  1. Jul 30, 2018 at 3:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    that looks great
    zero4[QUOTED] likes this.
  2. Jul 30, 2018 at 3:19 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Thanks! Yeah, I think I'm just used to seeing polished wheels on my truck for so long. My last set were polished too. Time for a change!
  3. Jul 30, 2018 at 3:20 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    if you don't want them you can have my steel wheels :p
    zero4 likes this.
  4. Jul 30, 2018 at 3:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I run mine w/o center caps
  5. Jul 30, 2018 at 3:37 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Hmmm may just have them press it apart then...thanks buddy appreciate it! I do weld also! Can you post up a pic of your contraption?
  6. Jul 30, 2018 at 4:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    looks great. Love the color choice.
    Fernando and zero4[QUOTED] like this.
  7. Jul 30, 2018 at 4:49 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    So I know this topic may have run it’s course; however, I’m still kind of new here. Are there any Gen 1 folks out here who have had their frame replaced for significant corrosion beyond surface rust, but not the “typical” 10mm hole in the frame? My frame is covered until 12.15.2018. Although I don’t have any holes, I have significant rust on the frame and deformation of cross members, (pitted and thinned). The rear of the frame (near the spare tire area), looks like it hadn’t been treated. Like someone sprayed everywhere else bot that area. The end of the frame near the hitch is flaking away. Just looking for any first hand info. If anyone has experience with this, I’d appreciate your feedback.
  8. Jul 30, 2018 at 4:58 PM
    eon_blue
    Azusa, CA
    Have you taken a ball peen hammer to rusty spots on the frame? That's what Toyota does to test for holes...it sounds like you would probably end up with a few if you were to do that. Or take it into Toyota to have them inspect it, they'll test it with a hammer and if any holes come about from the hammer test then you're golden.
  9. Jul 30, 2018 at 5:32 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    Yeah, I’ve taken it in early last year and it passed, barely. I’ve been hitting the areas with a hammer and only get pieces coming off, no holes. Parts of the frame are pretty solid in some areas, except the cross members and the end of the frame...but no holes.
  10. Jul 30, 2018 at 5:39 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    maybe it's time to make holes
    Teke and TacoYankee[QUOTED] like this.
  11. Jul 30, 2018 at 7:21 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Starting on the corner light mod tonight
  12. Jul 30, 2018 at 7:34 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have one of these spare if @cynicalrider needs one. I popped it out when I swapped to a solid manual hub axle tube from ADD.
  13. Jul 30, 2018 at 7:51 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    False
  14. Jul 30, 2018 at 8:03 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    :rofl:
    That would be called HWD (half wheel drive).
  15. Jul 30, 2018 at 8:26 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Beautiful...so jealous!
    m3bassman[QUOTED] likes this.
  16. Jul 30, 2018 at 10:51 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Got lots done tonight. Rerouted air intake, finished off the bob job, put the signals into the markers, got new headlights and markers, painted the grille black, seam sealed the drivers tub job, and a couple other little things I forget. I need to get my hands on an older Toyota washer fluid bottle.
    jubei, david9kelsey, ToyRyd04 and 6 others like this.
  17. Jul 30, 2018 at 10:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Like this https://www.ebay.com/ulk/itm/272835820599
    Prayn4surf likes this.
  18. Jul 30, 2018 at 10:54 PM
    Spoonman
    Jamie
    Alberta
    Yup. Gonna search local junkyards during work if I get a chance. I’ve never had good luck with eBay stuff.
  19. Jul 30, 2018 at 11:08 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Or this style. This one should bolt right up behind the air filer box if you don't have the cruise control box. 03 is drive by wire so I believe you don't have the cruise control box like on 01-02.
    https://www.ebay.com/itm/Windshield-Washer-Reservoir-Bottle-with-Pump-for-95-00-Toyota-Tacoma/310801491979?hash=item485d36680b:g:QrAAAOSwE8dadClq&_sacat=0&_nkw=2001+tacoma+washer+bottle+cold&_from=R40&rt=nc&LH_TitleDesc=0
  20. Jul 31, 2018 at 5:40 AM
    DawsonDestroyer
    DawsonDestroyer Well-Known Member
    Dawson
    Oklahoma City, Oklahoma
    2002 Tacoma Prerunner Double Cab
    Put on some new rotors and pads last night :burp:
