  1. Aug 17, 2018 at 11:07 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Haha. I'm not the type to post a lot but I also was away for like 6 yrs. The black hole I got sucked into was another hobby that cost me much more money than the mods for my truck.
  2. Aug 17, 2018 at 11:07 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I thought the same. then I went back in my files and found a pic of mine. Look about the same.RJqwqd1wKlZMWKfHGjbgB58USkIRnxeckgeiOefi_66c0b83399a6cf61516331614cb2d9b070d21e82.jpg
  3. Aug 17, 2018 at 11:09 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    With no flares it looks higher, well more gap in the wheel well anyway.
    razilla76 and Running Board Man like this.
  4. Aug 17, 2018 at 11:11 PM
    razilla76
    razilla76 Member
    Nor Cal
    2000 2.7L Ext Cab Pre-Runner
    Post a pic of your taco
  5. Aug 17, 2018 at 11:15 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Maybe it's still got water weight & needs to dry out more? :p
  6. Aug 17, 2018 at 11:23 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    To be serious, it could just be the angle of the pics. First pic rear looks higher. Second pic front looks higher. Also showing right side.of the truck, taco lean might possibly be a factor.
    But I don't know, if it was stock height I think it should have a bit more rake. Maybe those Moog front springs are adding a tiny bit of height?
  7. Aug 17, 2018 at 11:25 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Front looks about the same to me. Or were you talking about your rear? Tool box heavy & full?
  8. Aug 17, 2018 at 11:30 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Negative arch? I don't really remember what my stock leafs looked like, I think they were pretty much flat, not negative but they came off the truck at like 45K mi.
  9. Aug 17, 2018 at 11:33 PM
    razilla76
    razilla76 Member
    Nor Cal
    Could be the tire and wheel combo that make it look not as high as mine. Are you running 17s or 16s? Just a thought, not sure if its a valid reason...
  10. Aug 17, 2018 at 11:38 PM
    razilla76
    razilla76 Member
    Nor Cal
    This how we end up dropping more money on the trucks. always looking for a little improvement. But nothing wrong with that!
  11. Aug 17, 2018 at 11:38 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yeah I know what you were saying, sorry, I was trying to say that I don't remember mine ever being negative.
  12. Aug 17, 2018 at 11:38 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    That must suck on any bump. Are you riding the bump stops?
  13. Aug 18, 2018 at 12:35 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    How do you like those fog lights? Do they come on with the headlights?
    I have spots for fog lights on my Predator bumper. Debating on if I should hook them up as running lights, or hook them up to their own independent switch.
    The light output from my retrofits aren’t great. I get excellent long range light throw, but mediocre short range light throw.
  14. Aug 18, 2018 at 12:39 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Getting ready for this lift. I invested in greasable Daystar main eye bushings, as well as greasable OME shackles for my AllPro springs.
    I’m not looking forward to pressing out the upper ball joints in the steering knuckles again. If you were following my 4WD swap back in a December/January, you’ll know why it was such a pain in the ass.
    Please ignore the bed, it’s in the process being replaced on my 5-lug with a clean bed-lined one. Have to drill out the spotwelds on the passenger bedside and I’ll be done.
    Once I get this lift on, I can finally get an alignment. The truck has been wandering since I finished the 4WD swap. Perhaps from the small manufacturing differences in steering knuckles.
    SwampYota, FLBAdrian and BlackPearl like this.
  15. Aug 18, 2018 at 12:44 AM
    koditten
    Kirk
    Central Michigan
    They are driving lights. Fogs are usually yellow. To be honest, I only installed them because my home made bumper didn't look right with out something in that spot.
    They do work good, though, but I don't use them too often. I have a switch that activates a relay so I can run them independent of the headlights.
  16. Aug 18, 2018 at 12:51 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s a home-made bumper? Wow! I thought it was an ARB from the hoop designs. Well done.
  17. Aug 18, 2018 at 12:54 AM
    koditten
    Kirk
    Central Michigan
    I like the looks of the ARB, so I cloned one.jgRlb27NyNwMMBrvmueT47fEw4Q-fOMXMpXyyGLS_f08bb5e35d53632e9b61d5de333be850cfdb4e1a.jpg M0uaqqkG-RsMZjn9W40nZHIeWlJKVjjB5XN9lJ_I_d23eb495fee352a70c281b0161f1270188448347.jpg
  18. Aug 18, 2018 at 12:55 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Excellent work. I wouldn’t know it wasn’t an ARB bumper if you hadn’t told me. How thick is the steel plate?
    I really need to put my Predator bumper together.
  19. Aug 18, 2018 at 12:57 AM
    koditten
    Kirk
    Central Michigan
    10 gauge. It weighs 60 lbs. I got a little bit of sag in the front from the weight, but not enough for me to run out and get taller coils.
  20. Aug 18, 2018 at 1:01 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    That's it? Crazy. I believe the ARB equivalent is about 120 pounds.
