  1. Aug 13, 2018 at 10:49 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I see. I hear a lot of coilovers don't include the spanner wrenches anymore which doesn't make sense to me.
    I just placed my order for the greasable shackles & eye bolts along with Wheelers super bumps for the rear. I decided not to get that 1/2" shim.
    Anyone know how much taller the Wheelers bumps are compared to stock (so I assume)? I'm running Deaver J59s, is it best to run one of their spacers for the bumps? I didn't buy any, figure I'll just machine my own.
  2. Aug 13, 2018 at 10:51 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Damn that BPV bracket looks nice, never knew they existed. Easy to just make your own. Drilled 4 holes, tapped two, bolt right on in 10mins.
  3. Aug 13, 2018 at 10:53 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    digi-key or mouser
  4. Aug 13, 2018 at 10:54 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    I don't have one, not sure what there for lol
  5. Aug 13, 2018 at 10:55 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Idk for sure, like I said, Im too lazy to really care. If I did do any real offroading Id be chopping it.
    eon_blue[QUOTED] likes this.
  6. Aug 13, 2018 at 10:57 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    If you really want one, I have the OME bracket that I had on my truck. I'll ship it out to you for free if I can find the stupid thing. I ended up just chopping my exhaust because, even with the bracket I was getting contact between the leaf spring and the exhaust.
    It will need some nuts and washers to replace the welded-on nuts that broke off.
    Yeah I had the FK21 relocation bracket on my truck and I still managed to make contact with the exhaust and the leaf springs... so I just chopped it off lol it's a much better solution.
  7. Aug 13, 2018 at 10:58 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Strange. Mine has the bolts with nuts. Must be a change made by year.
  8. Aug 13, 2018 at 10:59 AM
    eon_blue
    Azusa, CA
    Same here, though I never installed it. I was getting my truck worked on at a local fab shop and just told the guy to cut the damn thing off, lol. Glad I did, except that it meant losing my TRD tail pipe which makes my truck sound quieter now. But it's worth not getting it hung up on rocks and having it swing around like crazy because the rubber hangars were always tearing.
  9. Aug 13, 2018 at 11:01 AM
    eon_blue
    Azusa, CA
    When you lift the rear of your truck, the brake proportioning valve (BPV) isn't sensing loads the way that it was designed to when the truck sits at stock height. Meaning it throws off your rear braking ability. Usually not by much, but the higher the lift the more it's effected. You might start noticing that your truck isn't braking as quickly as it once was. The BPV relocation bracket moves the BPV up so that it can sense loads the way it was designed to and braking improves.
    Not like the rear does a whole lot for braking anyway, but I noticed a small improvement overall after putting mine on. They're cheap and only take a few minutes to install.
    Area51Runner and SwampYota like this.
  10. Aug 13, 2018 at 11:02 AM
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    My exhaust dumps right at the axle. From what I was told by the smog shop in the next two years you’ll need your exhaust to extend all the way to rear end similar to a stock setup. For California at least.
  11. Aug 13, 2018 at 11:05 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Ok I'll buy that with my sliders next check
  12. Aug 13, 2018 at 11:06 AM
    eon_blue
    Azusa, CA
    shit I hope that isn't true. Good thing I kept the part that got cut off I guess.
    Sperrunner likes this.
  13. Aug 13, 2018 at 11:14 AM
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    It probably will be. The smog shop gave me a speech on why mine won’t pass next time.
  14. Aug 13, 2018 at 11:14 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    It's for the rear brake proportioning valve that adjusts brake pressure when you have load in the bed. Some say they feel a difference extending it to length with added lift but I couldn't really tell a difference. But then again I rarely tow or haul heavy loads.
    Edit: n/m I type too slow
    what road[QUOTED] likes this.
  15. Aug 13, 2018 at 11:17 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I'll still get one. Best be prepared for braking when I have camping gear loaded up lol
    zero4[QUOTED] likes this.
  16. Aug 13, 2018 at 11:21 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    It's really easy to make. Measure how much lift you have over stock, get a piece of flat bar & drill the second set holes according to how much lift you have. I threaded the second set of holes on the flat bar so it would just bolt right on but you can just use nuts also.
  17. Aug 13, 2018 at 11:25 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    they are supposed to compress to stock length. Maybe slightly above stock. The rubber is super soft compared to the stock one thats hard as cement. So even though it looks taller. It compresses down big time. Not sure about the deavers.
  18. Aug 13, 2018 at 11:27 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Looks like I’ll have to take the Sawzall out. Thanks guys!
    Prayn4surf[QUOTED] likes this.
  19. Aug 13, 2018 at 11:27 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Those BPVs don't work very well anyways.
    Just cut the rod and zip tie it all the way up for maximum rear brakes. Or better yet swap it for a manual valve.
  20. Aug 13, 2018 at 11:33 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I think I’ll just chop the damn thing off after the axle. Thank you though!
    lambo[QUOTED] likes this.
