  1. Aug 7, 2018 at 12:10 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Don't go too hard on the grease for those any resistance and the zerks will pop out of the bolt as they're only press fit, they aren't tapped and screwed. If they pop out you'll have to get new bolts or tap the hole and screw a zerk in.
  2. Aug 7, 2018 at 12:24 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Looks like Daystar sells their own flavor. The tubes are for mini grease guns. Even more expensive than the ES stuff. I have no experience with this Lubrathane stuff though, just saw it on Amazon.
    https://www.amazon.com/Daystar-Univ...pID=41r6UH9K4DL&preST=_SX300_QL70_&dpSrc=srch
  3. Aug 7, 2018 at 1:01 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Nice link, never saw that before. Seems like silicone based lube is recommended for poly bushings but there are a number of other companies that recommend the standard Super Lube synthetic grease which is not a silicone based grease.
    I have 3M silicone paste that I use for other stuff & it's really thick & tacky, way thicker than the ES Formula 5 stuff, the name paste suits it well. I ordered a tub of Formula 5 to use on my bushings that don't have zerks.
    I wonder if Super Lube's silicone grease is as thick & tacky as Formula 5. I suspect no since it's available in tubes for grease guns. I'm starting to think that the the tacky silicone based greases that come with poly bushings might be too thick to pump through zerks & is why they don't come in tubes for grease guns?
    eon_blue likes this.
  4. Aug 7, 2018 at 1:20 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Not going to claim this is the solution for everyone, YMMV - it worked for me so far. Now I completed my install about a week ago, time will certainly determine if it 'worked'. As for pumping the ES Grease, worked fine when I filled my gun and used it on my OME Greasable shackles.
    Just bulk load the gun's tube. Again, tacky as they come and messy but it is possible. I imagine that Daystar tube is going to be just as tacky as the ES lube. Anyway, it is possible to bulk load that ES grease using that little 8oz. (its messy! - wear gloves)
    So here is what I would do - use the grease that the bushing manufacturer either supplies or says to use (more than likely its their grease). :)
    For those that don't know how to bulk load a grease gun, this is essentially the process.
    https://youtu.be/7alXII2wWtY
  5. Aug 7, 2018 at 4:39 AM
    Phessor
    Phessor Well-Known Member
    I applaud you, I have not taken on a project like that in years, great job.
  6. Aug 7, 2018 at 9:05 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I use the bed a lot. I’ll likely only keep the spare up there when I’m on trails though. I did think about doing an under mount though
  7. Aug 7, 2018 at 2:32 PM
    Tripod
    Tripod Well-Known Member
    I got my starter replaced today. She is back on the road!
  8. Aug 7, 2018 at 2:36 PM
    eon_blue
    Azusa, CA
    I hope he's referring to a 1st gen though...would suck to have to replace the starter on a brand new turd gen
  9. Aug 7, 2018 at 2:36 PM
    Tripod
    Yes... I know this. I replace the starter on my first gen Taco. Hence the reason why I post it here.
    Edit* I understand why you made that assumption. I know..... I need to change my profile pic. I hate that turd gen and I will be selling it back to the dealer this week!!
  10. Aug 7, 2018 at 2:36 PM
    Tripod
    Yes. That is exactly what I was referring to.
    eon_blue[QUOTED] likes this.
  11. Aug 7, 2018 at 2:41 PM
    Tripod
    Thank you sir! (Bows in a gentlemanly way)
  12. Aug 7, 2018 at 2:53 PM
    Tripod
    There. Picture fixed!
  13. Aug 7, 2018 at 2:59 PM
    Speedytech7
    Nice RoadGlide, kinda miss my Road King
    Tripod[QUOTED] likes this.
  14. Aug 7, 2018 at 3:00 PM
    Tripod
    Thank you, sir! Ive had her for about 3 months now. Almost 4k miles on it. I LOVE this bike. Had a SG before this and a Slim S before that. This is by far the best bike.
    Speedytech7[QUOTED] likes this.
  15. Aug 7, 2018 at 3:10 PM
    Speedytech7
    I haven't ridden a Harley that I didn't enjoy. The road King was like riding a couch, except I could scrape pipes pretty easily turning haha. My family has lots of Harley's, just wanted something lighter for quick trips since I don't do any long rides anymore.
  16. Aug 7, 2018 at 3:12 PM
    Tripod
    So what did you get?
  17. Aug 7, 2018 at 3:16 PM
    Speedytech7
    Haven't bought anything yet, looking to get a Yamaha WR450F when AZ starts to cool off again
    pairodice and Tripod[QUOTED] like this.
  18. Aug 7, 2018 at 3:18 PM
    Tripod
    Ah! Dirt bike route. Very nice.
  19. Aug 7, 2018 at 5:52 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    I attempted to finish the driver side front-end work. But I ran into two roadblocks. First I couldn't detach the brake line from the flare nut. I got it loose all the way but it would not detach so I just reconnected the old brake line. has anyone run into this problem?
    Second I didn't realize that my lower shock bolt is completely stripped.
    Should I go to the dealer and buy one or order one from Camelback? Please advise thank you. I have roughly two weeks to finish this job.
    HCFab, SwampYota and Teke like this.
  20. Aug 7, 2018 at 6:05 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    that frame, its soo clean...
