  1. Aug 10, 2018 at 4:18 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I’ve never had a problem with them before so idk why they decided to get picky this one time. It was a newer younger guy this time but I was still bullshitting with the techs in the back since I knew a few of them. Oh well. They are now on and look good
    rngr, SwampYota, BYJOSHCOOK and 2 others like this.
  2. Aug 10, 2018 at 4:20 PM
    tony2018
    tony2018 Well-Known Member
    looks good
  3. Aug 10, 2018 at 4:21 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Mind posting that link? Thanks.
  4. Aug 10, 2018 at 4:30 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Sliders turned out well also
  5. Aug 10, 2018 at 4:33 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Looks great! :cheers:
    Teke[QUOTED] likes this.
  6. Aug 10, 2018 at 4:36 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I’m afraid I’m going to have to end up doing some cutting as well. The Ko2s seem to be bigger than my Kos.
    One question though.
    I’m assuming your older Ko2s where load E as well as BFG decided to forget about the millions of smaller size trucks running 16s. But how do your 265 load E ride compared to the 285 Es? I would think that the 265 E would be super harsh since there’s less sidewall.
  7. Aug 10, 2018 at 4:42 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    0y
    Could try fluid film or some rubber / plastic in the friction areas...
  8. Aug 10, 2018 at 4:46 PM
    SwampDeer
    SwampDeer Active Member
    99 Tacoma 4x4
    3 inch lift.
    Cut out sway bar links with a grinder.
  9. Aug 10, 2018 at 4:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Thanks. Got some zone stuff instead. About the same price with a 3 year warranty on the rotors and a lifetime :confused: warranty on the pads. Figure a big change wouldn't happen unless doing the Tundra swap.
  10. Aug 10, 2018 at 4:58 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Since you have an 02 (w/ tilt column I assume), follow post 42 instead of post 1, if you have a welder you can finish the job in 30mins rather than 2-3 hrs. For 97 & older or with no tilt you have to take everything apart like in post 1.
    Took me about 1.5 hrs from start to finish which included driving to 2 different welding shops. I have a cheap flux core welder that someone gave me but I'm not a welder so I just payed $10 to have it tacked. I was so happy I drove back to the welder & brought him a 6-pack for tig welding it (mig is perfectly fine) & for doing it right away.
    quetzal[QUOTED], jubei and Seagull233 like this.
  11. Aug 10, 2018 at 4:59 PM
    SwampDeer
    99 Tacoma 4x4
    3 inch lift.
    Dalandser[QUOTED] likes this.
  12. Aug 10, 2018 at 5:06 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I was thinking of adding nylon washers, I just don’t know how long they would last.
  13. Aug 10, 2018 at 5:37 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Is that Pepboys?
  14. Aug 10, 2018 at 5:51 PM
    tony2018
  15. Aug 10, 2018 at 5:55 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Sperrunner likes this.
  16. Aug 10, 2018 at 5:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  17. Aug 10, 2018 at 5:57 PM
    License2Ill
    Ian
    Yeah, I know. But they share the same ground point. I'm glad it didn't turn out to be a wiring issue!
  18. Aug 10, 2018 at 5:58 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Maybe he meant me but i dont see how he confused that
  19. Aug 10, 2018 at 6:00 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I actually helped my buddy with changing his brake pads on his Ranger. And he said the dude at Vatozone said his brake pads were under a lifetime warranty. Which makes no sense, they’re essentially a wear item haha. Hopefully my Vatozone pads are under lifetime warranty too
  20. Aug 10, 2018 at 6:02 PM
    JKO1998
    Utah
    I had led turn signals up until like last week, but not anymore.
    Sperrunner[QUOTED] likes this.
