolt holes on the frame?
  11. Jul 24, 2018 at 6:37 AM
    JKO1998
    Utah
    Well I guess this is a different thread then I started in, oh well.
  12. Jul 24, 2018 at 6:54 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No. Most plate bumpers you have to modify your frame horns. Trail gear is the only one with the adapter for both gens.
    Pelfrey built will have a specific one for 98-00 similar to how cbi does.
  13. Jul 24, 2018 at 7:03 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    My ‘98 has the weird frame horns, so Relentless Fab provided special frame caps to cut and weld onto the stock frame horns. This appears to be only an issue on the 1998-2000 model revision.
  14. Jul 24, 2018 at 7:29 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Ordered up the Idler pulley. Tired of hearing it squeal when it gets dirty.
  15. Jul 24, 2018 at 7:56 AM
    JKO1998
    Utah
    I’m thinking about building one, my friend welds for a living and has some access to steel at work, so make make a half way decent looking one, no winch mount or anything.
    I guess really anything would be better than the stock one.
    Ya so does my 99
  16. Jul 24, 2018 at 8:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    if you build a custom one, do whatever you want. Hell you can buy the adapter from trailgear for your starting point if you wanted.
  17. Jul 24, 2018 at 8:28 AM
    JKO1998
    Utah
    Guess I could do that huh, when I swapped my deer bumper for a new to me bumper yesterday it made me miss the old TG I had haha.
  18. Jul 24, 2018 at 8:48 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Or weld it straight to frame but I think that's illegal in some areas.
  19. Jul 24, 2018 at 8:50 AM
    JKO1998
    Utah
    I’d like something easily removable
  20. Jul 24, 2018 at 9:42 AM
    JKO1998
    Utah
    Bumpers swapped and turn signals working again.
    No more nasty faded hercliner
    983E8863-782D-422B-AD7D-49627D9903EB.jpg E39FCC73-65E1-4DD0-BA28-225E105D9176.jpg
    Now I just need to find a bro bar
    And a headlight/ sidemarker thing
    SwampYota and LukeCC like this.
