  1. Aug 10, 2018 at 1:13 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I used the novita ep35c with zero issue
    License2Ill[QUOTED] likes this.
  2. Aug 10, 2018 at 1:13 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You put an aftermarket sunroof into your truck? Gotta hear more details about this.
  3. Aug 10, 2018 at 1:19 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Where'd ya pick it up at?
  4. Aug 10, 2018 at 1:20 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Amazon prime. But ive seen novita stuff at orileys before but idk about the relay
  5. Aug 10, 2018 at 1:27 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    No, not in my truck, though I have considered it. It was a little Dodge Neon that was my son's first car. I made a pattern of the opening from the junker, laid that out on the top with tape, drilled a hole, and used a sabre saw to cut it out. Just kept putting tape across the cut as I went, so the cut out didn't try to cave in as I got close to the final cutting. Cut out the headliner to the size of the opening, silicone caulk around the edge, and screw the two pieces together. I had watched a shop install one in my '82 Toyota truck, so I had an idea of what to do and not do.
  6. Aug 10, 2018 at 1:39 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Sounds like you pissed them off or rubbed them the wrong way. My discount guys always take care of me and have never seen them check how many threads go on the stud. Hell they have even dismounted and mounted tires for free so I can get the tires warrantied by 4 wheel parts.
    Digiratus likes this.
  7. Aug 10, 2018 at 1:52 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Is he talking about the same store?
  8. Aug 10, 2018 at 2:07 PM
    malburg114
    Las Vegas, NV
    Probably not but just saying that out of all the discounts I've stopped at and even my local regular one they've taken real good care. But I also normally talk and bs with them for a little
  9. Aug 10, 2018 at 3:03 PM
    tony2018
    tony2018 Well-Known Member
    I'll take a look at mine when its not roasting outside.
  10. Aug 10, 2018 at 3:22 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    So December
    FLBAdrian likes this.
  11. Aug 10, 2018 at 3:23 PM
    tony2018
    8pm...sheesh.
  12. Aug 10, 2018 at 3:25 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Damn I can't believe how easy that was to take out thanks to that TTORA thread. 10 mins & I had it sitting on the table.
    Also can't believe how much of a difference it made. So little play felt in the shaft but much more noticeable on the steering wheel.
    My steering wheel play is completely gone now, this & the steering rack guide did the trick. So happy right now.
    jubei, SwampYota, BYJOSHCOOK and 4 others like this.
  13. Aug 10, 2018 at 3:28 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    About to pull the trigger on this stuff, am I missing anything? My aal snapped on the passenger side so I’m gonna get:
    Dakar cs046’s
    OME greasable shackles
    OME rear bushings
    Toytec u bolt flip kit
    And center pins
    ^all from wheelers for ~$700 after shipping
    I’ve got a little extra weight in the bed but nothing crazy, just a cap and drawer system that’s empty most of the time.
    I can run Dakar’s with normal OME rear shocks right? I’m probably not gonna be too elaborate with the relocate yet until I get longer shocks, box the frame, and get a manual bpv
  14. Aug 10, 2018 at 3:37 PM
    tony2018
    you mean nitros right?
    Lux[QUOTED] likes this.
  15. Aug 10, 2018 at 3:47 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    Yes
  16. Aug 10, 2018 at 3:55 PM
    tony2018
    yeah, shouldn't be a problewm
  17. Aug 10, 2018 at 4:01 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Not sure if Wheelers has them, but I woud grab the greasble bolt/bushings for the front spring hangers by Daystar. They will help with the creaky/squeeky Dakars
    Also I would look into the aal for the Dakars, mine sagged a good bit just with an rtt and 2 bed bars. Drawers and a shell might cause some sag
  18. Aug 10, 2018 at 4:13 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    I was actually afraid they’d be too stiff, I’ll look into it though, thanks. What shocks are you running and are they in the stock location? Just curious for future reference
  19. Aug 10, 2018 at 4:16 PM
    tony2018
    brake signal doesnt go through the flasher relay.
  20. Aug 10, 2018 at 4:18 PM
    tony2018
    hm, noted for future reference.
